Установка Oracle Enterprise Manager Cloud Control 13.2 на Oracle Linux 7
При попытке запустить инсталлятор em 13.2, вываливается ошибка: unzipsfx: cannot find myself![oracle@emcc13 emcc132]$ ./em13200_linux64.bin 0%.....unzipsfx: cannot find myself! [/home/oracle/Downloads/emcc132/em13200_linux64-2.zip] Failed to extract disk 2 (rc 9) unzipsfx: cannot find myself! [/home/oracle/Downloads/emcc132/em13200_linux64-3.zip] Failed to extract disk 3 (rc 9) unzipsfx: cannot find myself! [/home/oracle/Downloads/emcc132/em13200_linux64-4.zip] Failed to extract disk 4 (rc 9) unzipsfx: cannot find myself! [/home/oracle/Downloads/emcc132/em13200_linux64-5.zip] Failed to extract disk 5 (rc 9) unzipsfx: cannot find myself! [/home/oracle/Downloads/emcc132/em13200_linux64-6.zip] Failed to extract disk 6 (rc 9) 100% ** Failed to extract files from /home/oracle/Downloads/emcc132/em13200_linux64-6.zip; error code = 9. [oracle@emcc13 emcc132]$ На официальном сайте написано: unzipsfx has no knowledge of the user's PATH, so in general an archive must either be in the current directory when it is invoked, or else a full or relative path must be given. If a user attempts to extract the archive from a directory in the PATH other than the current one, unzipsfx will print a warning to the effect, «can't find myself.» Я уже скопировал unzipsfx в папку с дистрибутивом EM, но все равно не работает. Подскажите, как решить данную проблему? ... |
| 15.11.2016, 15:56 |
start [/forum/topic.php?desktop=1&fid=52&tid=1887012]: |
41ms |
28ms |
| others: | 245ms |
| total: | 358ms |
