GoldenGate Agent
Добрый день, не могу запустить GG agent, установил GG monitor и veridata, но agent не хочет запускаться. Уже пробовал разные конфиги. GGSCI (localhost.localdomain) 1> view report JAGENT *********************************************************************** Oracle GoldenGate Command Tool for Oracle Version 12.3.0.1.0 OGGCORE_12.3.0.1.0_PLATFORMS_170721.0154 Linux, x64, 64bit (optimized) on Jul 21 2017 08:04:20 Copyright (C) 1995, 2017, Oracle and/or its affiliates. All rights reserved. Starting at 2017-10-20 16:51:56 *********************************************************************** Operating System Version: Linux Version #1 SMP Tue Sep 12 22:26:13 UTC 2017, Release 3.10.0-693.2.2.el7.x86_64 Node: localhost.localdomain Machine: x86_64 soft limit hard limit Address Space Size : unlimited unlimited Heap Size : unlimited unlimited File Size : unlimited unlimited CPU Time : unlimited unlimited Process id: 24375 Parameters... COMMAND java -Dconfig.dir=/home/oracle/gg/agent/cfg -Djava.util.logging.config.class=oracle.core.ojdl.logging.Loggi ngConfiguration -Doracle.core.ojdl.logging.config.file=/home/oracle/gg/agent/cfg/logging-config.xml -Doracle.core.o jdl.logging.componentId=JAGENT -jar -Xms512m -Xmx1024m /home/oracle/Oracle/Middleware/Oracle_Home/oggmon/ogg_agent/ dirjar/jagent.jar Program is 'java', arguments are '-Dconfig.dir=/home/oracle/gg/agent/cfg -Djava.util.logging.config.class=oracle.co re.ojdl.logging.LoggingConfiguration -Doracle.core.ojdl.logging.config.file=/home/oracle/gg/agent/cfg/logging-confi g.xml -Doracle.core.ojdl.logging.componentId=JAGENT -jar -Xms512m -Xmx1024m /home/oracle/Oracle/Middleware/Oracle_H ome/oggmon/ogg_agent/dirjar/jagent.jar' *********************************************************************** ** Run Time Messages ** *********************************************************************** 2017-10-20 16:51:56 INFO OGG-00978 GGCMD JAGENT is running. 2017-10-20 16:51:56 INFO OGG-01927 Child process started, process ID 24380, command line 'java -Dconfig.dir=/h ome/oracle/gg/agent/cfg -Djava.util.logging.config.class=oracle.core.ojdl.logging.LoggingConfiguration -Doracle.cor e.ojdl.logging.config.file=/home/oracle/gg/agent/cfg/logging-config.xml -Doracle.core.ojdl.logging.componentId=JAGE NT -jar -Xms512m -Xmx1024m /home/oracle/Oracle/Middleware/Oracle_Home/oggmon/ogg_agent/dirjar/jagent.jar'. log4j:WARN No appenders could be found for logger (org.springframework.core.env.StandardEnvironment). log4j:WARN Please initialize the log4j system properly. Exception in thread "agentRegistration" com.goldengate.monitor.MonitorRuntimeException: Could not get ggs_version f rom Agent's mbean at com.goldengate.monitor.jagent.jmx.MBeansContainerImpl.getGgsVersion(MBeansContainerImpl.java:997) at com.goldengate.monitor.jagent.jmx.MBeansContainerImpl.access$200(MBeansContainerImpl.java:121) at com.goldengate.monitor.jagent.jmx.MBeansContainerImpl$2.run(MBeansContainerImpl.java:1495) at java.lang.Thread.run(Thread.java:745) Caused by: java.lang.NullPointerException at com.goldengate.monitor.jagent.jmx.MBeansContainerImpl.getGgsVersion(MBeansContainerImpl.java:995) ... 3 more Exception in thread "deleteProcess" com.goldengate.monitor.MonitorRuntimeException: Could not get ggs_version from Agent's mbean at com.goldengate.monitor.jagent.jmx.MBeansContainerImpl.getGgsVersion(MBeansContainerImpl.java:997) at com.goldengate.monitor.jagent.jmx.MBeansContainerImpl.access$200(MBeansContainerImpl.java:121) at com.goldengate.monitor.jagent.jmx.MBeansContainerImpl$3.run(MBeansContainerImpl.java:1604) at java.lang.Thread.run(Thread.java:745) Caused by: java.lang.NullPointerException at com.goldengate.monitor.jagent.jmx.MBeansContainerImpl.getGgsVersion(MBeansContainerImpl.java:995) ... 3 more ... |
| 14.11.2017, 11:25 |
start [/forum/topic.php?desktop=1&fid=52&tid=1884926]: |
69ms |
30ms |
| others: | 242ms |
| total: | 400ms |
