Нужна помощь, подскажите
Есть 3 набора данных (на самом деле их значительно больше) нужно для набора RE1 сформировать запись входящие из других наборов по диапазону WITH RE1 as ( select '10' as id,to_date('05.05.2017', 'dd.mm.yyyy') as DP, '1' as TOO, '0' as FRO, '174' as V, '100' as N FROM dual union all select '11' as id, to_date('06.07.2017', 'dd.mm.yyyy') as DP, '1' as TOO, '0' as FRO, '174' as V, '100' as N FROM dual union all select '12' as id, to_date('08.09.2017', 'dd.mm.yyyy') as DP, '1' as TOO, '0' as FRO, '174' as V, '100' as N FROM dual union all select '13' as id, to_date('10.10.2017', 'dd.mm.yyyy') as DP, '1' as TOO, '0' as FRO, '174' as V, '100' as N FROM dual ), RE2 as ( select '14' as id, to_date('07.05.2017', 'dd.mm.yyyy') as DP, '0' as TOO, '1' as FRO, '174' as V, '100' as N FROM dual union all select '15' as id,to_date('09.07.2017', 'dd.mm.yyyy') as DP, '0' as TOO, '1' as FRO, '174' as V, '100' as N FROM dual union all select '16' as id,to_date('08.09.2017', 'dd.mm.yyyy') as DP, '0' as TOO, '1' as FRO, '174' as V, '100' as N FROM dual ), RE3 as ( select '17' as id,to_date('04.06.2017', 'dd.mm.yyyy') as DP, '0' as TOO, '0' as FRO, '173' as V, '100' as N FROM dual union all select '18' as id,to_date('07.08.2017', 'dd.mm.yyyy') as DP, '0' as TOO, '0' as FRO, '173' as V, '100' as N FROM dual ) В результате должно получится как-то так: Код: plaintext 1. 2. 3. 4. 5. ... |
| 12.01.2018, 10:45:15 |
a_s_v, и какие сложности? LEAD/LAG по первому набору, а далее LEFT JOIN по between на второй и третий набор ... |
| 12.01.2018, 11:01:54 |
Можно подробней ? Сложности есть ... |
| 12.01.2018, 11:16:09 |
Воможно не очень правильно сформулировал там связка наборов по RE1.V = RE2=V.RE3.V и длжно получится Код: plaintext 1. 2. 3. 4. 5. ... |
| 12.01.2018, 11:29:23 |
Добрый Э - Эх по betweenнедальновидно. ... |
| 12.01.2018, 11:30:42 |
Ошибка по полю re1.N =re2.N=re3.N Код: plaintext 1. 2. 3. 4. 5. ... |
| 12.01.2018, 11:32:35 |
a_s_v, Код: plsql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. .... stax ... |
| 12.01.2018, 11:33:30 |
пограничникДобрый Э - Эх по betweenнедальновидно.автор даже не осознал первой части посыла (про LEAD/LAG). думаешь, он бы понял продолжение про лефт джойн на неэквиусловии по "больше либо равно" и "меньше"? ... |
| 12.01.2018, 11:34:55 |
Stax, Спасибо Огромное ... |
| 12.01.2018, 11:41:09 |
Добрый Э - Эхпограничникпропущено... недальновидно.автор даже не осознал первой части посыла (про LEAD/LAG). думаешь, он бы понял продолжение про лефт джойн на неэквиусловии по "больше либо равно" и "меньше"? сложность скорее в другом что делать еслі в "диапазон" попадает больше 1 строки из ре2, ре3? .... stax ... |
| 12.01.2018, 11:43:25 |
Да это именно та сложность из re2 и re3 может быть несколько записей попадающих в один диапазон ... |
| 12.01.2018, 11:51:06 |
a_s_vДа это именно та сложность из re2 и re3 может быть несколько записей попадающих в один диапазон Код: plsql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. ..... stax ... |
| 12.01.2018, 11:58:50 |
start [/forum/topic.php?desktop=1&fid=52&tid=1884602]: |
44ms |
55ms |
| others: | 230ms |
| total: | 377ms |
