Alter package
Может кто бросанет скрипты на компиляцию тела пакета и спецификации по отдельности ... |
| 28.02.2003, 12:04 |
Alter package
rem ********************************************************* rem Перекомпиляция инвалидных объектов системы rem (ALTER PACKAGE COMPILE BODY) rem Запускается из-под SQL*Plus rem ********************************************************* set feedback off set heading off set newpage 0 set pagesize 0 set echo off set termout off set verify off set serveroutput on size 2000000 set linesize 250 set arraysize 1 set trimspool on set trimout on column xxx new_value oxxx noprint select user xxx from dual; spool &oxxx..sql select 'prompt *** '||object_type||' '||object_name||chr(10) ||'ALTER '||DECODE(object_type,'PACKAGE BODY','PACKAGE',object_type) ||' '||object_name||DECODE(object_type,'PACKAGE BODY',' COMPILE BODY;','TRIGGER',' ENABLE;',' COMPILE;') ||chr(10)||'sho err '||object_type||' '||object_name from user_objects where status!='VALID' and object_type in ('VIEW','PACKAGE','PROCEDURE','PACKAGE BODY','FUNCTION','TRIGGER'); spool off set termout on spool &oxxx..out prompt Протокол компиляции пакетов select 'Started compiling packages - '||TO_CHAR(SYSDATE,'DD/MM/YY (HH24:MI:SS)') from dual; @&oxxx. select 'Finished compiling packages - '||TO_CHAR(SYSDATE,'DD/MM/YY (HH24:MI:SS)') from dual; spool off host del &oxxx..sql set feedback on set heading on ... |
| 28.02.2003, 12:06 |
Alter package
ALTER PACKAGE name COMPILE specification; ALTER PACKAGE name COMPILE BODY; Ne podhodit? ... |
| 28.02.2003, 12:31 |
start [/forum/topic.php?desktop=1&fid=52&tid=1991668]: |
136ms |
23ms |
| others: | 204ms |
| total: | 392ms |
