Create database. HELP!
Существует скрипт: spool /oracle/admin/dir_name/create/crdbdb_name.lst connect internal startup nomount pfile=/oracle/admin/dir_name/pfile/initdb_name_0.ora create database "db_name" maxinstances 8 maxlogfiles 32 character set "CL8ISO8859P5" national character set "CL8ISO8859P5" datafile '/oracle/oradata/dir_name/system01.dbf' size 200M logfile '/oracle/oradata/dir_name/redodb_name01.log' size 2M, '/oracle/oradata/dir_name/redodb_name02.log' size 2M, '/oracle/oradata/dir_name/redodb_name03.log' size 2M; disconnect spool off При запуске получается следующее: SVRMGR> @/oracle/admin/dir_name/create/crdbdb_name.sql Connected. ORACLE instance started. Total System Global Area 6003688 bytes Fixed Size 52200 bytes Variable Size 4235264 bytes Database Buffers 1638400 bytes Redo Buffers 77824 bytes create database "db_name" * ORA-01501: CREATE DATABASE failed ORA-00200: controlfile could not be created ORA-00202: сontrolfile: '/oracle/oradata/db_name/control01.ctl' ORA-27038: skgfrcre: file exists Disconnected. Все control файлы и redo файлы после отработки скрипта создаются. Oracle 8.0.6.2.0 ОС HP-UX 11.0 Заранее благодарен за помощь. ... |
| 06.09.2002, 11:06:04 |
наверное надо: create database "db_name" controlfile reuse ... ... |
| 06.09.2002, 12:42:08 |
start [/forum/topic.php?desktop=1&fid=52&tid=1993130]: |
63ms |
46ms |
| others: | 230ms |
| total: | 387ms |
