Ora 12560 При создании базы данных
Доброго времени суток прошу помощи в решении вопроса При создании базы данных возникает ошибка Ora 12560 Содержание лог файла sqlnet.log Fatal NI connect error 12560, connecting to: (DESCRIPTION=(ADDRESS=(PROTOCOL=BEQ)(PROGRAM=oracle)(ARGV0=oracleMAGICASH)(ARGS='(DESCRIPTION=(LOCAL=YES)(ADDRESS=(PROTOCOL=beq)))'))(CONNECT_DATA=(SID=MAGICASH)(CID=(PROGRAM=C:\oracle\ora81\bin\svrmgrl.exe)(HOST=COMPUTER-6EECC0)(USER=Administrator)))) VERSION INFORMATION: TNS for 32-bit Windows: Version 8.1.7.4.0 - Production Oracle Bequeath NT Protocol Adapter for 32-bit Windows: Version 8.1.7.4.0 - Production Time: 29-MAR-2019 09:29:24 Tracing not turned on. Tns error struct: nr err code: 0 ns main err code: 12560 TNS-12560: TNS:protocol adapter error ns secondary err code: 0 nt main err code: 530 TNS-00530: Protocol adapter error nt secondary err code: 2 nt OS err code: 0 Содержание файла listener.ora # LISTENER.ORA Network Configuration File: C:\oracle\ora81\network\admin\listener.ora # Generated by Oracle configuration tools. LISTENER = (DESCRIPTION_LIST = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC0)) ) (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = computer-6eecc0)(PORT = 1521)) ) ) (DESCRIPTION = (PROTOCOL_STACK = (PRESENTATION = GIOP) (SESSION = RAW) ) (ADDRESS = (PROTOCOL = TCP)(HOST = computer-6eecc0)(PORT = 2481)) ) ) SID_LIST_LISTENER = (SID_LIST = (SID_DESC = (SID_NAME = PLSExtProc) (ORACLE_HOME = C:\oracle\ora81) (PROGRAM = extproc) ) ) Содержание файла sqlnet.ora # SQLNET.ORA Network Configuration File: C:\oracle\ora81\network\admin\sqlnet.ora # Generated by Oracle configuration tools. SQLNET.AUTHENTICATION_SERVICES= (NTS) NAMES.DIRECTORY_PATH= (TNSNAMES, ONAMES, HOSTNAME) Содержание файла tnsnames.ora # TNSNAMES.ORA Network Configuration File: C:\oracle\ora81\network\admin\tnsnames.ora # Generated by Oracle configuration tools. EXTPROC_CONNECTION_DATA = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC0)) ) (CONNECT_DATA = (SID = PLSExtProc) (PRESENTATION = RO) ) ) В прикрепленном файле список активных служб действую по руководству от предыдущего сисадмина, который заверял что все работает и все просто https://drive.google.com/open?id=1b1Q_ygi9R9ZKyM4zNVX-O_p0U02IU_x1 вот гугл диск руководства (ошибка возникает на пункте 18 создания базы данных) сам оракл и патч ставится без проблем ... |
| 29.03.2019, 10:52:55 |
Alergikfor 32-bit Windows: Version 8.1.7.4.01) Что за ОС? 2) Какого века инструкция? ... |
| 29.03.2019, 11:13:13 |
AlergikДоброго времени суток прошу помощи в решении вопроса При создании базы данных возникает ошибка Ora 12560 Содержание лог файла sqlnet.log Код: plsql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. Содержание файла listener.ora Код: plsql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. Содержание файла sqlnet.ora Код: plsql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. В прикрепленном файле список активных служб действую по руководству от предыдущего сисадмина, который заверял что все работает и все просто https://drive.google.com/open?id=1b1Q_ygi9R9ZKyM4zNVX-O_p0U02IU_x1 вот гугл диск руководства (ошибка возникает на пункте 18 создания базы данных) сам оракл и патч ставится без проблем ORA-12560 - ошибка показываете, что у Вас не запустилась/не создалась служба OracleServiceXXXX Ее кстати и не видно в списке служб. Из под какого Пользователя, и на какой версии windows ОС Вы пытаетесь развернуть Вашу базу? Если Win2008+, то даже под администратором, у Вас не хватает прав, бо когда писалась указанная Вами инструкция, в те благословенные времена, не было такой шайтан заковырки, как UAC (Microsoft Windows User Access Control) Мало того, Oracle8i, не сертифицирован под современные версии MS как вариант, Вы можете создать базу вручную Для этого, откажитесь от создания базы при установке А затем, запустив dbca (DataBase Configuration Assistant) Выбрать в конце галочку "генерации скриптов", но отказаться от немедленного создания базы Пункт 16 в главе "Создание экземпляра базы данных" Вашей инструкции После этого, В %ORACLE_BASE%\admin\XXXX\scripts Вы найдете .bat файл и .sql скрипты создания базы Вас прежде всего интересуют файлы XXXX.bat XXXX.sql Попробуйте вручную выполнить все операции которые описаны в них Создав службу, используя утилиту oradim -sid XXXX -create p.s. Вместо XXXX нужно подставить имя Вашей базы ... |
| 29.03.2019, 11:16:18 |
Vadim Lejnin, вот такая винда, а инструкция к сожалению из прошлого десятилетия ... |
| 29.03.2019, 11:25:04 |
Alergik,вот пользователь, админ он едиснтвенный ... |
| 29.03.2019, 11:29:00 |
Vadim Lejnin, создалась папка с файлами в ней был батник с таким содержанием set ORACLE_SID=MAGICASH C:\oracle\ora81\bin\oradim -new -sid MAGICASH -startmode manual -pfile "C:\oracle\admin\MAGICASH\pfile\initMAGICASH.ora" C:\oracle\ora81\bin\svrmgrl @C:\Documents and Settings\Администратор\Рабочий стол\batbase\MAGICASHrun.sql C:\oracle\ora81\bin\svrmgrl @C:\Documents and Settings\Администратор\Рабочий стол\batbase\MAGICASHrun1.sql C:\oracle\ora81\bin\svrmgrl @C:\Documents and Settings\Администратор\Рабочий стол\batbase\MAGICASHalterTablespace.sql C:\oracle\ora81\bin\oradim -edit -sid MAGICASH -startmode auto и содержание sqlnet .log Fatal NI connect error 12560, connecting to: (DESCRIPTION=(ADDRESS=(PROTOCOL=BEQ)(PROGRAM=oracle)(ARGV0=oracleMAGICASH)(ARGS='(DESCRIPTION=(LOCAL=YES)(ADDRESS=(PROTOCOL=beq)))'))(CONNECT_DATA=(SID=MAGICASH)(CID=(PROGRAM=C:\oracle\ora81\bin\SVRMGRL.EXE)(HOST=COMPUTER-6EECC0)(USER=Administrator)))) VERSION INFORMATION: TNS for 32-bit Windows: Version 8.1.7.4.0 - Production Oracle Bequeath NT Protocol Adapter for 32-bit Windows: Version 8.1.7.4.0 - Production Time: 29-MAR-2019 12:34:50 Tracing not turned on. Tns error struct: nr err code: 0 ns main err code: 12560 TNS-12560: TNS:protocol adapter error ns secondary err code: 0 nt main err code: 530 TNS-00530: Protocol adapter error nt secondary err code: 2 nt OS err code: 0 содержание файла MAGICASHalterTablespace.sql connect internal/oracle alter user system default tablespace TOOLS; alter user system temporary tablespace TEMP; содержание файла MAGICASHrun.sql spool C:\oracle\admin\MAGICASH\create\createdb set echo on connect INTERNAL/oracle startup nomount pfile="C:\oracle\admin\MAGICASH\pfile\initMAGICASH.ora" CREATE DATABASE MAGICASH LOGFILE 'C:\oracle\oradata\MAGICASH\redo01.log' SIZE 1024K, 'C:\oracle\oradata\MAGICASH\redo02.log' SIZE 1024K, 'C:\oracle\oradata\MAGICASH\redo03.log' SIZE 1024K MAXLOGFILES 32 MAXLOGMEMBERS 2 MAXLOGHISTORY 1 DATAFILE 'C:\oracle\oradata\MAGICASH\system01.dbf' SIZE 264M REUSE AUTOEXTEND ON NEXT 10240K MAXDATAFILES 254 MAXINSTANCES 1 CHARACTER SET CL8MSWIN1251 NATIONAL CHARACTER SET CL8MSWIN1251; spool off содержание файла MAGICASHrun1.sql spool C:\oracle\admin\MAGICASH\create\createdb1 set echo on connect INTERNAL/oracle REM ********** ALTER SYSTEM TABLESPACE ********* ALTER TABLESPACE SYSTEM DEFAULT STORAGE ( INITIAL 64K NEXT 64K MINEXTENTS 1 MAXEXTENTS UNLIMITED PCTINCREASE 50); ALTER TABLESPACE SYSTEM MINIMUM EXTENT 64K; REM ********** TABLESPACE FOR ROLLBACK ********** CREATE TABLESPACE RBS DATAFILE 'C:\oracle\oradata\MAGICASH\rbs01.dbf' SIZE 520M REUSE AUTOEXTEND ON NEXT 5120K MINIMUM EXTENT 512K DEFAULT STORAGE ( INITIAL 512K NEXT 512K MINEXTENTS 8 MAXEXTENTS UNLIMITED ); REM ********** TABLESPACE FOR USER ********** CREATE TABLESPACE USERS DATAFILE 'C:\oracle\oradata\MAGICASH\users01.dbf' SIZE 108M REUSE AUTOEXTEND ON NEXT 1280K MINIMUM EXTENT 128K DEFAULT STORAGE ( INITIAL 128K NEXT 128K MINEXTENTS 1 MAXEXTENTS UNLIMITED PCTINCREASE 0); REM ********** TABLESPACE FOR TEMPORARY ********** CREATE TABLESPACE TEMP DATAFILE 'C:\oracle\oradata\MAGICASH\temp01.dbf' SIZE 72M REUSE AUTOEXTEND ON NEXT 640K MINIMUM EXTENT 64K DEFAULT STORAGE ( INITIAL 64K NEXT 64K MINEXTENTS 1 MAXEXTENTS UNLIMITED PCTINCREASE 0) TEMPORARY; REM ********** TABLESPACE FOR Tools ********** CREATE TABLESPACE TOOLS DATAFILE 'C:\oracle\oradata\MAGICASH\tools01.dbf' SIZE 12M REUSE AUTOEXTEND ON NEXT 320K MINIMUM EXTENT 32K DEFAULT STORAGE ( INITIAL 32K NEXT 32K MINEXTENTS 1 MAXEXTENTS UNLIMITED PCTINCREASE 0); REM ********** TABLESPACE FOR INDEX ********** CREATE TABLESPACE INDX DATAFILE 'C:\oracle\oradata\MAGICASH\indx01.dbf' SIZE 58M REUSE AUTOEXTEND ON NEXT 1280K MINIMUM EXTENT 128K DEFAULT STORAGE ( INITIAL 128K NEXT 128K MINEXTENTS 1 MAXEXTENTS UNLIMITED PCTINCREASE 0); CREATE PUBLIC ROLLBACK SEGMENT RBS0 TABLESPACE RBS STORAGE ( OPTIMAL 4096K ); CREATE PUBLIC ROLLBACK SEGMENT RBS1 TABLESPACE RBS STORAGE ( OPTIMAL 4096K ); CREATE PUBLIC ROLLBACK SEGMENT RBS2 TABLESPACE RBS STORAGE ( OPTIMAL 4096K ); CREATE PUBLIC ROLLBACK SEGMENT RBS3 TABLESPACE RBS STORAGE ( OPTIMAL 4096K ); CREATE PUBLIC ROLLBACK SEGMENT RBS4 TABLESPACE RBS STORAGE ( OPTIMAL 4096K ); CREATE PUBLIC ROLLBACK SEGMENT RBS5 TABLESPACE RBS STORAGE ( OPTIMAL 4096K ); CREATE PUBLIC ROLLBACK SEGMENT RBS6 TABLESPACE RBS STORAGE ( OPTIMAL 4096K ); ALTER ROLLBACK SEGMENT "RBS0" ONLINE; ALTER ROLLBACK SEGMENT "RBS1" ONLINE; ALTER ROLLBACK SEGMENT "RBS2" ONLINE; ALTER ROLLBACK SEGMENT "RBS3" ONLINE; ALTER ROLLBACK SEGMENT "RBS4" ONLINE; ALTER ROLLBACK SEGMENT "RBS5" ONLINE; ALTER ROLLBACK SEGMENT "RBS6" ONLINE; alter user sys temporary tablespace TEMP; @C:\oracle\ora81\Rdbms\admin\catalog.sql; @C:\oracle\ora81\Rdbms\admin\catexp7.sql @C:\oracle\ora81\Rdbms\admin\catproc.sql @C:\oracle\ora81\Rdbms\admin\caths.sql connect system/manager @C:\oracle\ora81\sqlplus\admin\pupbld.sql connect INTERNAL/oracle spool off В сухом остатке появилась служба которая не запускается, в DBAM теперь есть база Magicash, при попытке сменить конфигурацию ошибка 12560 и попытке удалить бесконечно долго пытается к ней подключится, что дальше делать пока хз, в дерриктории где должны быть база C:\oracle\oradata\MAGICASH\archive (пусто) ... |
| 29.03.2019, 11:59:01 |
Alergik, Сделайте так: cmd.exe Код: plsql 1. 2. 3. 4. Есть ли ошибки? ... |
| 29.03.2019, 12:15:43 |
Vadim Lejnin,Точка входа не найдена ... |
| 29.03.2019, 13:59:50 |
Судя по всему кривая конфигурация, где-то что-то недоставлено, или осталось от прошлых попыток Проверьте на предмет кривых путей 1) Переменные окружения 2) ветку реестра HKLM\Software\oracle\... ПОпробуйте явно переключиться в ORACLE_HOME и еще раз oracle %ORACLE_SID% Посмотреть сертификацию oracle8.1.7.0 для 2003R2 не могу, бо информацию снесли уже давно ... |
| 29.03.2019, 14:29:58 |
start [/forum/topic.php?desktop=1&fid=52&tid=1882648]: |
41ms |
48ms |
| others: | 230ms |
| total: | 364ms |
