End-of-file on communication ora-03113
Добрый все , первый раз встречаю такую ошибку : ОшибкаORACLE instance started. Total System Global Area 2432696320 bytes Fixed Size 8623592 bytes Variable Size 671091224 bytes Database Buffers 1744830464 bytes Redo Buffers 8151040 bytes Database mounted. ORA-03113: end-of-file on communication channel Process ID: 11921 Session ID: 9 Serial number: 37632 ЛогиALTER DATABASE OPEN Ping without log force is disabled: instance mounted in exclusive mode. Endian type of dictionary set to little LGWR: STARTING ARCH PROCESSES TT00: Gap Manager starting (PID:11923) Starting background process ARC0 ARC0 started with pid=37, OS id=11925 ARC0: Archival started LGWR: STARTING ARCH PROCESSES COMPLETE ARC0: Becoming a 'no FAL' ARCH ARC0: Becoming the 'no SRL' ARCH Errors in file /u01/app/oracle/diag/rdbms/mainbase/MAINBASE/trace/MAINBASE_lgwr_11870.trc: ORA-00313: open failed for members of log group 1 of thread 1 Errors in file /u01/app/oracle/diag/rdbms/mainbase/MAINBASE/trace/MAINBASE_lgwr_11870.trc: ORA-00313: open failed for members of log group 2 of thread 1 Errors in file /u01/app/oracle/diag/rdbms/mainbase/MAINBASE/trace/MAINBASE_lgwr_11870.trc: ORA-00313: open failed for members of log group 3 of thread 1 Errors in file /u01/app/oracle/diag/rdbms/mainbase/MAINBASE/trace/MAINBASE_lgwr_11870.trc: ORA-00322: log 3 of thread 1 is not current copy ORA-00312: online log 3 thread 1: '/mnt/oradata/MAINBASE/onlinelog/o1_mf_3_fgogk3sk_.log' ORA-00312: online log 3 thread 1: '/mnt/fast_recovery_area/MAINBASE/MAINBASE/archivelog/MAINBASE/onlinelog/o1_mf_3_fgogk4y5_.log' ARCH: STARTING ARCH PROCESSES Errors in file /u01/app/oracle/diag/rdbms/mainbase/MAINBASE/trace/MAINBASE_ora_11921.trc: ORA-00322: log 1 of thread is not current copy ORA-00312: online log 3 thread 1: '/mnt/oradata/MAINBASE/onlinelog/o1_mf_3_fgogk3sk_.log' ORA-00312: online log 3 thread 1: '/mnt/fast_recovery_area/MAINBASE/MAINBASE/archivelog/MAINBASE/onlinelog/o1_mf_3_fgogk4y5_.log' USER (ospid: 11921): terminating the instance due to error 322 System state dump requested by (instance=1, osid=11921), summary=[abnormal instance termination]. System State dumped to trace file /u01/app/oracle/diag/rdbms/mainbase/MAINBASE/trace/MAINBASE_diag_11852_20180507133942.trc Dumping diagnostic data in directory=[cdmp_20180507133942], requested by (instance=1, osid=11921), summary=[abnormal instance termination]. 2018-05-07 13:39:44.336000 +03:00 Instance terminated by USER, pid = 11921 ... |
| 07.05.2018, 13:52:45 |
Заранее запостил . Суть такога , перетаскивал базу на новый диск ( тот же сервер ) , все параметры вроде исправил . В чем может быть проблема ? ... |
| 07.05.2018, 13:54:07 |
Сервер упал. Posted via ActualForum NNTP Server 1.5 ... |
| 07.05.2018, 13:58:25 |
maverick2104Заранее запостил . Суть такога , перетаскивал базу на новый диск ( тот же сервер ) , все параметры вроде исправил . В чем может быть проблема ? автор Код: plsql 1. 2. 3. 4. Базу останавливал когда копировал/перемещал? ... |
| 07.05.2018, 14:00:58 |
Vadim Lejnin, Нет к сожалению , забыл про shutdown ( да дилетант ) . Как можна исправить ? ... |
| 07.05.2018, 14:04:38 |
maverick2104Vadim Lejnin, Нет к сожалению , забыл про shutdown ( да дилетант ) . Как можна исправить ? Никак - у тебя мусор вместо базы... Восстанавливай backup ... |
| 07.05.2018, 14:28:47 |
Vadim Lejnin, А что умерло то в итоге , онлайнлоги ? ... |
| 07.05.2018, 14:55:01 |
maverick2104А что умерло то в итоге , Теоретически - всё что угодно. Это как фотографировать толпу на митинге с большой выдержкой - кто смирно стоял, тот получился. Кто двигался, руками или чем ещё размахивал, тому то и размазало - отдельные части или целиком. ... |
| 07.05.2018, 15:29:32 |
Viewer, Спасибо за ответ , я вас понял . Но вот стало интересно предположим у меня ручной стандбай ( для бедных ) который работает только с помощью скриптов. Теоретически все файлы у прода и станда одинаковые , кроме controlfile , я делаю специальный : Код: plaintext Вопрос : если в моем случае я копирую все файлы из станда ( кроме controlfile , этих оставляю ) запустится у меня база или нет ? ... |
| 07.05.2018, 16:02:12 |
maverick2104Viewer, Спасибо за ответ , я вас понял . Но вот стало интересно предположим у меня ручной стандбай ( для бедных ) который работает только с помощью скриптов. Теоретически все файлы у прода и станда одинаковые , кроме controlfile , я делаю специальный : Код: plaintext Вопрос : если в моем случае я копирую все файлы из станда ( кроме controlfile , этих оставляю ) запустится у меня база или нет ? Что значит запустится? не запустятся..., утверждение красным не верное Прочитай про SCN, что это такое, где хранится и для чего испульзуется ... |
| 07.05.2018, 16:40:08 |
| 07.05.2018, 16:52:08 |
maverick2104если в моем случае я копирую все файлы из станда Первое, что нужно понимать четко и однозначно: если база данных не остановлена, то файлы БД находятся в непрерывном процессе изменения. Второе, что нужно понимать четко и однозначно: для того, чтобы база данных "запустилась", необходимо, чтобы все файлы БД находились в согласованном состоянии. Если БД была корректно остановлена, то копия БД будет называться "холодной" и, если перенос осуществлен на совместимую (с исходной) платформу, а также не было допущено ошибок при переносе данных, "запустится". Если же копирование осуществляется без остановки БД, то такая копия называется "горячей". Для успешного осуществления такого копирования, вообще говоря, требуется выполнить некоторые приседания на исходной БД или воспользоваться специальной утилитой (RMAN). Для успешного старта горячей копии необходим процесс согласования файлов БД (recover). Данный процесс осуществляет "проигрывание" изменений, выполненных исходной БД от момента начала копирования до окончания. Протокол изменений база непрерывно сохраняет в журналах повторного выполнения (REDO), которые по заполнении складирует в архивные журналы (только в режиме ARCHIVELOG). Как правильно сделать и восстановить горячую копию - см. в руководстве администратора (хотя бы "2-day dba"), это не тема для пустопорожнего переливания на форуме. ... |
| 07.05.2018, 16:53:44 |
start [/forum/topic.php?desktop=1&fid=52&tid=1884033]: |
177ms |
32ms |
| others: | 186ms |
| total: | 422ms |
