ORA-12154: TNS:could not resolve the connect identifier specified
Всем привет! Перерыл интернеты. Не врубаюсь, что не так, девелопер не видит базы. PL\SQL Developer 32 битный, клиент поставил 32 битный. service name проверил, все как надо. Переменную окружения TNS_ADMIN добавил. В девелопере указал home и oci.dll. Внизу привожу listener.ora и tnsnames.ora. P.S. Oracle Database 12c Enterprise Edition Release 12.1.0.2.0 - 64bit Oracle Client 12.1.0.2.0 32 bit listener: SID_LIST_LISTENER = (SID_LIST = (SID_DESC = (SID_NAME = CLRExtProc) (ORACLE_HOME = E:\app\israel\product\12.1.0\dbhome_1) (PROGRAM = extproc) (ENVS = "EXTPROC_DLLS=ONLY:E:\app\israel\product\12.1.0\dbhome_1\bin\oraclr12.dll") ) ) LISTENER = (DESCRIPTION_LIST = (DESCRIPTION = (ADDRESS = (PROTOCOL = TCP)(HOST = localhost)(PORT = 1521)) (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC1521)) ) ) TNSNAMES: LISTENER_ORCL = (ADDRESS = (PROTOCOL = TCP)(HOST = localhost)(PORT = 1521)) ORACLR_CONNECTION_DATA = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC1521)) ) (CONNECT_DATA = (SID = CLRExtProc) (PRESENTATION = RO) ) ) ORCL = (DESCRIPTION = (ADDRESS = (PROTOCOL = TCP)(HOST = localhost)(PORT = 1521)) (CONNECT_DATA = (SERVER = DEDICATED) (SERVICE_NAME = orcl) ) ) ... |
| 20.09.2016, 11:21:07 |
lsnrctl services? ... |
| 20.09.2016, 11:24:25 |
| 20.09.2016, 11:27:04 |
CrazyCat, E:\app\israel\product\12.1.0\dbhome_1\BIN>lsnrctl services LSNRCTL for 64-bit Windows: Version 12.1.0.2.0 - Production on 20-SEP-20 :24 Copyright (c) 1991, 2014, Oracle. All rights reserved. Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=localhost)(PORT= Services Summary... Service "CLRExtProc" has 1 instance(s). Instance "CLRExtProc", status UNKNOWN, has 1 handler(s) for this servi Handler(s): "DEDICATED" established:0 refused:0 LOCAL SERVER Service "orcl" has 1 instance(s). Instance "orcl", status READY, has 1 handler(s) for this service... Handler(s): "DEDICATED" established:1 refused:0 state:ready LOCAL SERVER Service "orclXDB" has 1 instance(s). Instance "orcl", status READY, has 1 handler(s) for this service... Handler(s): "D000" established:0 refused:0 current:0 max:1022 state:ready DISPATCHER <machine: ISRAELSHAMIR, pid: 1164> (ADDRESS=(PROTOCOL=tcp)(HOST=israelshamir)(PORT=49168)) The command completed successfully ... |
| 20.09.2016, 11:55:16 |
K790, прописал вместо localhost свой ip - не помогло ... |
| 20.09.2016, 12:00:40 |
| 20.09.2016, 12:30:59 |
israelshamir, куда прописали и что есть "свой ip" ? ... |
| 20.09.2016, 12:44:30 |
israelshamirK790, прописал вместо localhost свой ip - не помогло я правильно понимаю - что все это делаете в пределах одного хоста? т.е. и сервер и клиент - один хост... ... |
| 20.09.2016, 12:53:47 |
CrazyCatну и как подключаемся? пробовал tnsping orcl sqlplus user/pass@orcl? вот это все и еще посмотреть содержимое sqlnet.ora ... |
| 20.09.2016, 13:30:44 |
CrazyCat, да, sqlplus цепляется нормально, коннекчусь так israel/ilikemilk22@orcl as sysdba. результат tnsping orcl: C:\Users\israel_shamir>tnsping orcl TNS Ping Utility for 64-bit Windows: Version 12.1.0.2.0 - Production on 20-SEP-2 016 18:32:15 Copyright (c) 1997, 2014, Oracle. All rights reserved. Used parameter files: E:\app\israel\product\12.1.0\dbhome_1\network\admin\sqlnet.ora Used TNSNAMES adapter to resolve the alias Attempting to contact (DESCRIPTION = (ADDRESS = (PROTOCOL = TCP)(HOST = 192.168. 251.101)(PORT = 1521)) (CONNECT_DATA = (SERVER = DEDICATED) (SERVICE_NAME = orcl ))) TNS-12541: TNS:no listener C:\Users\israel_shamir> ... |
| 20.09.2016, 18:39:50 |
CrazyCat, да, все делаю в пределах одного хоста. инстанс и девелопер на одном компе стоят ... |
| 20.09.2016, 18:41:04 |
K790, ipconfig'ом посмотрел ip хоста на котором стоят и экземпляр и девелопер. и в listener.ora и в tnsnames.ora вместо localhost прописал полученный ip ... |
| 20.09.2016, 18:43:25 |
Rinka777, вот так выглядит sqlnet: # sqlnet.ora Network Configuration File: E:\app\israel\product\12.1.0\dbhome_1\network\admin\sqlnet.ora # Generated by Oracle configuration tools. # This file is actually generated by netca. But if customers choose to # install "Software Only", this file wont exist and without the native # authentication, they will not be able to connect to the database on NT. SQLNET.AUTHENTICATION_SERVICES= (NTS) NAMES.DIRECTORY_PATH= (TNSNAMES, EZCONNECT) ... |
| 20.09.2016, 18:45:32 |
israelshamir(ADDRESS = (PROTOCOL = TCP)(HOST = localhost)(PORT = 1521)) israelshamir(HOST = 192.168.251.101) где то ты нас обманываешь! откуда тут 192.168...? 127.0.0.1 - это локалхост. уж разберись там! tnsping написал откуда берет файлы параметров. ... |
| 20.09.2016, 19:38:07 |
CrazyCat, сделал все по новой, как здесь описано http://sergdankov.blogspot.ru/2012/05/oracle-instant-client.html теперь девелопер видит базу, но не получается залогиниться - пишет: ORA-01017: invalid username/password; logon denied в sqlplus коннекчусь без проблем под той же учеткой ... |
| 20.09.2016, 21:28:56 |
CrazyCat, ip, кстати, заменил обратно на localhost в listener и tnsnames ... |
| 20.09.2016, 21:30:05 |
CrazyCat, результат tnsping orcl теперь такой: E:\app\israel\product\12.1.0\dbhome_1\BIN>tnsping orcl TNS Ping Utility for 64-bit Windows: Version 12.1.0.2.0 - Production on 20-╤┼═-2 016 21:33:40 Copyright (c) 1997, 2014, Oracle. All rights reserved. Used parameter files: E:\app\israel\product\12.1.0\dbhome_1\network\admin\sqlnet.ora Used TNSNAMES adapter to resolve the alias Attempting to contact (DESCRIPTION = (ADDRESS = (PROTOCOL = TCP)(HOST = localhos t)(PORT = 1521)) (CONNECT_DATA = (SERVER = DEDICATED) (SERVICE_NAME = orcl))) OK (20 msec) E:\app\israel\product\12.1.0\dbhome_1\BIN> ... |
| 20.09.2016, 21:34:34 |
israelshamirтеперь девелопер видит базу, но не получается залогиниться - пишет: ORA-01017: invalid username/password; logon denied 32bit клиент тоже 12c? и не забываешь "as sysdba" в девелопере указать? сейчас в эту сторону смотри, настройки лисенера не трогай уже. ... |
| 20.09.2016, 21:35:06 |
CrazyCat, да, клиент тоже 12c 32bit. as sysdba не забываю. ... |
| 20.09.2016, 21:47:30 |
CrazyCat, разобрался благодаря этой статье https://www.experts-exchange.com/questions/27859821/Can-connect-as-sysdba-using-sqlplus-but-not-sql-developer-ORA-01017.html я не знал, что есть такой нюанс! А можете носом ткнуть, что почитать, чтобы также разбираться в этом(в архитектуре - как клиент коннектится и почему случился какой либо факап) как вы? ... |
| 21.09.2016, 07:05:06 |
start [/forum/topic.php?desktop=1&fid=52&tid=1887420]: |
191ms |
56ms |
| others: | 203ms |
| total: | 494ms |
