interface in ODI
Доброго времени суток. При инсерте данных в файл возникает проблема следующего характера. можете подсказать с чем может быть связано. Вылетает ошибка: java.lang.NumberFormatException at java.math.BigDecimal.<init>(BigDecimal.java:459) at java.math.BigDecimal.<init>(BigDecimal.java:728) at com.sunopsis.data.transform.impl.DataTransformerBigDecimal2Object.from(DataTransformerBigDecimal2Object.java:36) at com.sunopsis.data.transform.impl.generic.DataTransformerCombiner.from(DataTransformerCombiner.java:50) at com.sunopsis.data.transform.impl.generic.DataTransformerCombiner.from(DataTransformerCombiner.java:50) at com.sunopsis.data.transform.impl.generic.DataTransformerCombiner.from(DataTransformerCombiner.java:50) at com.sunopsis.data.transform.impl.generic.DataTransformerNullWrapper.from(DataTransformerNullWrapper.java:37) at com.sunopsis.jdbc.driver.file.impl.rows.RowDataAbstract.setValue(RowDataAbstract.java:75) at com.sunopsis.jdbc.driver.file.FilePreparedStatement.setValue(FilePreparedStatement.java:163) at com.sunopsis.jdbc.driver.file.FilePreparedStatement.setObject(FilePreparedStatement.java:263) at com.sunopsis.jdbc.driver.file.FilePreparedStatement.setObject(FilePreparedStatement.java:273) at oracle.odi.query.typemapping.PassThroughWriterType.setValue(PassThroughWriterType.java:30) at oracle.odi.query.JDBCTemplate.setValue(JDBCTemplate.java:199) at oracle.odi.runtime.agent.execution.sql.SQLCommand.bindResultSetColumns(SQLCommand.java:229) at oracle.odi.runtime.agent.execution.sql.SQLCommand.processRecord(SQLCommand.java:141) at oracle.odi.runtime.agent.execution.cmd.TextCommand.processRecord(TextCommand.java:1) at oracle.odi.runtime.agent.execution.DataMovementTaskExecutionHandler.handleTask(DataMovementTaskExecutionHandler.java:86) at com.sunopsis.dwg.dbobj.SnpSessTaskSql.processTask(SnpSessTaskSql.java:2913) at com.sunopsis.dwg.dbobj.SnpSessTaskSql.treatTask(SnpSessTaskSql.java:2625) at com.sunopsis.dwg.dbobj.SnpSessStep.treatAttachedTasks(SnpSessStep.java:577) at com.sunopsis.dwg.dbobj.SnpSessStep.treatSessStep(SnpSessStep.java:468) at com.sunopsis.dwg.dbobj.SnpSession.treatSession(SnpSession.java:2128) at oracle.odi.runtime.agent.processor.impl.StartSessRequestProcessor$2.doAction(StartSessRequestProcessor.java:366) at oracle.odi.core.persistence.dwgobject.DwgObjectTemplate.execute(DwgObjectTemplate.java:216) at oracle.odi.runtime.agent.processor.impl.StartSessRequestProcessor.doProcessStartSessTask(StartSessRequestProcessor.java:300) at oracle.odi.runtime.agent.processor.impl.StartSessRequestProcessor.access$0(StartSessRequestProcessor.java:292) at oracle.odi.runtime.agent.processor.impl.StartSessRequestProcessor$StartSessTask.doExecute(StartSessRequestProcessor.java:855) at oracle.odi.runtime.agent.processor.task.AgentTask.execute(AgentTask.java:126) at oracle.odi.runtime.agent.support.DefaultAgentTaskExecutor$2.run(DefaultAgentTaskExecutor.java:82) at java.lang.Thread.run(Thread.java:662) ... |
| 05.10.2018, 12:14:10 |
start [/forum/topic.php?desktop=1&fid=52&tid=1883370]: |
59ms |
48ms |
| others: | 235ms |
| total: | 399ms |
