Ошибка: Недопустимые сведения о привязке
Доброго времени суток! Помогите, пожалуйста, разобраться. Имеем: Set cm = New ADODB.Command cm.ActiveConnection = cnn cm.CommandText = "xx_scm_elm_adj.create_elm_entry_header" cm.CommandType = adCmdStoredProc 'cm.Parameters.Refresh Set Prm_x_errbuf = cm.CreateParameter("x_errbuf", adChar, adParamOutput, 20000) cm.Parameters.Append Prm_x_errbuf Set Prm_retcode = cm.CreateParameter("x_retcode", adInteger, adParamInputOutput) cm.Parameters.Append Prm_retcode 'Prm_retcode.Value = "0" Set Prm_hierarchy_id = cm.CreateParameter("p_hierarchy_id", adInteger, adParamInput) cm.Parameters.Append Prm_hierarchy_id Prm_hierarchy_id.Value = gHierarchy_id Set Prm_entity_id = cm.CreateParameter("p_entity_id", adInteger, adParamInput) cm.Parameters.Append Prm_entity_id Prm_entity_id.Value = gEntity_Id Set Prm_entity_name = cm.CreateParameter("p_entity_name", adVarChar, adParamInput, 5000) cm.Parameters.Append Prm_entity_name Prm_entity_name.Value = gEntity_Name Set Prm_entry_name = cm.CreateParameter("p_entry_name", adVarChar, adParamInput, 5000) cm.Parameters.Append Prm_entry_name Set Prm_entry_description = cm.CreateParameter("p_entry_description", adVarChar, adParamInput, 5000) cm.Parameters.Append Prm_entry_description Set Prm_start_cal_period_id = cm.CreateParameter("p_start_cal_period_id", adVarChar, adParamInput, 5000) cm.Parameters.Append Prm_start_cal_period_id Prm_start_cal_period_id.Value = gCal_Period_Id Set Prm_end_cal_period_id = cm.CreateParameter("p_end_cal_period_id", adVarChar, adParamInput, 5000) cm.Parameters.Append Prm_end_cal_period_id Prm_end_cal_period_id.Value = gCal_Period_Id Set Prm_balance_type_code = cm.CreateParameter("p_balance_type_code", adVarChar, adParamInput, 1000) cm.Parameters.Append Prm_balance_type_code Prm_balance_type_code.Value = gBalance_Type_Code Set Prm_currency_code = cm.CreateParameter("p_currency_code", adVarChar, adParamInput, 10) cm.Parameters.Append Prm_currency_code Prm_currency_code.Value = "UAH" Set Prm_process_code = cm.CreateParameter("p_process_code", adVarChar, adParamInput, 50) cm.Parameters.Append Prm_process_code Prm_process_code.Value = "ALL_RUN_FOR_PERIOD" Set Prm_category_code = cm.CreateParameter("p_category_code", adVarChar, adParamInput, 1000) cm.Parameters.Append Prm_category_code Prm_category_code.Value = gCategory_Code Set Prm_entry_id = cm.CreateParameter("p_entry_id", adInteger, adParamInputOutput) cm.Parameters.Append Prm_entry_id cm.Execute После этого уходит на ошибку. Проверяю: For Each e In cnn.Errors ' cn - это мой ADODB.Connection объект MsgBox e.Description Next ошибка "Недопустимые сведения о привязке". В чём может быть загвоздка? Спасибо. ... |
| 20.02.2008, 16:58 |
> Автор: ADODB > Доброго времени суток! > Помогите, пожалуйста, разобраться. > > Имеем: > Set Prm_x_errbuf = cm.CreateParameter("x_errbuf", adChar, > adParamOutput, 20000) > cm.Parameters.Append Prm_x_errbuf > > Set Prm_retcode = cm.CreateParameter("x_retcode", adInteger, > adParamInputOutput) > cm.Parameters.Append Prm_retcode > 'Prm_retcode.Value = "0" > Set Prm_entry_id = cm.CreateParameter("p_entry_id", adInteger, > adParamInputOutput) > cm.Parameters.Append Prm_entry_id > В чём может быть загвоздка? А правильно указанно направление этих параметров ? А разрешены именованные параметры? А правильно, что некоторым параметрам присваивается значение, а некоторый остаются "сиротами"? Posted via ActualForum NNTP Server 1.4 ... |
| 20.02.2008, 20:12 |
Игорь, спасибо за наводку, разобрался. Дело в том, что в процедуре xx_scm_elm_adj.create_elm_entry_header, которую я вызываю, параметры p_entry_name IN VARCHAR2 DEFAULT NULL, p_entry_description IN VARCHAR2 DEFAULT NULL, по умолчанию Null. И в коде VB я их не указал. А это есть не совсем верно. Я сделал присвоение для этих параметров Prm_entry_name.Value = Null Prm_entry_description.Value = Null и всё заработало. Спасибо еще раз. ... |
| 21.02.2008, 11:31 |
start [/forum/topic.php?desktop=1&fid=60&tid=2162677]: |
53ms |
52ms |
| others: | 248ms |
| total: | 402ms |
