UPDATED TAR Alert! - TAR 2882164.995
TAR 2882164.995 - IMP: ABNORMAL END OF EXPORT FILE, EXPORT ENDED SUCESSFULLY IMP-0009 has been updated by Oracle Support with relevant information on 17-MAR-03. To view the progress on-line via MetaLink, go to this URL: http://metalink.oracle.com/metalink/plsql/tar_main.this_tar?tar_num=2882164.995&p_ctryCode=826 ... |
| 17.03.2003, 11:57 |
exp+imp after setting columns as unused. exp terminates without warnings. imp silently corrupts data or terminates abnormally. this was tested on our production systems, still under Oracle's investigation. ... |
| 17.03.2003, 12:02 |
start [/forum/topic.php?desktop=1&fid=52&tid=1991463]: |
184ms |
28ms |
| others: | 234ms |
| total: | 486ms |
