ORA-00600: internal error code, arguments: [1113], [], [], [], [], [], [], []
Выскочила такая ошибка (8.1.7 на W2K Server) ORA-1652: unable to extend temp segment by 32 in tablespace TEMP Sat Dec 28 09:27:46 2002 Errors in file C:\OraNT\admin\DBTX2530\udump\ORA01132.TRC: ORA-00600: internal error code, arguments: [1113], [], [], [], [], [], [], [] ORA-01652: unable to extend temp segment by 32 in tablespace TEMP Sat Dec 28 09:27:47 2002 Errors in file C:\OraNT\admin\DBTX2530\udump\ORA01132.TRC: ORA-00600: internal error code, arguments: [504], [965095972], [8], , [cache buffers chains], [668], [0], [0] ORA-01652: unable to extend temp segment by 32 in tablespace TEMP Что-бы это значило? ... |
| 04.01.2003, 03:49 |
ORA-01652 unable to extend temp segment by string in tablespace string Cause: Failed to allocate an extent for temporary segment in tablespace. Action: Use ALTER TABLESPACE ADD DATAFILE statement to add one or more files to the tablespace indicated. ... |
| 04.01.2003, 10:44 |
start [/forum/topic.php?desktop=1&fid=52&tid=1992288]: |
47ms |
49ms |
| others: | 207ms |
| total: | 352ms |
