ошибка при shutdown базы
При shutdown базы в Oracle 9.2 из Enterprice Manager Console происходит ошибка 00106 и просесс не заканчиваеься. Остановить базу можно только если остановить сервис. Что делать ??? ... |
| 15.01.2003, 11:49 |
ORA-00106 cannot startup/shutdown database when connected to a dispatcher Cause: An attempt was made to start or shut down an instance while connected to a shared server via a dispatcher. Action: Reconnect as user INTERNAL without going through the dispatcher. For most cases, this can be done by connect to INTERNAL without specifying a network connect string. ... |
| 15.01.2003, 12:11 |
start [/forum/topic.php?desktop=1&fid=52&tid=1992187]: |
144ms |
| others: | 187ms |
| total: | 381ms |
