Empty Tablespaces
Vot uzh ne dumal, chto opredelit pustyje TS v bolshoj base budet tak slozhno. elementarnyj Statement: select tablespace_name from dba_tablespaces where tablespace_name not in (select distinct tablespace_name from dba_segments); imejet Plan na 1000 Strok i dlitsya na BD s 17000 Segmentov bolshe 20 Min, prichinyaja 16000000 consistent gets. Peredelal na PL/SQL: declare v_tsname varchar2(30); v_tssize integer; v_tsfree integer; v_tsfpct integer; v_tsstot integer := 0; v_tsftot integer := 0; v_string varchar2(79); v_empty integer; cursor c1 is select tablespace_name,round(sum(bytes)/1024/1024,2) tssize from dba_data_files group by tablespace_name; cursor c2 is select distinct name from ts$ t,seg$ s where t.ts#=s.ts#; cursor c3 is select round(sum(bytes)/1024/1024,2) tsfree from dba_free_space where tablespace_name = v_tsname; begin dbms_output.enable(50000); v_string := rpad('Tablespace',30)||lpad('Size (Mb)',12)||lpad('Free (Mb)',12)||lpad('Pct free',10); dbms_output.put_line(v_string); for i1 in c1 loop v_tsname:=i1.tablespace_name; v_tssize := i1.tssize; v_empty:=1; for i2 in c2 loop if i2.name=v_tsname then v_empty:=0; end if; end loop; if v_empty=1 then v_tsstot := v_tsstot + v_tssize; for i3 in c3 loop v_tsfree := i3.tsfree; v_tsftot := v_tsftot + v_tsfree; v_tsfpct := round(v_tsfree * 100 / v_tssize,0); v_string := rpad(v_tsname,30)||lpad(v_tssize,12)||lpad(v_tsfree,12)||lpad(v_tsfpct,10); dbms_output.put_line(v_string); end loop; end if; end loop; v_string := rpad('-',30,'-')||' '||lpad('-',11,'-')||' '||lpad('-',11,'-')||' '||lpad('-',9,'-'); dbms_output.put_line(v_string); v_tsfpct := round(v_tsftot * 100 / v_tsstot,0); v_string := rpad('Total',30)||lpad(v_tsstot,12)||lpad(v_tsftot,12)||lpad(v_tsfpct,10); dbms_output.put_line(v_string); v_string := chr(10); dbms_output.put_line(v_string); end; effekt totzhe. Hotel chtoby bylo krasivo, a poluchilos kak vsegda!:(( Mozh pomozhet kto, lyudi dobryje!!! ... |
| 05.02.2003, 16:12 |
Empty Tablespaces
так вроде быстрее: Код: plaintext 1. 2. 3. 4. 5. 6. ... |
| 05.02.2003, 16:49 |
Empty Tablespaces
k sozhaleniju i select tablespace_name from dba_tablespaces t 2 where not exists ( 3 select 1 from dba_segments s 4* where s.tablespace_name = t.tablespace_name ) dlitsya bolshe 15 minut. Dolzhen byt gde-to drugoj vychod. ... |
| 05.02.2003, 18:10 |
Empty Tablespaces
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. ... |
| 05.02.2003, 18:40 |
Empty Tablespaces
ну, кто лучше? вот мой вариант: Код: plaintext 1. 2. 3. 4. ... |
| 05.02.2003, 20:20 |
Empty Tablespaces
Variant konechmo luchshij, no resultaty zaprosov ne sovpadajut. ... |
| 06.02.2003, 13:05 |
Empty Tablespaces
obschem rodil krokodila :-). Kto zhelajet polzujtes. Spasibo za pomosch. set pause off set echo off set termout on prompt prompt sel_ts_empty.sql prompt prompt Script lists the empty tablespaces. prompt define spoolfile = sel_ts_empty.lst set pages 50000 set linesize 79 set heading on set verify off set feedback off set serveroutput on spool &&spoolfile declare v_tsname varchar2(30); v_tssize integer; v_tsfree integer; v_tsfpct integer; v_tsstot integer := 0; v_tsftot integer := 0; v_string varchar2(79); cursor c1 is select tablespace_name,round(sum(bytes)/1024/1024,2) tssize from dba_data_files where tablespace_name in ( select tablespace_name from dba_tablespaces minus select tablespace_name from dba_tablespaces t where exists ( select 1 from dba_segments s where s.tablespace_name = t.tablespace_name ) ) group by tablespace_name; cursor c2 is select round(sum(bytes)/1024/1024,2) tsfree from dba_free_space where tablespace_name = v_tsname; begin dbms_output.enable(50000); v_string := rpad('Tablespace',30)||lpad('Size (Mb)',12)||lpad('Free (Mb)',12)||lpad('Pct free',10); dbms_output.put_line(v_string); v_string := rpad('-',30,'-')||' '||lpad('-',11,'-')||' '||lpad('-',11,'-')||' '||lpad('-',9,'-'); dbms_output.put_line(v_string); for i1 in c1 loop v_tsname := i1.tablespace_name; v_tssize := i1.tssize; v_tsstot := v_tsstot + v_tssize; for i2 in c2 loop v_tsfree := i2.tsfree; v_tsftot := v_tsftot + v_tsfree; v_tsfpct := round(v_tsfree * 100 / v_tssize,0); v_string := rpad(v_tsname,30)||lpad(v_tssize,12)||lpad(v_tsfree,12)||lpad(v_tsfpct,10); dbms_output.put_line(v_string); end loop; end loop; v_string := rpad('-',30,'-')||' '||lpad('-',11,'-')||' '||lpad('-',11,'-')||' '||lpad('-',9,'-'); dbms_output.put_line(v_string); v_tsfpct := round(v_tsftot * 100 / v_tsstot,0); v_string := rpad('Total',30)||lpad(v_tsstot,12)||lpad(v_tsftot,12)||lpad(v_tsfpct,10); dbms_output.put_line(v_string); v_string := chr(10); dbms_output.put_line(v_string); end; / spool off clear breaks clear computes set pages 60 set verify on set feedback on prompt prompt Output is spooled to &&spoolfile prompt undef spoolfile ... |
| 06.02.2003, 13:19 |
Empty Tablespaces
>Variant konechmo luchshij, no resultaty zaprosov ne sovpadajut. А что именно не совпадает? ... |
| 06.02.2003, 14:28 |
Empty Tablespaces
ne sovpadajet kollichestbo empty tablespaces. Pochozhe chto seg$ mozhet soderzhat segmenty allokirovanyje v uzhe ne suschstvujuschich tablespasah. ... |
| 06.02.2003, 18:18 |
Empty Tablespaces
Nesovpadaut iz-za znacheniya polya online$ = 3 v TS$ --> ono oznachaet, cho TS udalena dlya sovpadeniya nuzno: Код: plaintext 1. 2. 3. 4. 5. 6. 7. raznica megdu 2 zaprosami: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. ... |
| 06.02.2003, 18:24 |
start [/forum/topic.php?desktop=1&fid=52&tid=1991904]: |
142ms |
44ms |
| others: | 197ms |
| total: | 425ms |
