Где найти скрипты для создания демо-таблиц под Report Builder?
Может есть у кого-нибудь??? Нашел в доке следующее, но CD у меня нет... В инете тоже не нашел :( Буду очень признателен. _______________________________________________________ 1.3 Obtaining database access before you start In order to build the reports as described in this manual, you must be able to access the Oracle Reports Developer demo tables. Use the demo CD that came with your product package to install the SQL scripts. These scripts are used to install the demo tables in your database. These SQL scripts can be run from the Start->Programs menu. Before starting a report, be sure to log into the database that contains the Oracle Reports Developer demo tables. You log in by selecting File->Connect. ... |
| 12.01.2003, 15:14 |
start [/forum/topic.php?desktop=1&fid=52&tid=1992229]: |
163ms |
25ms |
| others: | 204ms |
| total: | 433ms |
