Не стартует node2 после установки. 2-х нодовый кластер
Доброго времени суток. Помогите в решении проблемы - не стартует вторая нода на двухнодовом кластере после установки, все шаги установки прошли без ошибок (Установка Грида, СУБД Оракл, создание БД) в алерт логе ошибок не наблюдаю. Запуск кластера со 2-й ноды (srvctl start database -d CLUSTER) все равно запускает ноду 1. Установку производил на VMware Workstation 11 OS - SunOS 5.11 СУБД - Oracle 11.2.0.4 Команда srvctl status: oracle@cluster-rac1:~$ srvctl status database -d CLUSTER Instance CLUSTER1 is running on node cluster-rac1 grid@cluster-rac1:/u01/app/oracle/product/11.2.0/grid/bin$ crsctl query crs activeversion Oracle Clusterware active version on the cluster is [11.2.0.4.0] grid@cluster-rac1:/u01/app/oracle/product/11.2.0/grid/bin$ crsctl query crs activeversion Oracle Clusterware active version on the cluster is [11.2.0.4.0] grid@cluster-rac1:/u01/app/oracle/product/11.2.0/grid/bin$ crsctl query css votedisk ## STATE File Universal Id File Name Disk group -- ----- ----------------- --------- --------- 1. ONLINE 85abb79110204fd9bf9b136771ea75ea (/dev/rdsk/c3t0d0) [DATA] Located 1 voting disk(s). grid@cluster-rac1:/u01/app/oracle/product/11.2.0/grid/bin$ crsctl check crs CRS-4638: Oracle High Availability Services is online CRS-4537: Cluster Ready Services is online CRS-4529: Cluster Synchronization Services is online CRS-4533: Event Manager is online grid@cluster-rac1:/u01/app/oracle/product/11.2.0/grid/bin$ ./srvctl status nodeapps VIP cluster-rac1-vip is enabled VIP cluster-rac1-vip is running on node: cluster-rac1 VIP cluster-rac2-vip is enabled VIP cluster-rac2-vip is running on node: cluster-rac2 Network is enabled Network is running on node: cluster-rac1 Network is running on node: cluster-rac2 GSD is disabled GSD is not running on node: cluster-rac1 GSD is not running on node: cluster-rac2 ONS is enabled ONS daemon is running on node: cluster-rac1 ONS daemon is running on node: cluster-rac2 grid@cluster-rac1:/u01/app/oracle/product/11.2.0/grid/bin$ ./crsctl check cluster -all ************************************************************** cluster-rac1: CRS-4537: Cluster Ready Services is online CRS-4529: Cluster Synchronization Services is online CRS-4533: Event Manager is online ************************************************************** cluster-rac2: CRS-4537: Cluster Ready Services is online CRS-4529: Cluster Synchronization Services is online CRS-4533: Event Manager is online ************************************************************** grid@cluster-rac1:/u01/app/oracle/product/11.2.0/grid/bin$ ./crsctl status resource -t -------------------------------------------------------------------------------- NAME TARGET STATE SERVER STATE_DETAILS -------------------------------------------------------------------------------- Local Resources -------------------------------------------------------------------------------- ora.DATA.dg ONLINE ONLINE cluster-rac1 ONLINE ONLINE cluster-rac2 ora.LISTENER.lsnr ONLINE ONLINE cluster-rac1 ONLINE ONLINE cluster-rac2 ora.asm ONLINE ONLINE cluster-rac1 Started ONLINE ONLINE cluster-rac2 Started ora.gsd OFFLINE OFFLINE cluster-rac1 OFFLINE OFFLINE cluster-rac2 ora.net1.network ONLINE ONLINE cluster-rac1 ONLINE ONLINE cluster-rac2 ora.ons ONLINE ONLINE cluster-rac1 ONLINE ONLINE cluster-rac2 ora.registry.acfs ONLINE ONLINE cluster-rac1 ONLINE ONLINE cluster-rac2 -------------------------------------------------------------------------------- Cluster Resources -------------------------------------------------------------------------------- ora.LISTENER_SCAN1.lsnr 1 ONLINE ONLINE cluster-rac2 ora.LISTENER_SCAN2.lsnr 1 ONLINE ONLINE cluster-rac1 ora.LISTENER_SCAN3.lsnr 1 ONLINE ONLINE cluster-rac1 ora.cluster-rac1.vip 1 ONLINE ONLINE cluster-rac1 ora.cluster-rac2.vip 1 ONLINE ONLINE cluster-rac2 ora.cluster.db 1 ONLINE ONLINE cluster-rac1 Open ora.cvu 1 ONLINE ONLINE cluster-rac1 ora.oc4j 1 ONLINE ONLINE cluster-rac1 ora.scan1.vip 1 ONLINE ONLINE cluster-rac2 ora.scan2.vip 1 ONLINE ONLINE cluster-rac1 ora.scan3.vip 1 ONLINE ONLINE cluster-rac1 grid@cluster-rac1:/u01/app/oracle/product/11.2.0/grid/bin$ asmcmd lsdsk Path /dev/rdsk/c3t0d0 Подскажите куда копать, что допилить? Во вложении архив cluster с файликами листенера, тнснаймз с обеих нод ... |
| 21.12.2016, 15:06 |
andrewirn, У вас в кластере зарегистрирован только один инстанс: oracle@cluster-rac1:~$ srvctl status database -d CLUSTER Instance CLUSTER1 is running on node cluster-rac1 ... -------------------------------------------------------------------------------- Cluster Resources -------------------------------------------------------------------------------- 1 ONLINE ONLINE cluster-rac2 ora.cluster.db Добавьте второй через srvctl add instance: https://docs.oracle.com/cd/E11882_01/rac.112/e41960/srvctladmin.htm#i1008526 Вообще, конечно, хотелось бы глянуть как устанавливались GI и БД. ... |
| 21.12.2016, 15:45 |
Скорее всего причина в том, что когда создавалась база была выбрана только одна нода (по умолчанию стоит одна), для установки на две ноды необходимо их выбрать вручную или щелкнуть "выбрать все". Для решения "проблемы" добавьте инстанс на вторую ноду командой из предыдущего сообщения. ... |
| 22.12.2016, 12:08 |
дж, Taciturn12 Огромное спаисбо за советы, сделал как вы советовали все запустилось. Очень благодарен вам. Добавлю еще пару шагов в дополнение, для тех у кого возможно будет похожая проблема: 1. Так же добавил redo logs for thread 2 alter database add logfile thread 2 group 5 ('+DATA/cluster/onlinelog/log_name.log') size 50M; 2. Enable redo alter database enable public thread 2; ... |
| 22.12.2016, 12:47 |
Добый день Taciturn12, дж Подскажите плиз действенное решение или если имеется скиньте полезную ссылку (я их перелопатил множество в нете, все бесполезно) по вопросу того, что после ребута одного из 2-х серверов, нода на этом сервере не стартует: С ноды1: oracle@cluster-rac1:$ ./crsctl status resource -t -------------------------------------------------------------------------------- NAME TARGET STATE SERVER STATE_DETAILS -------------------------------------------------------------------------------- Local Resources -------------------------------------------------------------------------------- ora.DATA.dg ONLINE ONLINE cluster-rac1 ora.LISTENER.lsnr ONLINE ONLINE cluster-rac1 ora.asm ONLINE ONLINE cluster-rac1 Started ora.gsd OFFLINE OFFLINE cluster-rac1 ora.net1.network ONLINE ONLINE cluster-rac1 ora.ons ONLINE ONLINE cluster-rac1 ora.registry.acfs ONLINE ONLINE cluster-rac1 -------------------------------------------------------------------------------- Cluster Resources -------------------------------------------------------------------------------- ora.LISTENER_SCAN1.lsnr 1 ONLINE ONLINE cluster-rac1 ora.LISTENER_SCAN2.lsnr 1 ONLINE ONLINE cluster-rac1 ora.LISTENER_SCAN3.lsnr 1 ONLINE ONLINE cluster-rac1 ora.cluster-rac1.vip 1 ONLINE ONLINE cluster-rac1 ora.cluster-rac2.vip 1 ONLINE INTERMEDIATE cluster-rac1 FAILED OVER ora.cluster.db 1 ONLINE ONLINE cluster-rac1 Open 2 ONLINE OFFLINE ora.cvu 1 ONLINE ONLINE cluster-rac1 ora.oc4j 1 ONLINE ONLINE cluster-rac1 ora.scan1.vip 1 ONLINE ONLINE cluster-rac1 ora.scan2.vip 1 ONLINE ONLINE cluster-rac1 ora.scan3.vip 1 ONLINE ONLINE cluster-rac1 С ноды: root@cluster-rac2:# ./crsctl start crs CRS-4124: Oracle High Availability Services startup failed. CRS-4000: Command Start failed, or completed with errors. ... |
| 11.01.2017, 12:56 |
andrewirn, для ленивых сначала проверим srvctl status inst –d CLUSTER -i CLUSTER1 если нету то: srvctl add instance -d CLUSTER -i CLUSTER1 -n cluster-rac1 ... |
| 11.01.2017, 15:49 |
сорян сначала проверим srvctl status inst –d CLUSTER -i CLUSTER2 если нету то: srvctl add instance -d CLUSTER -i CLUSTER2 -n cluster-rac2 ... |
| 11.01.2017, 15:51 |
Тролинсорян сначала проверим srvctl status inst –d CLUSTER -i CLUSTER2 если нету то: srvctl add instance -d CLUSTER -i CLUSTER2 -n cluster-rac2 Не в тему. ... |
| 11.01.2017, 17:59 |
andrewirn, Ищи ohasd.trc и смотри в него. Обычно он в $ORACLE_BASE/diag/crs/<host>/crs/trace Там же alert.log, можешь и его глянуть. ... |
| 11.01.2017, 18:06 |
Тролин, Спасибо за совет, но я это уже проделал все заработало отлично. Свою ошибку я понял. Но на этот раз после ребута сервера (незапланированного) тот инстанс который крутился на этот сервере не поднимается: oracle@cluster-rac1:~$ srvctl status database -d CLUSTER Instance CLUSTER1 is running on node cluster-rac1 Instance CLUSTER2 is not running on node cluster-rac2 ... |
| 12.01.2017, 08:45 |
andrewirn, еще нужно сделать srvctl enable instance -d CLUSTER -i CLUSTER2 должен заработать автоматический запуск ... |
| 12.01.2017, 18:10 |
andrewirn, но после enable прийдется все же сделать start этому instance ... |
| 12.01.2017, 18:11 |
У автора CRS не стратует, до srvctl дело не доходит даже ... |
| 12.01.2017, 18:18 |
постит труизмы,как определил? Телепат? ... |
| 12.01.2017, 18:57 |
Тролинпостит труизмы,как определил? Телепат? Дебил что ли ? root@cluster-rac2:# ./crsctl start crs CRS-4124: Oracle High Availability Services startup failed. CRS-4000: Command Start failed, or completed with errors. ora.cluster-rac2.vip 1 ONLINE INTERMEDIATE cluster-rac1 FAILED OVER У него кластерварь не стартует, а ты со своими инстансами лезешь. ... |
| 12.01.2017, 21:13 |
andrewirn, Я так понимаю логи ты так и не посмотрел ? Причину не видишь ? Тогда смотри доступность и права доступа к shared-дискам, это самая распространенная проблема. Посмотри что там на втором узле (скорее всего это всё даст ошибку): crsctl check has crsctl stat res -t -init crsctl query css votedisk ocrcheck Ну и если между командой root@cluster-rac2:# ./crsctl start crs и ошибкой CRS-4124: Oracle High Availability Services startup failed. Проходит достаточно много времени (ну минуты две), то скажи. Есть там прикольный баг, который обходится не менее прикольным способом. ... |
| 12.01.2017, 21:27 |
crsctl, не увидел в последнем сообщении что у него проблема с crs.... ... |
| 12.01.2017, 21:53 |
crsctl, Большое спасибо за советы!!! В итоге после череды команд у меня вооще перестала грузиться солярка на второй проблемной ноде, поэтому и логи не глянул. Пока пытаюсь привести в чувства операционку. Как решу вопрос с ней обязательно отпишусь по результатам. Если ничего не поулчится откачусь до момента начала установки грида (благо есть спапшот) установлю все по новой, снова ребутну и гляну что там. На все дня 3 думаю. ... |
| 13.01.2017, 08:13 |
crsctl, Добрый день! Переустановил все заново. Все рабатает пока. oracle@cluster-rac1:~$ srvctl status database -d CLUSTER -v Instance CLUSTER1 is running on node cluster-rac1. Instance status: Open. Instance CLUSTER2 is running on node cluster-rac2. Instance status: Open. SQL> select INSTANCE_NAME,HOST_NAME,VERSION,STARTUP_TIME,STATUS,ACTIVE_STATE,INSTANCE_ROLE,DATABASE_STATUS from gv$INSTANCE; INSTANCE_NAME HOST_NAME VERSION STARTUP_TIME STATUS ACTIVE_ST INSTANCE_ROLE DBASE_STATUS ---------------- ----------- ----------------- ------------------- ------------ --------- ------------------ ----------------- CLUSTER1 cluster-rac1.test.com 11.2.0.4.0 2017-01-18 04:39:24 OPEN NORMAL PRIMARY_INSTANCE ACTIVE CLUSTER2 cluster-rac2.test.com 11.2.0.4.0 2017-01-18 04:40:05 OPEN NORMAL PRIMARY_INSTANCE ACTIVE Подскажите плиз работают ли рекомендации данные в этом посте чтоб избежать проблемы с которой я столкнулся после непредвиденного ребута сервака? (How to set auto start resources in 11G RAC) https://oracleracdba1.wordpress.com/2013/01/29/how-to-set-auto-start-resources-in-11g-rac/ У меня: oracle@cluster-rac1:$ crsctl stat res -p NAME=ora.DATA.dg TYPE=ora.diskgroup.type AUTO_START=never NAME=ora.LISTENER.lsnr AUTO_START=restore NAME=ora.asm AUTO_START=never NAME=ora.cluster.db AUTO_START=restore NAME=ora.cvu AUTO_START=restore NAME=ora.gsd AUTO_START=always NAME=ora.scan1.vip AUTO_START=restore Я правильно понимаю что знание "restore" так же стоит установить в "always"? ... |
| 18.01.2017, 14:29 |
crsctl, т.е. после изменения вышеприведенных параметров, а так же при условии: root@cluster-rac1:# ./crsctl config has CRS-4622: Oracle High Availability Services autostart is enabled. root@cluster-rac1:# ./crsctl config crs CRS-4622: Oracle High Availability Services autostart is enabled. Можно смело тушить серваки и снимать снапшоты? ... |
| 18.01.2017, 15:36 |
start [/forum/topic.php?desktop=1&fid=52&tid=1886415]: |
171ms |
50ms |
| others: | 205ms |
| total: | 456ms |
