powered by simpleCommunicator - 2.0.44     © 2025 Programmizd 02
Форумы / Oracle [игнор отключен] [закрыт для гостей] / Проблемы с преобразованием типов при выборке в Oracle 19c через Heterogeneous Services из PostgreSQL 15
3 сообщений из 3, страница 1 из 1
    #40138108
mvadim2003
Всем привет.
Конфигурация ODBC и гетерогенного сервиса:
Код: BASH
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
[ODBC Data Sources]
root@dev-postgres1:~# cat /etc/odbc.ini
GG_Postgres=DataDirect 6.1 PostgreSQL Wire Protocol
[ODBC]
QEWSD=2460221
IANAAppCodePage=106
InstallDir=/usr/lib/x86_64-linux-gnu/odbc/
[STF_DBS]
Driver=/usr/lib/x86_64-linux-gnu/odbc/psqlodbca.so
Description=DataDirect 6.1 PostgreSQL Wire Protocol
Database=stf_dbs
Server=127.0.0.1
PortNumber=5432
LogonID         = srv_goldengate
Password = my_postgres_password
oracle@nbs-testing> cat /home/oracle/u01/app/product/19.3/db_home/hs/admin/initSTF_DBS.ora
Код: BASH
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
HS_FDS_CONNECT_INFO = STF_DBS
HS_FDS_SQLLEN_INTERPRETATION = 64
HS_RPC_FETCH_REBLOCKING= OFF
HS_FDS_FETCH_ROWS = 1
HS_KEEP_REMOTE_COLUMN_SIZE=ALL
#HS_FDS_TRACE_LEVEL = 4
HS_FDS_TRACE_LEVEL = 255
HS_FDS_SHAREABLE_NAME = /usr/pgsql-15/lib/psqlodbcw.so
HS_NLS_NCHAR=UCS2
HS_FDS_TRACE_LEVEL=ON
set ODBCINI=/etc/odbc.ini
HS_NLS_LENGTH_SEMANTICS=BYTE
NLS_LANGUAGE=AMERICAN
NLS_TERRITORY=AMERICA
NLS_CHARACTERSET=WE8ISO8859P9
oracle@nbs-testing> cat /home/oracle/u01/app/product/19.3/db_home/network/admin/listener.ora
Код: BASH
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
SID_LIST_LISTENER =
  (SID_LIST =
    (SID_DESC =
      (SID_NAME = orcl)
      (ORACLE_HOME = /home/oracle/u01/app/product/19.3/db_home)
LISTENER =
  (DESCRIPTION_LIST =
    (DESCRIPTION =
      (ADDRESS = (PROTOCOL = TCP)(HOST = 10.32.201.136)(PORT = 1521))
      (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC1521))
SID_LIST_LISTENER =
   (SID_LIST=
      (SID_DESC=
      (SID_NAME=STF_DBS)
      (ORACLE_HOME=/home/oracle/u01/app/product/19.3/db_home)
      (CONNECT_DATA=(SID=STF_DBS))
      (PROGRAM=dg4odbc)
      (ENVS=LD_LIBRARY_PATH=/usr/lib64:/home/oracle/u01/app/product/19.3/db_home/lib)
Тестовая таблица на стороне PostgreSQL 15:
Код: PL/pgSQL
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
72.
73.
74.
75.
DROP TABLE IF EXISTS slm.test_table;
CREATE TABLE IF NOT EXISTS slm.test_table
id integer NOT NULL,
name character varying(200) COLLATE pg_catalog."default",
flag boolean,
guid uuid,
date_field date,
timestamp_0 timestamp(0) without time zone,
timestamp_3 timestamp(3) without time zone,
timestamp_6 timestamp(6) without time zone,
timestamp_unlimited timestamp without time zone,
int16 smallint,
int32 integer,
int64 bigint,
varchar_10 varchar(10),
varchar_1000 varchar(1000),
varchar_2000 varchar(2000),
--varchar_2001 varchar(2001), -- ломает работу через dblink
varchar_unlimited varchar,
text_field text, -- ORA-00997: illegal use of LONG datatype (при выполнении create table)
json_field json,
money_in_rubles public.money_in_rubles,
bytea_field bytea
CONSTRAINT test_table_pkey PRIMARY KEY (id)
grant all on slm.test_table to srv_oracle_dblink;
DO
DECLARE
  ts1 timestamp := '2023-09-27 12:01:02.123456'::timestamp;
  ts2 timestamp := '2023-09-27 12:01:02.987654'::timestamp;
  str10 varchar := 'а' || REPEAT('.', 8) || 'я';
  str1000 varchar := 'а' || REPEAT('.', 998) || 'я';
  str2000 varchar := 'а' || REPEAT('.', 1998) || 'я';
  str10000 varchar := 'а' || REPEAT('.', 9998) || 'я';
  str100000 varchar := 'а' || REPEAT('.', 99998) || 'я';
  json10 json := '{ "a": 1 }';
  json300 json := '{ "a1": "123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890", "a2": "123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890", "a3": "123456789012345678901234567890123456789012345678901234567890123456789012345678901234567" }';
  byte16 bytea := '\x00112233445566778899AABBCCDDEEFF'::bytea;
BEGIN
insert into slm.test_table (id, date_field, name) values (0, '2023-09-27'::date, 'Проверка date 2023-09-27');
insert into slm.test_table (id, timestamp_0, timestamp_3, timestamp_6, timestamp_unlimited, name) values (10, ts1, ts1, ts1, ts1, 'Проверка timestamp 2023-09-27 12:01:02.123456');
insert into slm.test_table (id, timestamp_0, timestamp_3, timestamp_6, timestamp_unlimited, name) values (11, ts2, ts2, ts2, ts2, 'Проверка timestamp 2023-09-27 12:01:02.987654');
insert into slm.test_table (id, flag, name) values (20, false, 'Проверка boolean false');
insert into slm.test_table (id, flag, name) values (21, true, 'Проверка boolean true');
insert into slm.test_table (id, guid, name) values (30, gen_random_uuid(), 'Проверка uuid');
insert into slm.test_table (id, guid, name) values (31, gen_random_uuid(), 'Проверка uuid');
insert into slm.test_table (id, int16, int32, int64, name) values (40, -32768, -2147483648, -9223372036854775808, 'Проверка граничных целочисленных значений');
insert into slm.test_table (id, int16, int32, int64, name) values (41, 32767, 2147483647, 9223372036854775807, 'Проверка граничных целочисленных значений');
insert into slm.test_table (id, varchar_10, varchar_1000, varchar_2000, name) values (50, str10, str1000, str2000, 'Проверка varchar(x)');
insert into slm.test_table (id, varchar_unlimited, name) values (51, str100000, 'Проверка varchar');
insert into slm.test_table (id, text_field, name) values (60, str10::text, 'Проверка text 10');
insert into slm.test_table (id, text_field, name) values (61, str2000::text, 'Проверка text 2000');
insert into slm.test_table (id, text_field, name) values (62, str10000::text, 'Проверка text 10000');
--insert into slm.test_table (id, text_field, name) values (63, str100000::text, 'Проверка text 100000'); -- arraycopy: last source index 32769 out of bounds for byte[32768]
insert into slm.test_table (id, json_field, name) values (70, json10, 'Проверка json 10');
--insert into slm.test_table (id, json_field, name) values (71, json300, 'Проверка json 300'); -- arraycopy: length -18 is negative
insert into slm.test_table (id, money_in_rubles, name) values (80, 1234567.89, 'Проверка money_in_rubles');
insert into slm.test_table (id, bytea_field, name) values (90, byte16, 'Проверка bytea 16');
END
Через isql все работает:
oracle@dev-postgres1:~$ isql -v STF_DBS srv_goldengate my_postgres_password
Код: SQL
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
| Connected!                            |
| sql-statement                         |
| help [tablename]                      |
| quit                                  |
SQL>
SQL> SELECT id, name, flag, guid, date_field, timestamp_0, timestamp_3, timestamp_6, timestamp_unlimited, int16, int32, int64, varchar_10, varchar_1000, varchar_2000, varchar_unlimited, text_field, json_field, money_in_rubles, byte16
        FROM slm.test_table
SQLRowCount returns 17
17 rows fetched
SQL>
Когда я пытаюсь из ораклового клиента через dblink заселектить данные из таблицы, то получаю следующее:
1. Значения полей varchar больше 255 символов, обрезаются до 255 символов.
2. Значения полей varchar больше 2000 символов в Oracle приходят вообще, как тип LONG.
Вопрос: что и где нужно подкрутить, чтобы этого избежать?
    #40138197
Фотография andrey_anonymous
Да нет никого в этом музее, чего шумите?
mvadim2003  04.10.2023, 14:40
[игнорируется]
Код: BASH
1.
Код: PL/pgSQL
1.
insert into slm.test_table (id, flag, name) values (20, false, >>>'Проверка boolean false'<<<);
1. Где HS_LANGUAGE?
2. Почему WE8ISO8859P9, если работаете с кириллицей???
Зачем и для кого этот самый чарсет указывать надо - хорошо понимаете?
[игнорируется]
Какого клиента?
Каким приложением?
Короче - как определили, что строки режутся именно HS_ODBC, а не Вашим клиентом при отображении?
[игнорируется]
Так тут заведено (с поправкой на NLS_LENGTH_SEMANTICS):
https://docs.oracle.com/en/database/oracle/oracle-database/21/odbcu/database-gateway-odbc-data-type-conversion.html#GUID-2185626B-7A3D-4AFA-877F-4CC4B72843A0
    #40138249
Javl
mvadim2003 [игнорируется]
В моем случае было достаточно в odbc.ini у подключения добавить строку
ConnSettings = SET CLIENT_ENCODING to 'WIN1251'
Больше никаких NLS параметров не прописано.
Изменено: 01.12.2023, 14:46 - Javl
