Ошибка при EXPORT в 9.0i
При EXPORTe в LOGе такие сообщения: EXP-00008: ORACLE error 6550 encountered ORA-06550: line 1, column 13: PLS-00201: identifier 'SYS.LT_EXPORT_PKG' must be declared ORA-06550: line 1, column 7: PL/SQL: Statement ignored EXP-00083: The previous problem occurred when calling SYS.LT_EXPORT_PKG.schema_info_exp Может, кто-нибудь прояснит, что не так? ... |
| 25.04.2003, 19:23 |
It is a known bug (Bug:1828996). Fix: Connect as sys and grant this privileges before running the export: GRANT EXECUTE ON sys.lt_export_pkg TO exp_full_database; OR GRANT EXECUTE ON sys.lt_export_pkg TO PUBLIC; Solomon Yakobson. ... |
| 25.04.2003, 20:12 |
start [/forum/topic.php?desktop=1&fid=52&tid=1990805]: |
44ms |
33ms |
| others: | 303ms |
| total: | 428ms |
