Форумы / Oracle [игнор отключен] [закрыт для гостей] / Утсановка Oracle на RedHat
25 сообщений из 25, страница 1 из 1
    #38097394
Kostya9
Всем, привет!
Ошибка при установке Oracle 11 на RedHat, подскажите куда копать?
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
Starting Oracle Universal Installer...
Checking Temp space: must be greater than 120 MB.   Actual 62258 MB    Passed
Checking swap space: must be greater than 150 MB.   Actual 5951 MB    Passed
Checking monitor: must be configured to display at least 256 colors
    >>> Could not execute auto check for display colors using command /usr/bin/xdpyinfo. Check if the DISPLAY variable is set.    Failed <<<<
Some requirement checks failed. You must fulfill these requirements before
continuing with the installation,
Continue? (y/n) [n] y
>>> Ignoring required pre-requisite failures. Continuing...
Preparing to launch Oracle Universal Installer from /tmp/OraInstall2012-12-29_05-07-35PM. Please wait ...[oracle@VCS-SR01 database]$ _X11TransSocketINETConnect() can't get address for +127.0.0.1:6000: Name or service not known
Exception in thread "main" java.lang.NoClassDefFoundError
        at java.lang.Class.forName0(Native Method)
        at java.lang.Class.forName(Class.java:164)
        at java.awt.Toolkit$2.run(Toolkit.java:821)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.awt.Toolkit.getDefaultToolkit(Toolkit.java:804)
        at com.jgoodies.looks.LookUtils.isLowResolution(LookUtils.java:484)
        at com.jgoodies.looks.LookUtils.<clinit>(LookUtils.java:249)
        at com.jgoodies.looks.plastic.PlasticLookAndFeel.<clinit>(PlasticLookAndFeel.java:135)
        at java.lang.Class.forName(Class.java:242)
        at javax.swing.SwingUtilities.loadSystemClass(SwingUtilities.java:1779)
        at javax.swing.UIManager.setLookAndFeel(UIManager.java:453)
        at oracle.install.commons.util.Application.startup(Application.java:759)
        at oracle.install.commons.flow.FlowApplication.startup(FlowApplication.java:165)
        at oracle.install.commons.flow.FlowApplication.startup(FlowApplication.java:182)
        at oracle.install.commons.base.driver.common.Installer.startup(Installer.java:308)
        at oracle.install.ivw.db.driver.DBInstaller.startup(DBInstaller.java:121)
        at oracle.install.ivw.db.driver.DBInstaller.main(DBInstaller.java:152)
    #38097404
Kostya9
Вот немного поигрался, теперь др. сообщение:
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
[oracle@VCS-SR01 database]$ ./runInstall
-bash: ./runInstall: No such file or directory
[oracle@VCS-SR01 database]$ ./runInstaller
Checking Temp space: must be greater than 120 MB.   Actual 61844 MB    Passed
Preparing to launch Oracle Universal Installer from /tmp/OraInstall2012-12-29_05-28-44PM. Please wait ...[oracle@VCS-SR01 database]$ Exception in thread "main" java.lang.NoClassDefFoundError
    #38097427
Kostya9
Прошу помочь, в Linux я не силен еще пока, вот и прошу у Вас совета.
Заранее спасибо!
    #38097460
bdmalex
Я бы для начала выставил переменную окружения DISPLAY корректно,
а уже только после этого запускал инсталлятор..
    #38097473
s_v_a
Kostya9,
Инсталлятор графический . Вы его как запускаете?
    #38097850
BadRobot
А действительно, есть ли графика на сервере, и, в графике вы запускаете инсталлятор?
Между делом: Для того, чтобы на xpdyinfo не ругался, нужно поставить пакет x11-xorg-utils кажись
Обычно я ставлю на админскую машину (обычно виндовую) икс-сервер x-ming и через putty подключаюсь к серверу (в putty галочку ставить x11-forwarding) и весь графический поток редиректится на x-ming. Если на сервере есть иксы, то конечно, можно без этого запускать инсталлятор оракла.
    #38100623
Kostya9
BadRobot , s_v_a и bdmalex , доброго времени суток! И конечно же, С НАСТУПИВШИМ НОВЫМ 2013 ГОДОМ!!! ;)))
На сервере нет графики! И т.к. я только начинающий Linux-овод ;) и требуется оперативная установка Oracle DB, прошу помощи и дать необходимую информацию, где копать и по изучать в последующем!
Сейчас прошу с координировать мои действия! Как корректно выставить переменную окружения DISPLAY? Как запустить далее инсталлятор? И ссылочки по изучению администрированию Oracle. Буду очень при очень признателен!
Вообще начинал производить установку по данной инструкции . После выставления переменных, при запуске инсталляции и возникли проблемы, описанные мною выше!
Заранее благодарен за ответы!
    #38100712
jan2ary
Kostya9,
Kostya9прошу помощи и дать необходимую информацию, где копать и по изучать в последующем!
Oracle Database Installation Guide 11g Release 2 (11.2) for Linux
    #38101403
Kostya9,
runInstaller -silent
    #38104431
Kostya9
Всем спасибо, разобрался! Проблема была в некоректной настройке X-Ming и да, в переменной DISPLASY.
    #38104439
Kostya9
Теперь возникла другая проблема, пытаюсь соединиться клиентом с БД.
БД создал, пользователя создал, под ним в sqlplus соединение проходит все нормально. Пытаюсь прикрутить Jira к данной БД по порту 1521. Без результатно (см. screen.jpg).
Что можете посоветовать? У меня подозрения, что данный порт закрыт, но почему sqlplus соединился тогда?
    #38104460
вапвапв
Kostya9,
ну так отключи фаервол.
    #38104466
Kostya Ilyinov
вапвапв,
Так сервер же локальный судя по скриншоту. Костян, а точно сервер БД на том же сервере что и джира? Если нет, то исправь это и как советуют, посмотри не блокирует ли фаервол.
    #38104473
Kostya9
Kostya Ilyinov, firewall отключен. Jira и Oracle на одном сервере, т.к. на сервере нет графики, конфигурирую jira со своего браузера. Поэтому и указываю localhost.
    #38104586
Фотография pravednik
Kostya9,
А бд с листенером хоть создали?
    #38104958
Kostya9
pravednik, да, конечно!
Уже разобрался! Проблемы с маршрутизатором были! Резал!
    #38105073
Kostya9
Подскажите, пожалуйста, как посмотреть кодировку БД? Нужна UTF-8, боюсь, что не то!
При заведении пользователя в Jira русскими буквами отображается "??????"
    #38105109
Kostya9Нужна UTF-8, боюсь, что не то!
Код: plsql
1.
select * from nls_database_parameters;
Kostya9При заведении пользователя в Jira русскими буквами отображается "??????"
кодировка клиента ?
    #38105127
Kostya9
pravednik, клиент браузер.
    #38105135
Kostya9
Вот что выдала команда:
Код: sql
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
PARAMETER                      VALUE
NLS_LANGUAGE                   AMERICAN
NLS_TERRITORY                  AMERICA
NLS_CURRENCY                   $
NLS_ISO_CURRENCY               AMERICA
NLS_NUMERIC_CHARACTERS         .,
NLS_CHARACTERSET               WE8MSWIN1252
NLS_CALENDAR                   GREGORIAN
NLS_DATE_FORMAT                DD-MON-RR
NLS_DATE_LANGUAGE              AMERICAN
NLS_SORT                       BINARY
NLS_TIME_FORMAT                HH.MI.SSXFF AM
PARAMETER                      VALUE
NLS_TIMESTAMP_FORMAT           DD-MON-RR HH.MI.SSXFF AM
NLS_TIME_TZ_FORMAT             HH.MI.SSXFF AM TZR
NLS_TIMESTAMP_TZ_FORMAT        DD-MON-RR HH.MI.SSXFF AM TZR
NLS_DUAL_CURRENCY              $
NLS_COMP                       BINARY
NLS_LENGTH_SEMANTICS           BYTE
NLS_NCHAR_CONV_EXCP            FALSE
NLS_NCHAR_CHARACTERSET         AL16UTF16
NLS_RDBMS_VERSION              11.2.0.2.0
20 rows selected.
Я так понимаю, что
Код: sql
1.
должнобыть UTF-8???
    #38105143
Kostya9
Kostya9Я так понимаю, что
Код: sql
1.
должнобыть UTF-8???
Можно ли изменить кодировку не пересоздавая БД?
    #38105166
Kostya9должнобыть UTF-8???
Ну не обязательно UTF-8, просто в W estern E urope 8MSWIN1252 просто ничего не знают о кирилице
    #38105170
Kostya9Kostya9Я так понимаю, что
Код: sql
\r\nNLS_CHARACTERSET               WE8MSWIN1252\r\n
\r\n
должнобыть UTF-8???
Лучше не стоит
    #38105608
Timofej
    #38105657
Kostya9
В общем пересоздал БД и все! Сейчас все отлично пока!
Всем большое спасибо за советы и помощь!!!
