SID.world
в tnsnames.ora написано: SID.world ..... ....... Что значит world? И почему оракл позволяет коннектица world не указывая? ... |
| 09.12.2002, 18:30 |
SID.world
In previous releases of SQL*Net and Oracle Names, a network with only one domain would by default be called ".world". This is no longer a requirement with Net8 and Oracle Names version 8. You may, however, want to keep the same convention to be backward compatible, as well as to avoid having to rename all your databases. ... |
| 10.12.2002, 04:55 |
start [/forum/topic.php?desktop=1&fid=52&tid=1992499]: |
45ms |
27ms |
| others: | 229ms |
| total: | 343ms |
