помогите пишу прогу для работать с реестром на удалённом компьютере
Private Sub Command1_Click() Dim lRetVal As Long Dim hKey As Long Dim sValue As String lRetVal = RegOpenKeyEx(hRemoteReg, _ "HARDWARE\DESCRIPTION\System", 0, KEY_QUERY_VALUE, hKey) If lRetVal <> ERROR_SUCCESS Then MsgBox "Cannot open key" Else sValue = String(255, " ") lRetVal = RegQueryValueExString(hKey, _ "SystemBIOSVersion", 0&, REG_SZ, sValue, 255) If lRetVal <> ERROR_SUCCESS Then MsgBox "Cannot query value" Else MsgBox sValue End If lRetVal = RegCloseKey(hKey) If lRetVal <> ERROR_SUCCESS Then MsgBox "Cannot close key" End If End If End Sub Private Sub Form_Load() Option Explicit Private Const HKEY_CLASSES_ROOT = &H80000000 Private Const HKEY_CURRENT_USER = &H80000001 Private Const HKEY_LOCAL_MACHINE = &H80000002 Private Const HKEY_USERS = &H80000003 Private Const KEY_QUERY_VALUE = &H1 Private Const KEY_SET_VALUE = &H2 Private Const KEY_ALL_ACCESS = &H3F Private Const REG_SZ As Long = 1 Private Const ERROR_SUCCESS = 0& Private Declare Function RegConnectRegistry Lib "advapi32.dll" _ Alias "RegConnectRegistryA" _ (ByVal lpMachineName As String, _ ByVal hKey As Long, _ phkResult As Long) As Long End Property Private Declare Function RegCloseKey Lib "advapi32.dll" _ (ByVal hKey As Long) As Long Private Declare Function RegOpenKeyEx Lib "advapi32.dll" _ Alias "RegOpenKeyExA" _ (ByVal hKey As Long, _ ByVal lpSubKey As String, _ ByVal ulOptions As Long, _ ByVal samDesired As Long, _ phkResult As Long) As Long Private Declare Function RegQueryValueExString Lib "advapi32.dll" _ Alias "RegQueryValueExA" _ (ByVal hKey As Long, _ ByVal lpValueName As String, _ ByVal lpReserved As Long, _ lpType As Long, _ ByVal lpData As String, _ lpcbData As Long) As Long Private hRemoteReg As Long End Sub Private Sub Form_Load() Dim lRet As Long 'Connect to the remote registry lRet = RegConnectRegistry("\\RemoteMachineName", _ HKEY_LOCAL_MACHINE, _ hRemoteReg) If (lRet = ERROR_SUCCESS) Then MsgBox "Successfully connected to remote registry" Else MsgBox "Error:" & Err.LastDllError Unload Me Exit Sub End If End Sub Private Sub Form_Unload(Cancel As Integer) Dim lRet As Long If hRemoteReg <> 0 Then lRet = RegCloseKey(hRemoteReg) End If End Sub End Sub но выходит ошибка в Private Declare Function RegConnectRegistry Lib "advapi32.dll" _ Alias "RegConnectRegistryA" _ (ByVal lpMachineName As String, _ ByVal hKey As Long, _ phkResult As Long) As Long """"""""""ОШИБКА"""""""""" Compile eror : only comments may appear after End Sub, End Function or End property """""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""" Что делать??????????? ... |
| 09.06.2010, 09:46 |
Код: plaintext 1. 2. Что непонятно в тексте ошибки? ... |
| 09.06.2010, 09:51 |
Private Sub Command1_Click() Dim lRetVal As Long Dim hKey As Long Dim sValue As String lRetVal = RegOpenKeyEx(hRemoteReg, _ "HARDWARE\DESCRIPTION\System", 0, KEY_QUERY_VALUE, hKey) If lRetVal <> ERROR_SUCCESS Then MsgBox "Cannot open key" Else sValue = String(255, " ") lRetVal = RegQueryValueExString(hKey, _ "SystemBIOSVersion", 0&, REG_SZ, sValue, 255) If lRetVal <> ERROR_SUCCESS Then MsgBox "Cannot query value" Else MsgBox sValue End If lRetVal = RegCloseKey(hKey) If lRetVal <> ERROR_SUCCESS Then MsgBox "Cannot close key" End If End If End Sub Private Sub Form_Load() Option Explicit Private Const HKEY_CLASSES_ROOT = &H80000000 Private Const HKEY_CURRENT_USER = &H80000001 Private Const HKEY_LOCAL_MACHINE = &H80000002 Private Const HKEY_USERS = &H80000003 Private Const KEY_QUERY_VALUE = &H1 Private Const KEY_SET_VALUE = &H2 Private Const KEY_ALL_ACCESS = &H3F Private Const REG_SZ As Long = 1 Private Const ERROR_SUCCESS = 0& Private Declare Function RegConnectRegistry Lib "advapi32.dll" _ Alias "RegConnectRegistryA" _ (ByVal lpMachineName As String, _ ByVal hKey As Long, _ phkResult As Long) As Long Private Declare Function RegCloseKey Lib "advapi32.dll" _ (ByVal hKey As Long) As Long Private Declare Function RegOpenKeyEx Lib "advapi32.dll" _ Alias "RegOpenKeyExA" _ (ByVal hKey As Long, _ ByVal lpSubKey As String, _ ByVal ulOptions As Long, _ ByVal samDesired As Long, _ phkResult As Long) As Long Private Declare Function RegQueryValueExString Lib "advapi32.dll" _ Alias "RegQueryValueExA" _ (ByVal hKey As Long, _ ByVal lpValueName As String, _ ByVal lpReserved As Long, _ lpType As Long, _ ByVal lpData As String, _ lpcbData As Long) As Long Private hRemoteReg As Long End Sub Private Sub Form_Load() Dim lRet As Long 'Connect to the remote registry lRet = RegConnectRegistry("\\RemoteMachineName", _ HKEY_LOCAL_MACHINE, _ hRemoteReg) If (lRet = ERROR_SUCCESS) Then MsgBox "Successfully connected to remote registry" Else MsgBox "Error:" & Err.LastDllError Unload Me Exit Sub End If End Sub Private Sub Form_Unload(Cancel As Integer) Dim lRet As Long If hRemoteReg <> 0 Then lRet = RegCloseKey(hRemoteReg) End If End Sub End Sub но выходит ошибка в Private Declare Function RegConnectRegistry Lib "advapi32.dll" _ Alias "RegConnectRegistryA" _ (ByVal lpMachineName As String, _ ByVal hKey As Long, _ phkResult As Long) As Long ... |
| 09.06.2010, 10:01 |
это я там уже х стродал помоги пожалуйста ... |
| 09.06.2010, 10:04 |
как правильно его составить помоги???????????????? ... |
| 09.06.2010, 10:09 |
kingarthyr, 1) Я уже ответил, привел фрагмент неверного кода 2) Прочти правила форума, научись оформлять код в сообщениях ... |
| 09.06.2010, 10:10 |
Shocker.Pro, не получаться помоги ... |
| 09.06.2010, 10:10 |
Еще там проблема - определения констант и Option не могут быть внутри процедуры. Дальше не смотрел. Хочешь стать крутым мегакулхацкером? Отредактировать чужой реестр? Книжки сначала почитай немножко по VB, а то молоко еще на губах не обсохло ... |
| 09.06.2010, 10:13 |
Shocker.Pro а то молоко еще на губах не обсохло ха, сорвался, а я так ждал, так ждал .... ... |
| 09.06.2010, 10:15 |
ну справедливости ради держался ты ОЧЕНЬ долго. Я бы и 10% не выдержал от твоего respect! ... |
| 09.06.2010, 10:17 |
да мне это по диплому надо ... |
| 09.06.2010, 10:18 |
Shocker.Pro, а как константу забивать? ... |
| 09.06.2010, 10:20 |
[quot Shocker.Pro]Еще там проблема - определения констант и Option не могут быть внутри процедуры. Дальше не смотрел. А Как это я с программистикой не очень на VB работал на 1 курсе ... |
| 09.06.2010, 10:23 |
kingarthyrэто я там уже х стродал помоги пожалуйстаkingarthyrА Как это я с программистикой не очень на VB работал на 1 курсе Да, пожалуй я погорячился насчет учебника по VB. Начать надо с учебника русского языка :-\ ... |
| 09.06.2010, 10:26 |
ну как константу вводить???????? ... |
| 09.06.2010, 10:28 |
2ShamanusShamanusShocker.Pro а то молоко еще на губах не обсохло ха, сорвался, а я так ждал, так ждал .... Ха. Неужели эта тема прошла мимо тебя? ... |
| 09.06.2010, 10:29 |
kingarthyrну как константу вводить???????? С помощью Const. Описание есть в хелпе. ... |
| 09.06.2010, 10:30 |
Shocker.Pro жесть, особенно на фразе Yuliya_7Я хорошо умею работать с SQL севером. А что на этом форуме сначала выясняют квалификацию, а потом дают ответы? но все равно, это нечестная тема, там ты слишком вежливо ответил несмотря на идиотские посты. Эту тему мы заносим в разряд культовых ... |
| 09.06.2010, 10:47 |
ShamanusShocker.Pro жесть, особенно на фразе Yuliya_7Я хорошо умею работать с SQL севером. А что на этом форуме сначала выясняют квалификацию, а потом дают ответы? но все равно, это нечестная тема, там ты слишком вежливо ответил несмотря на идиотские посты. Эту тему мы заносим в разряд культовых У нас одна девочка написала в резюме: В совершенстве владею программой Windows Media Player версии 9 ... |
| 09.06.2010, 10:54 |
Shocker.Pro, Private Sub Form_Load() Private Const HKEY_CLASSES_ROOT = &H80000000 Private Const HKEY_CURRENT_USER = &H80000001 Private Const HKEY_LOCAL_MACHINE = &H80000002 Private Const HKEY_USERS = &H80000003 Private Const KEY_QUERY_VALUE = &H1 Private Const KEY_SET_VALUE = &H2 Private Const KEY_ALL_ACCESS = &H3F Private Const REG_SZ As Long = 1 Private Const ERROR_SUCCESS = 0& Private Declare Function RegConnectRegistry Lib "advapi32.dll" _ Alias "RegConnectRegistryA" _ (ByVal lpMachineName As String, _ ByVal hKey As Long, _ phkResult As Long) As Long Private Declare Function RegCloseKey Lib "advapi32.dll" _ (ByVal hKey As Long) As Long Private Declare Function RegOpenKeyEx Lib "advapi32.dll" _ Alias "RegOpenKeyExA" _ (ByVal hKey As Long, _ ByVal lpSubKey As String, _ ByVal ulOptions As Long, _ ByVal samDesired As Long, _ phkResult As Long) As Long Private Declare Function RegQueryValueExString Lib "advapi32.dll" _ Alias "RegQueryValueExA" _ (ByVal hKey As Long, _ ByVal lpValueName As String, _ ByVal lpReserved As Long, _ lpType As Long, _ ByVal lpData As String, _ lpcbData As Long) As Long Private hRemoteReg As Long End Sub Private Sub Form_Load() Dim lRet As Long 'Connect to the remote registry lRet = RegConnectRegistry("\\RemoteMachineName", _ HKEY_LOCAL_MACHINE, _ hRemoteReg) If (lRet = ERROR_SUCCESS) Then MsgBox "Successfully connected to remote registry" Else MsgBox "Error:" & Err.LastDllError Unload Me Exit Sub End If End Sub Private Sub Form_Unload(Cancel As Integer) Dim lRet As Long If hRemoteReg <> 0 Then lRet = RegCloseKey(hRemoteReg) End If End Sub все ровно не помучается ... |
| 09.06.2010, 10:56 |
А что пишет? :) Posted via ActualForum NNTP Server 1.4 ... |
| 09.06.2010, 11:02 |
kingarthyrвсе ровно не помучается Ровно не получается, криво - тоже не получается Я уже говорил - декларации констант (а заодно и АПИ-функций) не могут быть внутри процедуры. Вынесите их в общий раздел модуля. ... |
| 09.06.2010, 11:05 |
Игорь Горбонос, """"""""""ОШИБКА"""""""""" Compile eror : only comments may appear after End Sub, End Function or End property """""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""" ... |
| 09.06.2010, 11:06 |
kingarthyr, а зачем Код: plaintext А еще я просил прочитать правила форума и научиться оформлять код ... |
| 09.06.2010, 11:08 |
я взял этот код с """"""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""" Как в Visual Basic 6.0 работать с реестром на удалённом компьютере http://www.source-code.ru/msdn/howto/q315586.shtml """"""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""" ... |
| 09.06.2010, 11:11 |
start [/forum/topic.php?desktop=1&fid=60&tid=2159670]: |
25ms |
48ms |
46ms |
| others: | 240ms |
| total: | 387ms |
