Нет возможности использовать в left join - OR
Как можно переписать запрос, если нет возможности использовать в left join - OR with tb1 as (select 1 a, 2 b, 3 c from dual union all select 4, 5, 6 from dual union all select 7, 8, 9 from dual union select 80, 88, 10 from dual union select 24, 88, 64 from dual union select 733, 88, 10 from dual union select 456, 99, 7575 from dual union select 1001, 90921, 75751 from dual), tb2 as (select 1 a, 2 b , 3 c from dual union select 5, 3, 1 from dual union select 8, 8, 9 from dual union select 73, 88, 10 from dual union select 100, 929, 7575 from dual union select 1001, 9092, 75751 from dual) select tb1.a, tb1.b, tb1.c, tb2.a, tb2.b, tb2.c from tb1 left join tb2 on (tb1.b = tb2.b or tb1.c = tb2.c and tb1.a = tb2.a) ... |
| 13.10.2019, 18:32:05 |
nc1318, есть такой вариант, но правильно ли он будет рабоать : with tb1 as (select 1 a, 2 b, 3 c from dual union all select 4, 5, 6 from dual union all select 7, 8, 9 from dual union select 80, 88, 10 from dual union select 24, 88, 64 from dual union select 733, 88, 10 from dual union select 456, 99, 7575 from dual union select 1001, 90921, 75751 from dual), tb2 as (select 1 a, 2 b , 3 c from dual union select 5, 3, 1 from dual union select 8, 8, 9 from dual union select 73, 88, 10 from dual union select 100, 929, 7575 from dual union select 1001, 9092, 75751 from dual) select * from tb1 left join ( select tb1.a a1, tb1.b b1, tb1.c c1 from tb1 join tb2 on tb1.b = tb2.b union select tb1.a a1, tb1.b b1, tb1.c c1 from tb1 join tb2 on tb1.c = tb2.c and tb1.a = tb2.a ) tb2 on tb2.a1 = tb1.a and tb2.b1 = tb1.b and tb2.c1 = tb1.c ... |
| 13.10.2019, 18:54:23 |
http://www.bugtraq.ru/forum/faq/general/smart-questions.html] RTFM ... |
| 13.10.2019, 20:35:03 |
nc1318нет возможности использовать в left join - OR Это как так? ... |
| 14.10.2019, 14:01:24 |
andrey_anonymousnc1318нет возможности использовать в left join - OR Это как так?Возможно студенту в одно ухо влетело про ограниечение на оракловый синтаксис джоина, а в другое задача на внешнее соединение. ... |
| 14.10.2019, 14:10:09 |
andrey_anonymous, интересно как это можно реализовать ... |
| 14.10.2019, 14:28:58 |
nc1318интересно как это можно реализовать Что реализовать? Запрос из Вашего первого поста вроде работает (Oracle 11), что требуется и что не работает - вот лично мне совершенно не понятно. ... |
| 14.10.2019, 14:31:39 |
nc1318интересно как это можно реализоватьЕсли это спортивный интерес, то любое выражение булевой логики можно реализовать без OR. Если не спортивный, то 21993232 ... |
| 14.10.2019, 14:37:47 |
-2-nc1318интересно как это можно реализоватьЕсли это спортивный интерес, то любое выражение булевой логики можно реализовать без OR. Оно, конечно, действительно: Код: plsql 1. 2. 3. 4. но от ora-01719 на родном оракловом синтаксисе это не спасает :) ... |
| 14.10.2019, 16:21:33 |
andrey_anonymous, Остаётся благодарить небеса, что в подобных случаях засовывание в case спасает. Код: plaintext ... |
| 14.10.2019, 17:27:54 |
КобанчегОстаётся благодарить небеса, что в подобных случаях засовывание в case спасает. Это же не спортивно :) ... |
| 14.10.2019, 17:30:58 |
andrey_anonymousКобанчегзасовывание в case спасает. Это же не спортивно :) Только decode, только хардкор! Код: plsql 1. 2. 3. 4. 5. 6. 7. ... |
| 14.10.2019, 17:40:37 |
Ыщщо один кошмарик Код: plsql 1. 2. 3. 4. 5. 6. ... |
| 14.10.2019, 17:46:56 |
start [/forum/topic.php?desktop=1&fid=52&tid=1881981]: |
39ms |
61ms |
| others: | 200ms |
| total: | 349ms |
