Error agent OEM 12c
Error Agent has been blocked due to Bounce Counter mismatch. If Agent has been restored from a backup perform an Agent Resync. ... |
| 08.01.2019, 11:14:18 |
Error agent OEM 12c
lleopolld1, При попытке resync выпадает следующее: Error communicating with the agent. Exception message - Unable to connect to the agent [Connection timed out: connect]. Please check agent-oms communication and try resync again.Exception in resync: Unable to connect to the agent [Connection timed out: connect]resyncState: resync of agent failed. ... |
| 08.01.2019, 13:58:51 |
Error agent OEM 12c
уже связь агента и oms eсть,но при resync получаю System has detected that this agent never uploaded to the repository successfully. Repository does not have enough information to restore this agent. ... |
| 10.01.2019, 10:48:00 |
Error agent OEM 12c
уже 13,3 есть . ... |
| 10.01.2019, 14:09:58 |
Error agent OEM 12c
тут всё норм? Код: plsql 1. 2. если нет хоста, то Код: plsql 1. ... |
| 11.01.2019, 08:39:12 |
Error agent OEM 12c
AlexVin, не совсем,вот скрины >emctl config agent listtargets Oracle Enterprise Manager Cloud Control 12c Release 5 Copyright (c) 1996, 2015 Oracle Corporation. All rights reserved. 2019-01-11 01:36:05,400 [main] ERROR emSDK.config - No file at D:\agent\agent_i nst\sysman\config\emd.properties java.io.FileNotFoundException: No file at D:\agent\agent_inst\sysman\config\emd. properties at oracle.sysman.emd.targetIntg.agent.AgentTargetInstaller.readEMDProper tiesFromAS(AgentTargetInstaller.java:5987) at oracle.sysman.emd.targetIntg.agent.AgentTargetInstaller.checkVersion( AgentTargetInstaller.java:2550) at oracle.sysman.emd.targetIntg.agent.AgentTargetInstaller.isNGAgent(Age ntTargetInstaller.java:2529) at oracle.sysman.emd.targetIntg.agent.AgentTargetInstaller.parseTargetsX mlToTargets(AgentTargetInstaller.java:2646) at oracle.sysman.emd.targetIntg.agent.AgentTargetInstaller.parseTargetsX ml(AgentTargetInstaller.java:2633) at oracle.sysman.emd.targetIntg.agent.AgentTargetInstaller.listAllTarget s(AgentTargetInstaller.java:2324) at oracle.sysman.emd.targetIntg.agent.AgentTargetInstaller.printTargets( AgentTargetInstaller.java:2129) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl. java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces sorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at oracle.sysman.emd.targetIntg.Util$DefaultIntegrationMethod.execute(Ut il.java:617) at oracle.sysman.emd.targetIntg.TargetInstaller.execute_(TargetInstaller .java:171) at oracle.sysman.emd.targetIntg.TargetInstaller.execute(TargetInstaller. java:159) at oracle.sysman.emSDK.conf.TargetInstaller.printTargets(TargetInstaller .java:1146) at oracle.sysman.emSDK.conf.TargetInstaller.main(TargetInstaller.java:35 52) [xxxxx.local, host] [xxxxxx.local:3872, oracle_emd] [xxxxxlocal, oracle_home] [Management Services and Repository, oracle_emrep] [xxxxx.local:4889_Management_Service, oracle_oms] [xxxxx.local:4889_Management_Service_CONSOLE, oracle_oms_console] [xxxxx.local:4889_Management_Service_PBS, oracle_oms_pbs] [/EMGC_GCDomain/GCDomain/EMGC_ADMINSERVER/FMW Welcome Page Application(11.1.0.0. 0), j2ee_application] [/EMGC_GCDomain/GCDomain/EMGC_OMS1/emgc, j2ee_application] [/EMGC_GCDomain/GCDomain/EMGC_OMS1/empbs, j2ee_application] [/EMGC_GCDomain/GCDomain/EMGC_OMS1/OCMRepeater, j2ee_application] [/EMGC_GCDomain/GCDomain/EMGC_ADMINSERVER/mds-owsm, metadata_repository] [/EMGC_GCDomain/GCDomain/EMGC_ADMINSERVER/mds-sysman_mds, metadata_repository] [/EMGC_GCDomain/instance1/ohs1, oracle_apache] [/EMGC_GCDomain/GCDomain/EMGC_OMS1/oracle.security.apm(11.1.1.3.0), oracle_apm] [EMGC_GCDomain, oracle_ias_farm] [/EMGC_GCDomain/GCDomain, weblogic_domain] [/EMGC_GCDomain/GCDomain/EMGC_ADMINSERVER, weblogic_j2eeserver] [/EMGC_GCDomain/GCDomain/EMGC_OMS1, weblogic_j2eeserver] [EM Management Beacon, oracle_beacon] [xxxxx.local, oracle_home] [xxxxx.mks.local, oracle_home] [xxxxx.local_4177, oracle_home] [xxxxx.local, oracle_home] [xxxxx, oracle_database] [xxxxx.mks.local, oracle_listener] [xxxxx.mks.local, oracle_home] >emctl listplugins agent Oracle Enterprise Manager Cloud Control 12c Release 5 Copyright (c) 1996, 2015 Oracle Corporation. All rights reserved. --------------------------------------------------------------- D:\agent\agent_inst\sysman\config\emd.properties (The system cannot find the fil e specified) ... |
| 11.01.2019, 09:17:53 |
Error agent OEM 12c
Агент заблочен(пишет,что не синхронизирован с репозиторием) Выполняю Resync в oem : Код: plaintext Код: plaintext 1. 2. ... |
| 11.01.2019, 09:22:20 |
Error agent OEM 12c
нашел схожую ситуацию Agent State is out of sync with management server под node понимается host? ... |
| 11.01.2019, 10:23:03 |
start [/forum/topic.php?desktop=1&fid=52&tid=1882949]: |
236ms |
23ms |
| others: | 182ms |
| total: | 477ms |
