как собрать статистику на external table c ORACLE_DATAPUMP ?
подскажите как собрать статистику Код: plsql 1. 2. 3. 4. 5. 6. 7. 8. таблица создана так Код: plsql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. ... |
| 19.09.2016, 09:42:28 |
joiner_plus, KUP-04084: The ORACLE_DATAPUMP access driver does not support the ROWID column. Cause: A query of an external table of type ORACLE_DATAPUMP tried to reference the ROWID column. The ORACLE_DATAPUMP access driver does not support ROWIDs. Action: Remove the ROWID from the query. If that is not possible, create a table in the database with the same columns as the external table, copy the data from the external table into the newly created table, and use that new table for the query. ... |
| 19.09.2016, 22:22:39 |
start [/forum/topic.php?desktop=1&fid=52&tid=1887431]: |
76ms |
42ms |
| others: | 234ms |
| total: | 411ms |
