18c startup: Image consistency checking encountered an error, checking disabled
Братцы, кушать не могу! Вот при старте базы 18с, что видно в логе. Подкиньте идей, как понять, витально это для экземпляра или нет b d x`v djj,ot cenm ********************************************************************** 2018-09-11T10:44:25.990306+05:00 Errors in file /orahome/diag/rdbms/db/OBLAKOSID/trace/OBLAKOSID_ora_1219.trc: ORA-27167: Attempt to determine if Oracle binary image is stored on remote server failed ORA-27300: OS system dependent operation:parse_df failed with status: 2 ORA-27301: OS failure message: No such file or directory ORA-27302: failure occurred at: parse failed ORA-27303: additional information: Файловая система 1K-блоков Использовано Доступно Использовано% Cмонтировано в rpoo 2018-09-11T10:44:25.990410+05:00 Image consistency checking encountered an error, checking disabled LICENSE_MAX_SESSION = 0 LICENSE_SESSIONS_WARNING = 0 Initial number of CPU is 8 Number of processor cores in the system is 4 Number of processor sockets in the system is 1 Capability Type : Network capabilities requested : 1 detected : 0 Simulated : 0 Capability Type : Runtime Environment capabilities requested : 400000FF detected : 40000000 Simulated : 0 Capability Type : Engineered Systems capabilities requested : 3 detected : 0 Simulated : 0 Using LOG_ARCHIVE_DEST_1 parameter default value as USE_DB_RECOVERY_FILE_DEST Autotune of undo retention is turned on. IMODE=BR ILAT =55 LICENSE_MAX_USERS = 0 SYS auditing is enabled NOTE: remote asm mode is local (mode 0x1; from cluster type) NOTE: Using default ASM root directory ASM NOTE: Cluster configuration type = NONE [2] Oracle Database 18c Enterprise Edition Release 18.0.0.0.0 - Production Version 18.3.0.0.0. ORACLE_HOME: /orahome/product/18.0.0/db_1 System name: Linux Node name: db.localdomain Release: 4.15.18-2-pve Version: #1 SMP PVE 4.15.18-20 (Thu, 16 Aug 2018 11:06:35 +0200) Machine: x86_64 Using parameter settings in server-side spfile /orahome/product/18.0.0/db_1/dbs/spfileOBLAKOSID.ora System parameters with non-default values: processes = 320 nls_language = "RUSSIAN" nls_territory = "RUSSIA" sga_target = 0 memory_target = 8G memory_max_target = 8G control_files = "/orahome/oradata/DB/control01.ctl" control_files = "/orahome/recovery_area/DB/control02.ctl" db_block_size = 8192 compatible = "18.0.0" db_recovery_file_dest = "/orahome/recovery_area" db_recovery_file_dest_size= 50G undo_tablespace = "UNDOTBS1" remote_login_passwordfile= "EXCLUSIVE" db_domain = "localdomain" dispatchers = "(PROTOCOL=TCP) (SERVICE=OBLAKOSIDXDB)" local_listener = "LISTENER_OBLAKOSID" audit_file_dest = "/orahome/admin/db/adump" audit_trail = "DB" db_name = "db" open_cursors = 300 diagnostic_dest = "/orahome" enable_pluggable_database= TRUE NOTE: remote asm mode is local (mode 0x1; from cluster type) ... |
| 11.09.2018, 19:57:33 |
Trace вот, если вдруг кто благоволит, да посмотрит... ... |
| 11.09.2018, 20:03:05 |
Саша Сплинтер Код: plaintext 1. 2. 3. Похоже они там зачем-то запускают df, пытаются пропарсить его вывод и обламываются от того, что тот на русском. Скорее всего выставление английской локали в шелл перед запуском устранит это (export LANG=C). ... |
| 11.09.2018, 20:55:23 |
Мутаген, благодарю. Таки да, индийские программисты не умеют парсить русский. Появилась еще одна строчка 2018-09-12T08:11:53.728098+05:00 Errors in file /orahome/diag/rdbms/db/OBLAKOSID/trace/OBLAKOSID_ora_6424.trc: ORA-27167: Attempt to determine if Oracle binary image is stored on remote server failed ORA-27300: OS system dependent operation:parse_df failed with status: 2 ORA-27301: OS failure message: No such file or directory ORA-27302: failure occurred at: parse failed ORA-27303: additional information: Filesystem 1K-blocks Used Available Use% Mounted on rpool/data/subvol-104-disk-1 209715200 29647104 180068096 15% / Лечится ли это на данном дисковом массиве (zfs), вот в чем вопрос... И какие могут быть последствия ) А так Оракла как живой! ... |
| 12.09.2018, 06:16:22 |
Забей Этот баг еще в 11g вылазил -- не понимал он ZFS ... |
| 12.09.2018, 07:37:10 |
Вячеслав Любомудров, Слушай, читал в MOS про этот баг. Знаешь, что озадачило. Они пишут, что патч типа выполнен и все ок. Прикольно, что в 18 это не перешло... По логике-то... ... |
| 12.09.2018, 08:28:29 |
Саша СплинтерВячеслав Любомудров, Слушай, читал в MOS про этот баг. Знаешь, что озадачило. Они пишут, что патч типа выполнен и все ок. Прикольно, что в 18 это не перешло... По логике-то...Обычное дело для Oracle. ... |
| 12.09.2018, 08:40:32 |
Ну когда ZFS портировали в линух и стали ставить в продакшн на серьезных оракловых серверах? ... |
| 12.09.2018, 08:40:55 |
Вячеслав Любомудров, ну видишь, я просто идеализировал в какой-то момент Оракл )) Верно говоришь. Есть среда виртуализации Оракла, ОЛ7 и нечего дёргаться ) А кто решил вдруг в контейнере lxc в ProxMox да на zfs, тот сам себе чудак. Просто, судя по статья "Ставим Оракл на *", не один я такой ))) ... |
| 12.09.2018, 08:49:49 |
Вячеслав Любомудров, Как думаешь, вот это из той же области? Error attempting to elevate VKTM's priority: no further priority changes will be attempted for this process VKTM started with pid=5, OS id=447 Подкрутить чего можно? ... |
| 12.09.2018, 08:52:24 |
Саша СплинтерВячеслав Любомудров, Как думаешь, вот это из той же области? Error attempting to elevate VKTM's priority: no further priority changes will be attempted for this process VKTM started with pid=5, OS id=447 Подкрутить чего можно? проверьте в $ORACLE_HOME/bin права и хозяев у бинарников. стоят ли суидные биты и овнер root на нужных файлах. прогоните root.sh ... |
| 13.09.2018, 09:46:57 |
Спасибо, проверю. Отдельной темой завёл уже этот вопрос, не обессудьте. ... |
| 13.09.2018, 11:41:34 |
Саша СплинтерВячеслав Любомудров, ну видишь, я просто идеализировал в какой-то момент Оракл )) Верно говоришь. Есть среда виртуализации Оракла, ОЛ7 и нечего дёргаться ) А кто решил вдруг в контейнере lxc в ProxMox да на zfs, тот сам себе чудак. Просто, судя по статья "Ставим Оракл на *", не один я такой ))) мне да и видимо Oracle приятнее openvz 7, ставил туда правда 12.2 вроде не было никаких проблем ... ... |
| 13.09.2018, 14:42:38 |
Ну на ProxMox 5 сейчас есть только qemu и lxc C qemu кошмар вышел сразу. На lxc все завелось тоже сразу. Вот только огрехи эти. Но, вроде, несущественные, как понимаю... ... |
| 13.09.2018, 17:27:48 |
start [/forum/topic.php?desktop=1&fid=52&tid=1883464]: |
36ms |
| others: | 175ms |
| total: | 254ms |
