VBS
Добрый день.Есть VBS скрипт создания пользовательской формы для ввода параметров.Подскажите как сделать что бы перед запуском Excel форма ожидала подтверждения. Т.е если ОК то запускается Excel , а если Cancel то выход из формы.Заранеее спасибо Sub clnpsdep_t3 ''ñîçäàíèå äèàëîãîâîãî îêíà Set Form = TForm.Create(Application) Form.Caption = "Ïàðàìåòðû îò÷åòà" Form.Position = poOwnerFormCenter Form.FormStyle = fsStayOnTop Form.Width = 600 Form.Height = 330 ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' set ed = TEdit.Create(Form) ed.Parent = Form ed.Left = 250 ed.Top = 15 ed.Width = 62 ed.Name = "ED" ed.text = date set lb1 = TLabel.Create(Form) lb1.Parent = Form lb1.Left = 10 lb1.Top = 15 lb1.Name = "lb1" lb1.Caption = "Ðàñ÷èòàòü íà äàòó:" '''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' set lb2 = TLabel.Create(Form) lb2.Parent = Form lb2.Left = 10 lb2.Top = 40 lb2.Name = "lb2" lb2.Caption = "Îêëàä:" q = "select code from grsalary " Query.Sql.Text = q Query.Open set cmbbox = TComboBox.Create(Form) cmbbox.Parent = Form cmbbox.Left = 250 cmbbox.Top = 40 cmbbox.Width = 330 cmbbox.Name = "cmbbox" cmbbox.Text = "Íå çàäàíî" While Not Query.EOF Form.cmbbox.Items.Add = Query.FieldByName("code").Value Query.Next I = I + 1 wend ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' set cc = TLabel.Create(Form) cc.Parent = Form cc.Left = 10 cc.Top = 65 cc.Name = "cc" cc.Caption = "Ãðóïïà êàòåãîðèé ÔÎÒ äëÿ ïðî÷èõ íàäáàâîê:" q = "select code from grcatsal " Query.Sql.Text = q Query.Open set DDD = TComboBox.Create(Form) DDD.Parent = Form DDD.Left = 250 DDD.Top = 65 DDD.Width = 330 DDD.Name = "DDD" DDD.Text = "Íå çàäàíî" While Not Query.EOF Form.DDD.Items.Add = Query.FieldByName("code").Value Query.Next I = I + 1 wend ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' set fff = TEdit.Create(Form) fff.Parent = Form fff.Left = 250 fff.Top = 90 fff.Width = 62 fff.Name = "fff" fff.text = date set ggg = TLabel.Create(Form) ggg.Parent = Form ggg.Left = 10 ggg.Top = 90 ggg.Name = "ggg" ggg.Caption = "Äàòà ñîñòàâëåíèÿ:" ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' set bb = TEdit.Create(Form) bb.Parent = Form bb.Left = 250 bb.Top = 115 bb.Width = 330 bb.Name = "bb" bb.text = "" set aa = TLabel.Create(Form) aa.Parent = Form aa.Left = 10 aa.Top = 115 aa.Name = "aa" aa.Caption = "Íîìåð äîêóìåíòà:" ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' set hh = TEdit.Create(Form) hh.Parent = Form hh.Left = 250 hh.Top = 140 hh.Width = 330 hh.Name = "hh" hh.text = "" set kk = TLabel.Create(Form) kk.Parent = Form kk.Left = 10 kk.Top = 140 kk.Name = "kk" kk.Caption = "Ñðåäíåå êîëè÷åñòâî ÷àñîâ â ìåñÿö:" ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' set lb22 = TLabel.Create(Form) lb22.Parent = Form lb22.Left = 10 lb22.Top = 165 lb22.Name = "lb22" lb22.Caption = "Íàçâàíèå îðãàíèçàöèè:" q = "select orgname from lkv_t_bossname " Query.Sql.Text = q Query.Open set cmbbox2 = TComboBox.Create(Form) cmbbox2.Parent = Form cmbbox2.Left = 250 cmbbox2.Top = 165 cmbbox2.Width = 330 cmbbox2.Name = "cmbbox2" cmbbox2.Text = "Íå çàäàíî" While Not Query.EOF Form.cmbbox2.Items.Add = Query.FieldByName("orgname").Value Query.Next I = I + 1 wend ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' set ll = TEdit.Create(Form) ll.Parent = Form ll.Left = 250 ll.Top = 190 ll.Width = 330 ll.Name = "ll" ll.text = "" set mm = TLabel.Create(Form) mm.Parent = Form mm.Left = 10 mm.Top = 190 mm.Name = "mm" mm.Caption = "Äîëæíîñòü ðóêîâîäèòåëÿ:" ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' set nn = TEdit.Create(Form) nn.Parent = Form nn.Left = 250 nn.Top = 215 nn.Width = 330 nn.Name = "nn" nn.text = "" set oo = TLabel.Create(Form) oo.Parent = Form oo.Left = 10 oo.Top = 215 oo.Name = "oo" oo.Caption = "Ô.È.Î. ðóêîâîäèòåëÿ:" ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' set pp = TEdit.Create(Form) pp.Parent = Form pp.Left = 250 pp.Top = 240 pp.Width = 330 pp.Name = "pp" pp.text = "" set rr = TLabel.Create(Form) rr.Parent = Form rr.Left = 10 rr.Top = 240 rr.Name = "rr" rr.Caption = "Ô.È.Î. ãëàâíîãî áóõãàëòåðà:" ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' set cmdPrint = TButton.Create(Form) cmdPrint.Parent = Form cmdPrint.Left = 425 cmdPrint.Top = 270 cmdPrint.Name = "cmdPrint" cmdPrint.Caption = "OK" cmdPrint.Default = true ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' set cmdCancel = TButton.Create(Form) cmdCancel.Parent = Form cmdCancel.Left = 505 cmdCancel.Top = 270 cmdCancel.Name = "cmdCancel" cmdCancel.Caption = "Îòìåíèòü" cmdCancel.Cancel = true ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' form.Visible = True 'Çàïóñêàåì Excel Set ExcelApplication = CreateObject("Excel.Application") Set ExcelWorkbook = ExcelApplication.Workbooks.Add' Set ExcelWorksheet = ExcelWorkbook.Worksheets(1) ExcelWorksheet.Name = "Øòàòíîå ðàñïèñàíèå" ExcelApplication.Sheets("Øòàòíîå ðàñïèñàíèå").Select и т.д........... ... |
| 11.05.2007, 14:31 |
VBS
В смысле на VBS? Запрос подтверждения и если да, то выполнение определенных команд, если нет то других? Если да, можно так: Код: plaintext 1. 2. 3. 4. 5. ... |
| 12.05.2007, 12:12 |
start [/forum/topic.php?desktop=1&fid=60&tid=2164057]: |
147ms |
| others: | 195ms |
| total: | 389ms |
