Oracle
Добрый день. Скажите что означают ошибки при инсталяции Oracle 8.1.6 на Solaris 8: ORA-01034 ORA-01012 Весь процесс инсталяции проходит успешно, вот как только доходдит до создания БД, ты выскакивает данная ошибка. 2. Как можно узнать стартанул ли Оракл или нет. Просто я смотрел через ps -A | grep ora ничего не было. Может его как то надо стартонуть??? Как подскажите. ... |
| 21.04.2003, 14:15 |
Oracle
| 21.04.2003, 14:15 |
Oracle
ORA-01012 not logged on Cause: A host language program issued an Oracle call, other than OLON or OLOGON, without being logged on to Oracle. This can occur when a user process attempts to access the database after the instance it is connected to terminates, forcing the process to disconnect. Action: Log on to Oracle, by calling OLON or OLOGON, before issuing any Oracle calls. When the instance has been restarted, retry the action. ORA-01034 ORACLE not available Cause: Oracle was not started. Possible causes include the following: The SGA requires more space than was allocated for it. The operating-system variable pointing to the instance is improperly defined. Action: Refer to accompanying messages for possible causes and correct the problem mentioned in the other messages. If Oracle has been initialized, then on some operating systems, verify that Oracle was linked correctly. See the platform-specific Oracle documentation. ... |
| 21.04.2003, 14:35 |
Oracle
ORA-01034 Oracle not available Cause: Oracle was not started up. Possible causes include the following: The SGA requires more space than was allocated for it. The operating system variable pointing to the instance was improperly defined. Action: Refer to accompanying messages for possible causes and correct the problem mentioned in the other messages. Retry after Oracle has been initialized. If Oracle has been initialized, then on some operating systems, verify that Oracle was linked correctly. See the platform-specific Oracle documentation. ORA-01012 not logged on Cause: A host language program issued an Oracle call, other than OLON or OLOGON, without being logged on to Oracle. This can occur when a user process attempts to access the database after the instance it is connected to terminates, forcing the process to disconnect. Action: Log on to Oracle, by calling OLON or OLOGON, before issuing any Oracle calls. When the instance has been restarted, retry the action. ... |
| 21.04.2003, 16:24 |
start [/forum/topic.php?desktop=1&fid=52&tid=1990892]: |
153ms |
| others: | 263ms |
| total: | 474ms |
