tnsping dlitsya 20 secund
Perrenes bazu s odnogo servera na drugoj. solaris SunOS 5.8 Generic Patch oracle 8.1.7.4. maschine E15K 8 Processors ransche tnsping schol zu 10-100ms teper 20000-70000. Perkonfiguriroval na druguju Netzwerkkartu- effect totzhe. listener.ora: listener_XXXX = (ADDRESS_LIST = (ADDRESS=(PROTOCOL=tcp)(HOST=xxxx-pr1)(PORT=7022)(queuesize=32)) (ADDRESS=(PROTOCOL=tcp)(HOST=xxxx-pr2)(PORT=7222)(queuesize=32)) ) SID_LIST_LISTENER_XXXX = (SID_LIST = (SID_DESC = (SDU = 1460)(TDU = 1460) (GLOBAL_DBNAME = XXXX) (ORACLE_HOME = /opt/oracle/product/817) (SID_NAME = XXXX) ) ) Pervyj Interface dlya UNIX, vtoroj - dlya CITRYX, ostlasy pri perenose bazy bez izmenenij. Chertovschina kakaja-to:((( ... |
| 05.05.2003, 17:56 |
Похоже у тебя не настроен DNS. ... |
| 05.05.2003, 17:57 |
vse nastrojeno kak nado. ... |
| 05.05.2003, 18:01 |
Dai log netstat ... |
| 05.05.2003, 21:32 |
oracle@borys2:/opt/oracle>netstat -i Name Mtu Net/Dest Address Ipkts Ierrs Opkts Oerrs Collis Queue lo0 8232 loopback localhost 16650612 0 16650612 0 0 0 ce0 1500 borys2-hb2 borys2-hb2 339785151 0 5909144 0 0 0 ce2 1500 borys2-hb3 borys2-hb3 121959316 0 5909433 0 0 0 ce3 1500 borys2-e5-p borys2-e5-p 283616399 0 0 0 0 0 dman0 1500 10.1.1.0 10.1.1.3 69389 0 563260 2 0 0 ge0 1500 borys2-g0-p borys2-g0-p 2600496210 0 2838015456 0 0 0 ge1 1500 borys2-g1-p borys2-g1-p 6043098 0 3 0 0 0 qfe0 1500 borys2-e0 borys2-e0 49955946 0 32417845 0 0 0 qfe1 1500 borys2-hb1 borys2-hb1 365126696 50780 5909148 0 0 0 qfe2 1500 borys2-e2-p borys2-e2-p 994815701 0 728023078 0 0 0 Listener sluschajet na ge0- Interface ... |
| 06.05.2003, 11:27 |
tut vot jescho client trace dlya DB .................... [06-MAY-2003 11:54:45] nscon: recving a packet [06-MAY-2003 11:54:45] nsprecv: entry [06-MAY-2003 11:54:45] nsbal: entry [06-MAY-2003 11:54:45] nsbgetfl: entry [06-MAY-2003 11:54:45] nsbgetfl: normal exit [06-MAY-2003 11:54:45] nsmal: entry [06-MAY-2003 11:54:45] nsmal: 44 bytes at 0x316580 [06-MAY-2003 11:54:45] nsmal: normal exit [06-MAY-2003 11:54:45] nsbal: normal exit [06-MAY-2003 11:54:45] nsprecv: reading from transport... [06-MAY-2003 11:54:45] nttrd: entry [06-MAY-2003 11:55:08] nttrd: socket 192 had bytes read=8 [06-MAY-2003 11:55:08] nttrd: exit [06-MAY-2003 11:55:08] nsprecv: 8 bytes from transport [06-MAY-2003 11:55:08] nsprecv: tlen=8, plen=8, type=11 [06-MAY-2003 11:55:08] nsprecv: packet dump [06-MAY-2003 11:55:08] nsprecv: 00 08 00 00 0B 00 00 00 |........| [06-MAY-2003 11:55:08] nsprecv: normal exit [06-MAY-2003 11:55:08] nscon: got NSPTRS packet [06-MAY-2003 11:55:08] nscon: no connect data [06-MAY-2003 11:55:08] nscon: exit (0) [06-MAY-2003 11:55:08] nsdo: nsctxrnk=0 [06-MAY-2003 11:55:08] nsdo: normal exit ......................... 25 Secund dlilsya connect s sqlplus:((( ... |
| 06.05.2003, 16:55 |
Switch ispol'zuesh? Pohoge, eto LAN's problem.. "E15K" local ping skol'ko vremeni?? ... |
| 06.05.2003, 17:21 |
mgnovenno. Na etom zhe interface, no s drugim Virtual-Ip i na drugom Portu sluschajet Listener dlya vtoroj DB. tnsping na etu druguju DB dlitsya 20-30 ms. Obe DB sravnimy po kollichestvu connectov. :-(((( ... |
| 07.05.2003, 10:57 |
truss na Clienta: ............... 1087/1: 0.0017 sigaction(SIGPIPE, 0xFFBE9D60, 0xFFBE9E8C) = 0 1087/1: 0.0016 getpid() = 1087 [6888] 1087/1: 0.0009 write(8, "\0D2\0\001\0\0\001 601 ,".., 210) = 210 1087/1: read(8, 0x000EDF76, 1476) (sleeping...) 1087/2: signotifywait() (sleeping...) 1087/3: lwp_cond_wait(0xFEBF5548, 0xFEBF5558, 0xFEBEEDB0) (sleeping...) 1087/4: door_return(0x00000000, 0, 0x00000000, 0) (sleeping...) 1087/1: 33.7050 read(8, "\0\b\0\0\v\0\0\0", 1476) = 8 1087/1: 0.0012 write(8, "\0D2\0\001\0\0\001 601 ,".., 210) = 210 1087/1: 0.0004 read(8, "\0 \0\002\0\0\001 6\f01".., 1476) = 32 1087/1: 0.0008 brk(0x000EF990) = 0 1087/1: 0.0004 brk(0x000F1990) = 0 1087/1: 0.0011 sigaction(SIGTSTP, 0xFFBEC470, 0xFFBEC59C) = 0 ................ 33,7 secundy pytajetsya chet prochitat?:( ... |
| 07.05.2003, 14:22 |
vse!!! reshili problemu. Unixoviki krivo /opt/oracle smontirovali!!!! ...read/write/setuid/mincache=closesync/delaylog/largefiles/usw... ubrali option mincache=closesync, i teper tnsping prohodit za 10 ms. Spasibo vsem za vnimanije!!! ))) ))) Vo blin!!! Meloch, a gora s plech!!!! ) ... |
| 08.05.2003, 11:26 |
start [/forum/topic.php?desktop=1&fid=52&tid=1990671]: |
191ms |
55ms |
| others: | 209ms |
| total: | 505ms |
