ora 1033 на ровном месте
Привет во такая страннота происходит : Код: plsql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. кто виноват и что делать ? ... |
| 16.11.2017, 13:43 |
Jebrail, Run, Forrest! Run! ... |
| 16.11.2017, 13:59 |
Как минимум, зри alert.log ... |
| 16.11.2017, 15:03 |
Ловил что-то похожее при некорректно переданных параметрах в DBMS_SCHEDULER ... |
| 16.11.2017, 19:24 |
Jebrail, DBMS_SCHEDULER.SET_SCHEDULER_ATTRIBUTE Failing With ORA-01033. (Doc ID 756740.1) ... |
| 16.11.2017, 21:59 |
Jebrail, оттуда же Please note that the usage of DBMS_SCHEDULER.SET_SCHEDULER_ATTRIBUTE('SCHEDULER_DISABLED', ... ) is currently undocumented and thus is not a supported scheduler attribute. The usage of this parameter can produce inconsistent results or even errors in some cases. Researching the Oracle Documentation, there's no supported way to completely disable the Scheduler. However, the Scheduler does not run if the database is started in UPGRADE Mode, so this can be used as a workaround sometimes. If the above parameter is to be used, then it should be only done with guidance from Oracle Support. ... |
| 16.11.2017, 22:01 |
[quot orac_list, there's no supported way to completely disable the Scheduler. [/quot] а мне и не надо . ... |
| 17.11.2017, 15:31 |
start [/forum/topic.php?desktop=1&fid=52&tid=1884901]: |
28ms |
27ms |
| others: | 190ms |
| total: | 271ms |
