ODI interface, LKM File To Oracle SQLLDR
Доброго времени суток. при выполнении интерфейса загрузки из файла в таблицу(LKM File To Oracle SQLLDR) выполняется скрипт который падает с ошибкой: org.apache.bsf.BSFException: exception from Jython: Traceback (most recent call last): File "<string>", line 22, in <module> Load Error: See /home/oracle/temp_rdf/ITEM_FORECAST_DY.log for details скрипт: import java.lang.String import java.lang.Runtime as Runtime from jarray import array import java.io.File import os import re ctlfile = r"""/home/oracle/temp_rdf/ITEM_FORECAST_DY.ctl""" logfile = r"""/home/oracle/temp_rdf/ITEM_FORECAST_DY.log""" outfile = r"""/home/oracle/temp_rdf/ITEM_FORECAST_DY.out""" oracle_sid='' if len('RMAPRD')>0: oracle_sid = '@'+'RMAPRD' loadcmd = r"""sqlldr \'STAGE/<@=snpRef.getInfo("DEST_PASS") @>%s\' control=\'%s\' log=\'%s\' > "%s" """ % (oracle_sid,ctlfile, logfile, outfile) rc = os.system(loadcmd) if rc <> 0 and rc <> 2: raise "Load Error", "See %s for details" % logfile # Init Vars nbIns = 0 nbRej = 0 nbNull = 0 strprt = "" maxAllowedError = r"""99999""" c = 0 flag = 0 # Open log file f = open(logfile, "r") try: lines = f.readlines() for line in lines: if line.rstrip().upper().endswith(r"""STAGE.TC$_0ITEM_FORECAST_DY_TEST:""".upper()): flag = 1 c = 0 if flag == 1: if c > 0 and c <= 4: if c == 1 : nbIns = int(re.findall("\d+", line)[0]) elif c == 2: nbRej = int(re.findall("\d+", line)[0]) elif c == 4: nbNull = int(re.findall("\d+", line)[0]) break c+=1 strprt = "\n\tIns:\t%s\n\tReject:\t%s\n\tNullField:\t%s" % (nbIns, nbRej, nbNull) finally: f.close() # if some rows has been rejected due to invalide data, check KM option LOA_ERRORS if rc == 2: if nbRej > int(maxAllowedError): raise strprt break помогиите разобраться в причине падения мб настройки не те в вел в LKMе ... |
| 08.11.2018, 10:11:03 |
Ну а что там в логах sqllldr? ... |
| 08.11.2018, 10:18:11 |
Festani_10if rc <> 0 and rc <> 2: ... |
| 08.11.2018, 10:19:25 |
-2-Festani_10if rc <> 0 and rc <> 2:а 2 это что? ... |
| 08.11.2018, 10:20:20 |
Alexander Ryndin, Файл с логами не создался. ... |
| 08.11.2018, 10:25:35 |
-2--2-пропущено... а 2 это что? полный текст ошибки: org.apache.bsf.BSFException: exception from Jython: Traceback (most recent call last): File "<string>", line 22, in <module> Load Error: See /home/oracle/temp_rdf/ITEM_FORECAST_DY.log for details at org.apache.bsf.engines.jython.JythonEngine.exec(JythonEngine.java:146) at com.sunopsis.dwg.codeinterpretor.SnpScriptingInterpretor.execInBSFEngine(SnpScriptingInterpretor.java:322) at com.sunopsis.dwg.codeinterpretor.SnpScriptingInterpretor.exec(SnpScriptingInterpretor.java:170) at com.sunopsis.dwg.dbobj.SnpSessTaskSql.scripting(SnpSessTaskSql.java:2472) at oracle.odi.runtime.agent.execution.cmd.ScriptingExecutor.execute(ScriptingExecutor.java:47) at oracle.odi.runtime.agent.execution.cmd.ScriptingExecutor.execute(ScriptingExecutor.java:1) at oracle.odi.runtime.agent.execution.TaskExecutionHandler.handleTask(TaskExecutionHandler.java:50) at com.sunopsis.dwg.dbobj.SnpSessTaskSql.processTask(SnpSessTaskSql.java:2913) at com.sunopsis.dwg.dbobj.SnpSessTaskSql.treatTask(SnpSessTaskSql.java:2625) at com.sunopsis.dwg.dbobj.SnpSessStep.treatAttachedTasks(SnpSessStep.java:577) at com.sunopsis.dwg.dbobj.SnpSessStep.treatSessStep(SnpSessStep.java:468) at com.sunopsis.dwg.dbobj.SnpSession.treatSession(SnpSession.java:2128) at oracle.odi.runtime.agent.processor.impl.StartSessRequestProcessor$2.doAction(StartSessRequestProcessor.java:366) at oracle.odi.core.persistence.dwgobject.DwgObjectTemplate.execute(DwgObjectTemplate.java:216) at oracle.odi.runtime.agent.processor.impl.StartSessRequestProcessor.doProcessStartSessTask(StartSessRequestProcessor.java:300) at oracle.odi.runtime.agent.processor.impl.StartSessRequestProcessor.access$0(StartSessRequestProcessor.java:292) at oracle.odi.runtime.agent.processor.impl.StartSessRequestProcessor$StartSessTask.doExecute(StartSessRequestProcessor.java:855) at oracle.odi.runtime.agent.processor.task.AgentTask.execute(AgentTask.java:126) at oracle.odi.runtime.agent.support.DefaultAgentTaskExecutor$2.run(DefaultAgentTaskExecutor.java:82) at java.lang.Thread.run(Thread.java:662) Caused by: Traceback (most recent call last): File "<string>", line 22, in <module> Load Error: See /home/oracle/temp_rdf/ITEM_FORECAST_DY.log for details at org.python.core.PyException.fillInStackTrace(PyException.java:70) at java.lang.Throwable.<init>(Throwable.java:181) at java.lang.Exception.<init>(Exception.java:29) at java.lang.RuntimeException.<init>(RuntimeException.java:32) at org.python.core.PyException.<init>(PyException.java:46) at org.python.core.PyException.doRaise(PyException.java:219) at org.python.core.Py.makeException(Py.java:1166) at org.python.core.Py.makeException(Py.java:1170) at org.python.pycode._pyx34.f$0(<string>:59) at org.python.pycode._pyx34.call_function(<string>) at org.python.core.PyTableCode.call(PyTableCode.java:165) at org.python.core.PyCode.call(PyCode.java:18) at org.python.core.Py.runCode(Py.java:1204) at org.python.core.Py.exec(Py.java:1248) at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:172) at org.apache.bsf.engines.jython.JythonEngine.exec(JythonEngine.java:144) ... 19 more ... |
| 08.11.2018, 10:34:35 |
Festani_10Alexander Ryndin, Файл с логами не создался.Ну я бы шел туда, где работает агент. Искал бы сгенерированный control-файл и под тем же пользователем попробовал руками запустить sqlldr. Может путей до sqlldr не хватает. Может прав нет на каталог ... |
| 08.11.2018, 10:51:32 |
-2--2-пропущено... а 2 это что?Ну это автоматически сгенерированный скрипт. Маловероятно, что там есть косяки, если, конечно, никто своими кривыми руками не поковырялся в коробочных KM ... |
| 08.11.2018, 10:52:54 |
Alexander Ryndin-2-пропущено... а 2 это что?Ну это автоматически сгенерированный скрипт. Маловероятно, что там есть косяки, если, конечно, никто своими кривыми руками не поковырялся в коробочных KM сам LKM не трогал. аналогичная ошибка на сайте ... |
| 08.11.2018, 11:14:11 |
Festani_10Alexander Ryndinпропущено... Ну это автоматически сгенерированный скрипт. Маловероятно, что там есть косяки, если, конечно, никто своими кривыми руками не поковырялся в коробочных KM сам LKM не трогал. аналогичная ошибка на сайте это ошибка не в odi. Вам нужно смотреть настройки окружения, которое задействует odi ... |
| 08.11.2018, 13:42:55 |
start [/forum/topic.php?desktop=1&fid=52&tid=1883219]: |
27ms |
55ms |
| others: | 261ms |
| total: | 389ms |
