RMAN-06054: При восстановлении полного бекапа на новый сервак
При восстановлении полного бекапа на новый сервак w2012 оракле 11.2.0.4 без установки базы, все прошло гладко. Только RMAN> recover database; Starting recover at 18-AUG-17 using channel ORA_DISK_1 starting media recovery channel ORA_DISK_1: starting archived log restore to default destination channel ORA_DISK_1: restoring archived log archived log thread=1 sequence=18131 channel ORA_DISK_1: restoring archived log archived log thread=1 sequence=18132 channel ORA_DISK_1: restoring archived log archived log thread=1 sequence=18133 channel ORA_DISK_1: restoring archived log archived log thread=1 sequence=18134 channel ORA_DISK_1: reading from backup piece C:\BACKUP\DB_20170817_SBSC4HA7_1_1_ALL.BKA channel ORA_DISK_1: piece handle=C:\BACKUP\DB_20170817_SBSC4HA7_1_1_ALL.BKA tag=TAG20170817T113015 channel ORA_DISK_1: restored backup piece 1 channel ORA_DISK_1: restore complete, elapsed time: 00:00:03 archived log file name=C:\ORACLEDB\ADMIN\PRODUCT\11.2.0\DBHOME_1\RDBMS\ARC0000018131_0891725177.0001 thread=1 sequence=18131 archived log file name=C:\ORACLEDB\ADMIN\PRODUCT\11.2.0\DBHOME_1\RDBMS\ARC0000018132_0891725177.0001 thread=1 sequence=18132 archived log file name=C:\ORACLEDB\ADMIN\PRODUCT\11.2.0\DBHOME_1\RDBMS\ARC0000018133_0891725177.0001 thread=1 sequence=18133 archived log file name=C:\ORACLEDB\ADMIN\PRODUCT\11.2.0\DBHOME_1\RDBMS\ARC0000018134_0891725177.0001 thread=1 sequence=18134 unable to find archived log archived log thread=1 sequence=18135 RMAN-00571: =========================================================== RMAN-00569: =============== ERROR MESSAGE STACK FOLLOWS =============== RMAN-00571: =========================================================== RMAN-03002: failure of recover command at 08/18/2017 11:05:21 RMAN-06054: media recovery requesting unknown archived log for thread 1 with sequence 18135 and starting SCN of 591057359 Надо RECOVER DATABASE UNTIL SEQUENCE 18131; или RECOVER DATABASE UNTIL SEQUENCE 18135; ?? ... |
| 18.08.2017, 11:28 |
Kaa548 или RECOVER DATABASE UNTIL SEQUENCE 18135; ... |
| 18.08.2017, 11:31 |
Taciturn12, RMAN> RECOVER DATABASE UNTIL SEQUENCE 18135; Starting recover at 18-AUG-17 using channel ORA_DISK_1 starting media recovery media recovery complete, elapsed time: 00:00:01 Finished recover at 18-AUG-17 RMAN> alter database open resetlogs; RMAN-00571: =========================================================== RMAN-00569: =============== ERROR MESSAGE STACK FOLLOWS =============== RMAN-00571: =========================================================== RMAN-03002: failure of alter db command at 08/18/2017 11:44:10 ORA-01092: ORACLE instance terminated. Disconnection forced ORA-00704: bootstrap process failure ORA-39700: database must be opened with UPGRADE option Process ID: 2104 Session ID: 1 Serial number: 17 RMAN-00571: =========================================================== RMAN-00569: =============== ERROR MESSAGE STACK FOLLOWS =============== RMAN-00571: =========================================================== ORA-03114: not connected to ORACLE RMAN-00571: =========================================================== RMAN-00569: =============== ERROR MESSAGE STACK FOLLOWS =============== RMAN-00571: =========================================================== RMAN-03002: failure of alter db command at 08/18/2017 11:44:10 ORA-01092: ORACLE instance terminated. Disconnection forced ORA-00704: bootstrap process failure ORA-39700: database must be opened with UPGRADE option Process ID: 2104 Session ID: 1 Serial number: 17 SQL> Во как, какие есть предложения? ... |
| 18.08.2017, 11:45 |
Kaa548, Насколько я помню, исходный backup у тебя 11.2.0.3 У тебя версия софта не совпадает с версией каталога в твоей базе Oracle Doc Manually Upgrading Oracle Database Тебе надо выполнить upgrade базы Если совсем упрощено: Код: plsql 1. 2. 3. 4. 5. 6. 7. ... |
| 18.08.2017, 12:00 |
При смене версии Oracle необходимо открывать базу в режиме Upgrade и выполнять процедуру апгрейда базы до новой версии (как минимум catupgrd.sql), подробности в инструкциях по апгрейду версий . ... |
| 18.08.2017, 12:01 |
Kaa548, И да, научись наконец пользоваться ТЭГАМи сооющения Выделяешь текст и используешь иконку SRC блин ... |
| 18.08.2017, 12:01 |
start [/forum/topic.php?desktop=1&fid=52&tid=1885406]: |
147ms |
47ms |
| others: | 232ms |
| total: | 465ms |
