ORA-12557 при попытке импортировать дамп БД командой impdp
Здравствуйте. При попытке импортировать дамп вылезает ошибка ORA-12557: Значения переменных окружения ORACLE_HOME и ORACLE_SID: Содержимое файла listener.ora: # listener.ora Network Configuration File: C:\app\oracle\product\11.2.0\client_1\network\admin\listener.ora # Generated by Oracle configuration tools. SID_LIST_LISTENER = (SID_LIST = (SID_DESC = (GLOBAL_DBNAME=KURASKRO) (ORACLE_HOME=C:\app\oracle\product\11.2.0\dbhome_1) (SID_NAME=KURASKRO) ) ) LISTENER = (DESCRIPTION_LIST = (DESCRIPTION = (ADDRESS = (PROTOCOL = TCP)(HOST = WIN-LC0HEMKES26)(PORT = 1521)) (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC1521)) ) ) ADR_BASE_LISTENER = C:\app\oracle Содержимое файла tnsnames.ora: # tnsnames.ora Network Configuration File: C:\Oracle\11.2.0.srv\orahome\network\admin\tnsnames.ora # Generated by Oracle configuration tools. #LISTENER_KURASKRO = # (ADDRESS = (PROTOCOL = TCP)(HOST = WIN-LC0HEMKES26)(PORT = 1521)) #KURASKRO = # (DESCRIPTION = # (ADDRESS = (PROTOCOL = TCP)(HOST = 127.0.0.1)(PORT = 1521)) # (CONNECT_DATA = # (SERVER = DEDICATED) # (SID = KURASKRO) # ) # ) KURASKRO = (DESCRIPTION_LIST = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = WIN-LC0HEMKES26)(PORT = 1521)) (CONNECT_DATA = (SID = KURASKRO) ) ) ) ) LISTENER_KURASKRO = (ADDRESS = (PROTOCOL = TCP)(HOST = WIN-LC0HEMKES26)(PORT = 1521)) Содержимое файла sqlnet.ora: NAMES.DIRECTORY_PATH=TNSNAMES Результат выполнения команды lsnrctl status: LSNRCTL for 64-bit Windows: Version 11.2.0.1.0 - Production on 26-ИЮЛ-2018 12:28:31 Copyright (c) 1991, 2010, Oracle. All rights reserved. Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=WIN-LC0HEMKES26)(PORT=1521))) STATUS of the LISTENER ------------------------ Alias LISTENER Version TNSLSNR for 64-bit Windows: Version 11.2.0.1.0 - Production Start Date 25-ИЮЛ-2018 15:48:02 Uptime 0 days 20 hr. 40 min. 30 sec Trace Level off Security ON: Local OS Authentication SNMP OFF Listener Log File c:\app\oracle\diag\tnslsnr\WIN-LC0HEMKES26\listener\alert\log.xml Listening Endpoints Summary... (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=WIN-LC0HEMKES26)(PORT=1521))) Services Summary... Service "KURASKROXDB" has 1 instance(s). Instance "kuraskro", status READY, has 1 handler(s) for this service... Service "kuraskro" has 1 instance(s). Instance "kuraskro", status READY, has 1 handler(s) for this service... The command completed successfully В чем может быть причина? Пытался решить проблему поиском аналогичных тем на форуме, не помогло... ... |
| 26.07.2018, 12:05:29 |
vglvВ чем может быть причина?Кто тебя научил писать двойной слэш? ... |
| 26.07.2018, 12:09:24 |
Elic, если импортировать командой impdp user/password@KURASKRO SCHEMAS=user dumpfile=KURASKRO_20180723.DMP, то возникают ошибки UDI-12154 и ORA-12154. ... |
| 26.07.2018, 12:24:29 |
vglvесли импортировать командойТы её сам выдумал. ... |
| 26.07.2018, 12:31:23 |
Elic, взял отсюда: https://oracle-base.com/articles/10g/oracle-data-pump-10g ... |
| 26.07.2018, 12:36:26 |
vglvElic, взял отсюда: https://oracle-base.com/articles/10g/oracle-data-pump-10g Ты в Oracle-овых технологиях совсем ничего не понимаешь? ... |
| 26.07.2018, 12:40:40 |
Elic, может быть, напишешь, что конкретно я не понимаю и на что конкретно мне следует обратить внимание, а не задавать вопросы, уводящие тему в какой-то бессмысленный флейм? ... |
| 26.07.2018, 12:44:25 |
vglvна что конкретно мне следует обратить вниманиеElicКто тебя научил писать двойной слэш? И не стоит воинствовать. ... |
| 26.07.2018, 12:47:28 |
ORA-12154: TNS:could not resolve the connect identifier specified Cause: A connection to a database or other service was requested using a connect identifier, and the connect identifier specified could not be resolved into a connect descriptor using one of the naming methods configured. For example, if the type of connect identifier used was a net service name then the net service name could not be found in a naming method repository, or the repository could not be located or reached. Action: - If you are using local naming (TNSNAMES.ORA file): - Make sure that "TNSNAMES" is listed as one of the values of the NAMES.DIRECTORY_PATH parameter in the Oracle Net profile (SQLNET.ORA) - Verify that a TNSNAMES.ORA file exists and is in the proper directory and is accessible. - Check that the net service name used as the connect identifier exists in the TNSNAMES.ORA file. - Make sure there are no syntax errors anywhere in the TNSNAMES.ORA file. Look for unmatched parentheses or stray characters. Errors in a TNSNAMES.ORA file may make it unusable. - If you are using directory naming: - Verify that "LDAP" is listed as one of the values of the NAMES.DIRETORY_PATH parameter in the Oracle Net profile (SQLNET.ORA). - Verify that the LDAP directory server is up and that it is accessible. - Verify that the net service name or database name used as the connect identifier is configured in the directory. - Verify that the default context being used is correct by specifying a fully qualified net service name or a full LDAP DN as the connect identifier - If you are using easy connect naming: - Verify that "EZCONNECT" is listed as one of the values of the NAMES.DIRETORY_PATH parameter in the Oracle Net profile (SQLNET.ORA). - Make sure the host, port and service name specified are correct. - Try enclosing the connect identifier in quote marks. See the Oracle Net Services Administrators Guide or the Oracle operating system specific guide for more information on naming. ... |
| 26.07.2018, 12:48:13 |
ElicИ не стоит воинствовать. Код: plsql 1. 2. 3. 4. 5. SY. ... |
| 26.07.2018, 15:08:26 |
SY Код: plsql 1. Передёргиваешь. ... |
| 26.07.2018, 15:36:51 |
ElicSY Код: plsql 1. Передёргиваешь. // конечно не масло, но кашу не портит и к 12557 никакого отношения не имеет. SY. ... |
| 26.07.2018, 15:45:19 |
Сайт Бирлесона уверяет, что ORA-12557 из-за наличия нескольких Oracle Home на компьютере. Что похоже на правду. т.к. tnsnames.ora у автора тоже не отработало--> скорее всего хватается какой-то другой tnsnames.ora. ... |
| 26.07.2018, 15:53:01 |
Leonid Kudryavtsevскорее всего хватается какой-то другой tnsnames.ora. ??? Какой TNSNAMES.ORA? Тут используется прямое соединение host:port/service. SY. ... |
| 26.07.2018, 15:55:51 |
Leonid KudryavtsevСайт Бирлесона уверяет, что ORA-12557 из-за наличия нескольких Oracle Home Из-за кривого окружения оно. Если умеючи - то можно сколько угодно хоумов держать. А вот ежели человек потребитель , то и решение должно быть потребительским - занести денег ближайшему Бурлесону, пусть сделает чтобы заработало... ... |
| 26.07.2018, 15:57:58 |
vglvСодержимое файла tnsnames.ora: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. Да и юзай лучше SERVICE_NAME=KURASKRO Поэтому у тебя не работает user/password@KURASKRO достаточно Код: plaintext 1. 2. 3. 4. 5. vglvСодержимое файла sqlnet.ora: Код: plaintext 1. Закомментируй этот параметр или добавь EZCONNECT (синтаксис подсмотри в доке) vglvРезультат выполнения команды lsnrctl status: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. И напрашивается вариант, что у тебя где-то установлено TNS_ADMIN или используется несколько ORACLE_HOME и файлики (sqlnet.ora, tnsnames.ora) берутся совсем не те, что ты выложил ... |
| 27.07.2018, 02:54:51 |
start [/forum/topic.php?desktop=1&fid=52&tid=1883678]: |
44ms |
66ms |
| others: | 234ms |
| total: | 401ms |
