Вылетает установщик Oracle database 12
Всем привет! При инсталяции Oracle database 12 вылетает установщик Файл installActions: Using paramFile: G:\database\install\oraparam.ini Checking monitor: must be configured to display at least 256 colors. Actual 4294967296 Passed The commandline for unzip: G:\database\install\unzip -qqqo ..\stage\Components\oracle.jdk\1.8.0.91.0\1\DataFiles/"*.jar" -d "C:\TEMP\OraInstall2019-11-05_09-59-03PM" INFO: Oracle Universal Installer Version 12.2.0.1.4 INFO: Loading data from: jar:file:/C:/TEMP/OraInstall2019-11-05_09-59-03PM/ext/jlib/installcommons_1.0.0b.jar!/oracle/install/driver/oui/resource/ConfigCommandMappings.xml INFO: Loading beanstore from jar:file:/C:/TEMP/OraInstall2019-11-05_09-59-03PM/ext/jlib/installcommons_1.0.0b.jar!/oracle/install/driver/oui/resource/ConfigCommandMappings.xml INFO: Restoring class oracle.install.driver.oui.ConfigCmdMappings from jar:file:/C:/TEMP/OraInstall2019-11-05_09-59-03PM/ext/jlib/installcommons_1.0.0b.jar!/oracle/install/driver/oui/resource/ConfigCommandMappings.xml INFO: Loading beans from Xml Bean Store. [BeanStoreName:config-data] INFO: Setting value for the property:id in the bean:configcmd INFO: Setting value for the property:platformcmdmap in the bean:configcmd INFO: Setting value for the property:id in the bean:configcmd INFO: Setting value for the property:platformcmdmap in the bean:configcmd INFO: Setting value for the property:id in the bean:configcmd INFO: Setting value for the property:platformcmdmap in the bean:configcmd INFO: Setting value for the property:id in the bean:configcmd INFO: Setting value for the property:platformcmdmap in the bean:configcmd INFO: Setting value for the property:id in the bean:configcmd INFO: Setting value for the property:platformcmdmap in the bean:configcmd INFO: Setting value for the property:id in the bean:configcmd INFO: Setting value for the property:platformcmdmap in the bean:configcmd INFO: Setting value for the property:id in the bean:configcmd INFO: Setting value for the property:platformcmdmap in the bean:configcmd INFO: Setting value for the property:id in the bean:configcmd INFO: Setting value for the property:platformcmdmap in the bean:configcmd INFO: Setting value for the property:id in the bean:configcmd INFO: Setting value for the property:platformcmdmap in the bean:configcmd INFO: Setting value for the property:id in the bean:configcmd INFO: Setting value for the property:platformcmdmap in the bean:configcmd INFO: Setting value for the property:id in the bean:configcmd INFO: Setting value for the property:platformcmdmap in the bean:configcmd INFO: Setting value for the property:id in the bean:configcmd INFO: Setting value for the property:platformcmdmap in the bean:configcmd INFO: Setting value for the property:id in the bean:configcmd INFO: Setting value for the property:platformcmdmap in the bean:configcmd INFO: Setting value for the property:configcmds in the bean:configcmdmappings INFO: Inventory exists: true INFO: oraInst.loc does not exist INFO: Gathering system details... INFO: Gathering system details... INFO: Registering setup bean INFO: Building Flow INFO: Opening bean stores from which the beans can be loaded INFO: Loading beanstore from a given input stream WARNING: Separator for key and value not found for the property:IntelliJ WARNING: Separator for key and value not found for the property:IntelliJ WARNING: Unable to create xml tag for the key:CommonProgramFiles(x86) WARNING: Unable to create xml tag for the key:ProgramFiles(x86) INFO: Translating external format into raw format INFO: No global condition definition found. INFO: Building the flow graph INFO: Loaded state AutoUpdatesOptionsUI INFO: Loaded state UpdatesListUI INFO: Loaded state finishupdates INFO: Building the flow graph INFO: Loaded state prepInstall INFO: Loaded state supportedOSCheck INFO: Loaded state decideOCMInstall INFO: Loaded state autoupdatesDecider INFO: Loaded state preAutoUpdates INFO: Loaded state AutoUpdatesOptionsUI INFO: Loaded state UpdatesListUI INFO: Loaded state getOCMDetails INFO: Loaded state mtsDialog INFO: Loaded state installOptions INFO: Loaded state getWindowsSecureOptionDetails INFO: Loaded state getSystemClass INFO: Loaded state DBTypeSelectionPage INFO: Loaded state RACDBTypeSelectionPage INFO: Loaded state nodeSelectionPage INFO: Loaded state upgradeValidation INFO: Loaded state installType INFO: Loaded state quickInstallPage INFO: Loaded state productLanguage INFO: Loaded state inventoryPage INFO: Loaded state getOracleHome INFO: Loaded state dbEdition INFO: Loaded state configurationType INFO: Loaded state dbIdentifier INFO: Loaded state configurationOption INFO: Loaded state managementOption INFO: Loaded state storageOption INFO: Loaded state recoveryOption INFO: Loaded state selectASMDiskGroups INFO: Loaded state schemaPasswordDialog INFO: Loaded state getPrivilegedOSGroups INFO: Loaded state prereqExecutionDecider INFO: Loaded state performChecks INFO: Loaded state showSummary INFO: Loaded state setup INFO: Loaded state finish INFO: Linking states INFO: State[AutoUpdatesOptionsUI]: route=NO_AUTO_UPDATES; to=installOptions INFO: State[AutoUpdatesOptionsUI]: route=success; to=UpdatesListUI INFO: State[DBTypeSelectionPage]: route=rac_dbcreate; to=RACDBTypeSelectionPage INFO: State[DBTypeSelectionPage]: route=rac_no_dbcreate; to=nodeSelectionPage INFO: State[DBTypeSelectionPage]: route=si_dbcreate; to=installType INFO: State[DBTypeSelectionPage]: route=si_no_dbcreate; to=productLanguage INFO: State[RACDBTypeSelectionPage]: route=admin; to=nodeSelectionPage INFO: State[RACDBTypeSelectionPage]: route=policy; to=installType INFO: State[UpdatesListUI]: route=success; to=installOptions INFO: State[autoupdatesDecider]: route=AUTO_UPDATES_DISABLE; to=installOptions INFO: State[autoupdatesDecider]: route=AUTO_UPDATES_STATE_SKIP; to=installOptions INFO: State[autoupdatesDecider]: route=success; to=preAutoUpdates INFO: Condition of state[autoupdatesDecider]: route=matched; to=installOptions INFO: State[configurationOption]: route=success; to=storageOption INFO: State[configurationType]: route=success; to=dbIdentifier INFO: State[dbEdition]: route=oraclehome_location; to=getWindowsSecureOptionDetails INFO: State[dbIdentifier]: route=success; to=configurationOption INFO: State[decideOCMInstall]: route=ignoreOCM; to=autoupdatesDecider INFO: State[decideOCMInstall]: route=requireOCM; to=getOCMDetails INFO: State[getOCMDetails]: route=success; to=mtsDialog INFO: State[getOracleHome]: route=advanced_yes_createDB_yes; to=configurationType INFO: State[getOracleHome]: route=advanced_yes_inventory_no; to=inventoryPage INFO: State[getOracleHome]: route=advanced_yes_softwareDB_yes; to=prereqExecutionDecider INFO: State[getOracleHome]: route=advanced_yes_upgrade_yes; to=prereqExecutionDecider INFO: State[getPrivilegedOSGroups]: route=success; to=prereqExecutionDecider INFO: State[getSystemClass]: route=desktop_class_yes; to=getWindowsSecureOptionDetails INFO: State[getSystemClass]: route=server_class_yes; to=DBTypeSelectionPage INFO: State[getWindowsSecureOptionDetails]: route=basic_yes; to=quickInstallPage INFO: State[getWindowsSecureOptionDetails]: route=desktop_class_yes; to=quickInstallPage INFO: State[getWindowsSecureOptionDetails]: route=success; to=getOracleHome INFO: State[installOptions]: route=advanced_yes_softwareDB_yes; to=DBTypeSelectionPage INFO: State[installOptions]: route=migrate_yes_clusterware_no; to=upgradeValidation INFO: State[installOptions]: route=migrate_yes_clusterware_yes; to=DBTypeSelectionPage INFO: State[installOptions]: route=system_class; to=getSystemClass INFO: State[installType]: route=advanced_yes; to=productLanguage INFO: State[installType]: route=basic_yes; to=getWindowsSecureOptionDetails INFO: State[inventoryPage]: route=advanced_yes_createDB_yes; to=configurationType INFO: State[inventoryPage]: route=advanced_yes_softwareDB_yes; to=prereqExecutionDecider INFO: State[inventoryPage]: route=basic_yes; to=prereqExecutionDecider INFO: Condition of state[inventoryPage]: route=advanced_yes_createDB_yes; to=configurationType INFO: Condition of state[inventoryPage]: route=advanced_yes_softwareDB_yes; to=prereqExecutionDecider INFO: Condition of state[inventoryPage]: route=basic_yes; to=prereqExecutionDecider INFO: State[managementOption]: route=success; to=recoveryOption INFO: State[mtsDialog]: route=success; to=autoupdatesDecider INFO: State[nodeSelectionPage]: route=create_and_configureDB; to=installType INFO: State[nodeSelectionPage]: route=software_onlyDB; to=productLanguage INFO: State[nodeSelectionPage]: route=upgradeDB; to=upgradeValidation INFO: State[performChecks]: route=success; to=showSummary INFO: State[preAutoUpdates]: route=success; to=AutoUpdatesOptionsUI INFO: State[prepInstall]: route=DOWNLOAD_UPDATES_ONLY; to=AutoUpdatesOptionsUI INFO: State[prepInstall]: route=configTools; to=setup INFO: State[prepInstall]: route=success; to=supportedOSCheck INFO: State[prereqExecutionDecider]: route=executeprereqs; to=performChecks INFO: State[prereqExecutionDecider]: route=ignoreprereqs; to=showSummary INFO: State[productLanguage]: route=productlanguage_yes; to=dbEdition INFO: Condition of state[productLanguage]: route=matched; to=dbEdition INFO: State[quickInstallPage]: route=basic_yes_inventory_no; to=inventoryPage INFO: State[quickInstallPage]: route=basic_yes_inventory_yes; to=prereqExecutionDecider INFO: State[recoveryOption]: route=asm_chosen_asm_not_present; to=schemaPasswordDialog INFO: State[recoveryOption]: route=asm_chosen_asm_present; to=selectASMDiskGroups INFO: State[recoveryOption]: route=asm_not_chosen; to=schemaPasswordDialog INFO: State[schemaPasswordDialog]: route=success; to=prereqExecutionDecider INFO: State[selectASMDiskGroups]: route=success; to=schemaPasswordDialog INFO: State[setup]: route=success; to=finish INFO: State[showSummary]: route=success; to=setup INFO: State[storageOption]: route=success; to=managementOption INFO: State[supportedOSCheck]: route=success; to=decideOCMInstall INFO: State[upgradeValidation]: route=success; to=productLanguage INFO: State[AutoUpdatesOptionsUI]: route=NO_AUTO_UPDATES; to=finishupdates INFO: State[AutoUpdatesOptionsUI]: route=success; to=UpdatesListUI INFO: State[UpdatesListUI]: route=DOWNLOAD_UPDATES_FINISHED; to=finishupdates INFO: Successfully built the flow INFO: loading the beans from bean stores INFO: Loading flow data beans INFO: Loading beans from Properties Bean Store. [BeanStoreName:beanstore] INFO: Setting value for the property:DBInstallSettings in the bean:DBSetupBean INFO: Setting value for the property:CentralInventorySettings in the bean:DBSetupBean INFO: Setting value for the property:PatchInstallSettings in the bean:DBSetupBean INFO: Setting value for the property:RootConfigurationSettings in the bean:DBSetupBean INFO: Setting value for the property:oracle_install_autoupdates_httpProxySettings in the bean:AutoUpdatesInstallSettings INFO: Setting value for the property:oracle_install_autoupdates_myOracleSupportCredentials in the bean:AutoUpdatesInstallSettings INFO: Setting value for the property:AutoUpdatesInstallSettings in the bean:DBSetupBean INFO: Setting value for the property:WindowsSecureOptionSettings in the bean:DBSetupBean INFO: Setting value for the property:OCMSettings in the bean:DBSetupBean INFO: Loading beans from Xml Bean Store. [BeanStoreName:beanstore] INFO: Setting value for the property:oracle_install_db_UseFileSystemForRecovery in the bean:DBInstallSettings INFO: Setting value for the property:oracle_install_db_SuperAdminPasswords in the bean:DBInstallSettings INFO: Setting value for the property:oracle_install_db_managementOption in the bean:DBInstallSettings INFO: Setting value for the property:oracle_install_db_UseSamePassword in the bean:DBInstallSettings INFO: Setting value for the property:oracle_install_db_CharSetOption in the bean:DBInstallSettings INFO: Setting value for the property:oracle_install_db_InstallOptionSelected in the bean:DBInstallSettings INFO: Setting value for the property:oracle_install_db_StorageType in the bean:DBInstallSettings INFO: Setting value for the property:oracle_install_db_ConfigTabSelected in the bean:DBInstallSettings INFO: Setting value for the property:DBInstallSettings in the bean:DBSetupBean INFO: Setting value for the property:CentralInventorySettings in the bean:DBSetupBean INFO: Setting value for the property:oracle_install_autoupdates_httpProxySettings in the bean:AutoUpdatesInstallSettings INFO: Setting value for the property:oracle_install_autoupdates_myOracleSupportCredentials in the bean:AutoUpdatesInstallSettings INFO: Setting value for the property:AutoUpdatesInstallSettings in the bean:DBSetupBean INFO: Setting value for the property:WindowsSecureOptionSettings in the bean:DBSetupBean INFO: Setting value for the property:OCMSettings in the bean:DBSetupBean INFO: Set value for bean DBSetupBean INFO: Loading beans from Properties Bean Store. [BeanStoreName:beanstore] INFO: Loading beans from Xml Bean Store. [BeanStoreName:beanstore] INFO: Loading beans from Properties Bean Store. [BeanStoreName:beanstore] INFO: Loading beans from Xml Bean Store. [BeanStoreName:beanstore] INFO: Loading beans from Properties Bean Store. [BeanStoreName:beanstore] INFO: Setting value for the property:oracle_install_autoupdates_httpProxySettings in the bean:AutoUpdatesInstallSettings INFO: Setting value for the property:oracle_install_autoupdates_myOracleSupportCredentials in the bean:AutoUpdatesInstallSettings INFO: Loading beans from Xml Bean Store. [BeanStoreName:beanstore] INFO: Closing bean stores from which the beans can be loaded INFO: Registering the flow views INFO: Adding View[type: oracle.install.commons.base.interview.common.view.PrereqGUI viewId: null uiType: null] INFO: oracle.install.commons.base.interview.common.view.PrereqGUI added to View Type Registry with the key as [PrereqUI] INFO: Adding View[type: oracle.install.commons.base.interview.common.view.SummaryGUI viewId: null uiType: null] INFO: oracle.install.commons.base.interview.common.view.SummaryGUI added to View Type Registry with the key as [SummaryUI] INFO: Adding View[type: oracle.install.commons.base.interview.common.view.SetupGUI viewId: null uiType: null] INFO: oracle.install.commons.base.interview.common.view.SetupGUI added to View Type Registry with the key as [SetupUI] INFO: Adding View[type: oracle.install.ivw.common.view.InventoryUI viewId: null uiType: null] INFO: oracle.install.ivw.common.view.InventoryUI added to View Type Registry with the key as [InventoryUI] INFO: Adding View[type: oracle.install.ivw.common.view.ProductLanguageGUI viewId: ProductLanguageUI uiType: null] INFO: oracle.install.ivw.common.view.ProductLanguageGUI added to View Type Registry with the key as [ProductLanguageUI] INFO: Adding View[type: oracle.install.ivw.common.view.OCMDetailsGUI viewId: OCMDetailsUI uiType: null] INFO: oracle.install.ivw.common.view.OCMDetailsGUI added to View Type Registry with the key as [OCMDetailsUI] INFO: Adding View[type: oracle.install.ivw.db.view.ConfigurationTypeUI viewId: null uiType: null] INFO: oracle.install.ivw.db.view.ConfigurationTypeUI added to View Type Registry with the key as [ConfigurationTypeUI] INFO: Adding View[type: oracle.install.ivw.db.view.DBIdentifierUI viewId: null uiType: null] INFO: oracle.install.ivw.db.view.DBIdentifierUI added to View Type Registry with the key as [DBIdentifierUI] INFO: Adding View[type: oracle.install.ivw.db.view.ConfigurationOptionsUI viewId: null uiType: null] INFO: oracle.install.ivw.db.view.ConfigurationOptionsUI added to View Type Registry with the key as [ConfigurationOptionsUI] INFO: Adding View[type: oracle.install.ivw.db.view.StorageOptionsUI viewId: null uiType: null] INFO: oracle.install.ivw.db.view.StorageOptionsUI added to View Type Registry with the key as [StorageOptionsUI] INFO: Adding View[type: oracle.install.ivw.db.view.RecoveryBackupUI viewId: null uiType: null] INFO: oracle.install.ivw.db.view.RecoveryBackupUI added to View Type Registry with the key as [RecoveryBackupUI] INFO: Adding View[type: oracle.install.ivw.db.view.ManagementOptionsUI viewId: null uiType: null] INFO: oracle.install.ivw.db.view.ManagementOptionsUI added to View Type Registry with the key as [ManagementOptionsUI] INFO: Adding View[type: oracle.install.ivw.db.view.ASMDiskGroupSelectionGUI viewId: ASMDiskGroupSelectionUI uiType: null] INFO: oracle.install.ivw.db.view.ASMDiskGroupSelectionGUI added to View Type Registry with the key as [ASMDiskGroupSelectionUI] INFO: Adding View[type: oracle.install.ivw.db.view.SchemaPasswordUI viewId: null uiType: null] INFO: oracle.install.ivw.db.view.SchemaPasswordUI added to View Type Registry with the key as [SchemaPasswordUI] INFO: Adding View[type: oracle.install.ivw.db.view.QuickInstallUI viewId: null uiType: null] INFO: oracle.install.ivw.db.view.QuickInstallUI added to View Type Registry with the key as [QuickInstallUI] INFO: Adding View[type: oracle.install.ivw.db.view.InstallOptionsUI viewId: null uiType: null] INFO: oracle.install.ivw.db.view.InstallOptionsUI added to View Type Registry with the key as [InstallOptionsUI] INFO: Adding View[type: oracle.install.ivw.db.view.WindowsSecureOptionUI viewId: WindowsSecureOptionUI uiType: null] INFO: oracle.install.ivw.db.view.WindowsSecureOptionUI added to View Type Registry with the key as [WindowsSecureOptionUI] INFO: Adding View[type: oracle.install.ivw.db.view.SystemClassUI viewId: SystemClassUI uiType: null] INFO: oracle.install.ivw.db.view.SystemClassUI added to View Type Registry with the key as [SystemClassUI] INFO: Adding View[type: oracle.install.ivw.db.view.InstallLocationUI viewId: null uiType: null] INFO: oracle.install.ivw.db.view.InstallLocationUI added to View Type Registry with the key as [InstallLocationUI] INFO: Adding View[type: oracle.install.ivw.db.view.DBEditionGUI viewId: null uiType: null] INFO: oracle.install.ivw.db.view.DBEditionGUI added to View Type Registry with the key as [DBEditionUI] INFO: Adding View[type: oracle.install.ivw.db.view.NodeSelectionUI viewId: null uiType: null] INFO: oracle.install.ivw.db.view.NodeSelectionUI added to View Type Registry with the key as [NodeSelectionUI] INFO: Adding View[type: oracle.install.ivw.db.view.DBTypeSelectionGUI viewId: DBTypeSelectionUI uiType: null] INFO: oracle.install.ivw.db.view.DBTypeSelectionGUI added to View Type Registry with the key as [DBTypeSelectionUI] INFO: Adding View[type: oracle.install.ivw.db.view.RACDBTypeSelectionGUI viewId: RACDBTypeSelectionUI uiType: null] INFO: oracle.install.ivw.db.view.RACDBTypeSelectionGUI added to View Type Registry with the key as [RACDBTypeSelectionUI] INFO: Adding View[type: oracle.install.ivw.db.view.FinishUI viewId: null uiType: null] INFO: oracle.install.ivw.db.view.FinishUI added to View Type Registry with the key as [FinishUI] INFO: Adding View[type: oracle.install.ivw.db.view.PrivilegedOSGroupsGUI viewId: null uiType: null] INFO: oracle.install.ivw.db.view.PrivilegedOSGroupsGUI added to View Type Registry with the key as [PrivilegedOSGroupsUI] INFO: Adding View[type: oracle.install.ivw.db.view.InstallTypeGUI viewId: installTypeUI uiType: null] INFO: oracle.install.ivw.db.view.InstallTypeGUI added to View Type Registry with the key as [installTypeUI] INFO: Adding View[type: oracle.install.ivw.common.view.AutoUpdatesOptionsUI viewId: AutoUpdatesOptionsUI uiType: null] INFO: oracle.install.ivw.common.view.AutoUpdatesOptionsUI added to View Type Registry with the key as [AutoUpdatesOptionsUI] INFO: Adding View[type: oracle.install.ivw.common.view.UpdatesListUI viewId: UpdatesListUI uiType: null] INFO: oracle.install.ivw.common.view.UpdatesListUI added to View Type Registry with the key as [UpdatesListUI] INFO: Adding View[type: oracle.install.ivw.common.view.FinishUpdatesUI viewId: FinishUpdatesUI uiType: null] INFO: oracle.install.ivw.common.view.FinishUpdatesUI added to View Type Registry with the key as [FinishUpdatesUI] INFO: Initial values of Setup Properties : ---------------------------------------------------------------------------------------------------- PROPERTY VALUE ---------------------------------------------------------------------------------------------------- AutoUpdatesInstallSettings oracle.install.ivw.common.bean.AutoUpdates InstallSettings@6bc407fd COLLECTOR_IGNORE_CONFIGURATION false COLLECTOR_IGNORE_FAILURES false COLLECTOR_RESPONSE_FILE CentralInventorySettings oracle.install.ivw.common.bean.CentralInve ntorySettings@181e731e DBInstallSettings oracle.install.ivw.db.bean.DBInstallSettin gs@5a3bc7ed DECLINE_SECURITY_UPDATES true FROM_LOCATION G:\database\install\../stage/products.xml INSTALL_TYPE EE INVENTORY_LOCATION C:\Program Files\Oracle\Inventory MYORACLESUPPORT_PASSWORD *Protected value, not to be logged* MYORACLESUPPORT_USERNAME OCMSettings oracle.install.ivw.common.bean.OCMSettings @16eccb2e ORACLE_BASE ORACLE_HOME ORACLE_HOSTNAME DESKTOP-LMADSQ8 PROXY_HOST PROXY_PORT PROXY_PWD *Protected value, not to be logged* PROXY_USER PatchInstallSettings oracle.install.ivw.common.bean.PatchInstal lSettings@35645047 RootConfigurationSettings oracle.install.ivw.common.bean.RootConfigu rationSettings@6f44a157 SECURITY_UPDATES_VIA_MYORACLESUPPORT true SELECTED_LANGUAGES {"en"} UNIX_GROUP_NAME WindowsSecureOptionSettings oracle.install.ivw.common.bean.WindowsSecu reOptionSettings@5ddcc487 b_rdbmsInstall true oracle.install.db.isCCRAuthenticationUsed false oracle_install_IsBuiltInAccount false oracle_install_IsOracleServiceUserExists false oracle_install_IsVirtualAccount false oracle_install_NoMigration false oracle_install_OCR_PartitionLocation oracle_install_ProductName oracle_install_RACInstall false oracle_install_RDBMSInstalling true oracle_install_autoupdates_httpProxyPort 0 oracle_install_autoupdates_httpProxySettings oracle.install.ivw.common.bean.HttpProxySe ttings@291f18 oracle_install_autoupdates_myOracleSupportCredentials oracle.install.ivw.common.bean.MyOracleSup portSettings@17d88132 oracle_install_db_ASMSNMPUserPassword *Protected value, not to be logged* oracle_install_db_AutoMemoryOption false oracle_install_db_CharSetOption 3 oracle_install_db_CharacterSet oracle_install_db_ConfigTabSelected 0 oracle_install_db_ConfigurationType &General Purpose / Transaction Processing oracle_install_db_ConfigureAsContainerDB false oracle_install_db_DiskGroupName oracle_install_db_DiskGroupNameForASM oracle_install_db_EnableAutoBackup false oracle_install_db_InstallEdition EE oracle_install_db_InstallOption INSTALL_DB_AND_CONFIG oracle_install_db_InstallOptionSelected 1 oracle_install_db_InstallType EE oracle_install_db_LaunchDBCA false oracle_install_db_LaunchNETCA false oracle_install_db_LaunchODMA false oracle_install_db_LoadExampleSchemas false oracle_install_db_MountPointLocation oracle_install_db_QuickInstallOption false oracle_install_db_RecoveryBackUpLocation oracle_install_db_SID oracle_install_db_ServerPoolCardinality 0 oracle_install_db_SetOracleBase false oracle_install_db_SkipHARegistration false oracle_install_db_StarterDatabaseType GENERAL_PURPOSE oracle_install_db_StorageType 0 oracle_install_db_SuperAdminPasswords *Protected value, not to be logged* oracle_install_db_SuperAdminSamePasswdForAll *Protected value, not to be logged* oracle_install_db_SystemClass DESKTOP_CLASS oracle_install_db_Type 1 oracle_install_db_UseFileSystemForRecovery false oracle_install_db_UseSamePassword false oracle_install_db_isRACOneInstall false oracle_install_db_managementOption DEFAULT oracle_install_db_nodeList {} oracle_install_db_omsPort 0 oracle_install_db_racOneServiceName oracle_install_rootConfiguration_ExecuteRootScript false ---------------------------------------------------------------------------------------------------- INFO: Launching Oracle Database 12c Release 2 Installer INFO: Started executing the flow in INTERACTIVE mode INFO: Executing initialize action at state prepInstall INFO: Completed executing initialize action at state <prepInstall> INFO: Waiting for completion of background operations INFO: Finishing all forked tasks at state prepInstall INFO: Waiting for completion all forked tasks at state prepInstall INFO: All forked task are completed at state prepInstall INFO: Completed background operations INFO: Waiting for completion of background operations INFO: Completed background operations INFO: Executing action at state prepInstall INFO: Completed executing action at state <prepInstall> INFO: Waiting for completion of background operations INFO: Completed background operations INFO: Waiting for completion of background operations INFO: Completed background operations INFO: Moved to state <prepInstall> INFO: Waiting for completion of background operations INFO: Completed background operations INFO: Validating view at state <prepInstall> INFO: Completed validating view at state <prepInstall> INFO: Validating state <prepInstall> INFO: Completed validating state <prepInstall> INFO: Verifying route success INFO: Checking condition at state <autoupdatesDecider> INFO: Successfully checked condition at state <autoupdatesDecider> INFO: Condition matched at state <autoupdatesDecider>. INFO: Redirecting to route <matched>. INFO: Executing initialize action at state supportedOSCheck INFO: Completed executing initialize action at state <supportedOSCheck> INFO: Waiting for completion of background operations INFO: Completed background operations INFO: Waiting for completion of background operations INFO: Completed background operations INFO: Executing action at state supportedOSCheck INFO: Loaded prereq XML file is: G:\database\stage\cvu\cvu_prereq.xml INFO: Completed executing action at state <supportedOSCheck> INFO: Waiting for completion of background operations INFO: Completed background operations INFO: Waiting for completion of background operations INFO: Completed background operations INFO: Moved to state <supportedOSCheck> INFO: Waiting for completion of background operations INFO: Completed background operations INFO: Validating view at state <supportedOSCheck> INFO: Completed validating view at state <supportedOSCheck> INFO: Validating state <supportedOSCheck> INFO: Verifying target environment... INFO: Checking whether the IP address of the localhost could be determined... INFO: Completed verification of target environment. INFO: Verifying setup for installer validations INFO: Completed validating state <supportedOSCheck> INFO: Verifying route success INFO: Checking condition at state <autoupdatesDecider> INFO: Successfully checked condition at state <autoupdatesDecider> INFO: Condition matched at state <autoupdatesDecider>. INFO: Redirecting to route <matched>. INFO: Executing initialize action at state decideOCMInstall INFO: Completed executing initialize action at state <decideOCMInstall> INFO: Waiting for completion of background operations INFO: Completed background operations INFO: Waiting for completion of background operations INFO: Completed background operations INFO: Executing action at state decideOCMInstall INFO: Completed executing action at state <decideOCMInstall> INFO: Waiting for completion of background operations INFO: Completed background operations INFO: Waiting for completion of background operations INFO: Completed background operations INFO: Moved to state <decideOCMInstall> INFO: Waiting for completion of background operations INFO: Completed background operations INFO: Validating view at state <decideOCMInstall> INFO: Completed validating view at state <decideOCMInstall> INFO: Validating state <decideOCMInstall> WARNING: Validation disabled for the state decideOCMInstall INFO: Completed validating state <decideOCMInstall> INFO: Verifying route requireOCM INFO: Checking condition at state <autoupdatesDecider> INFO: Successfully checked condition at state <autoupdatesDecider> INFO: Condition matched at state <autoupdatesDecider>. INFO: Redirecting to route <matched>. INFO: Get view named [OCMDetailsUI] INFO: View for [OCMDetailsUI] is oracle.install.ivw.common.view.OCMDetailsGUI@319f18ff INFO: Executing initialize action at state getOCMDetails INFO: Completed executing initialize action at state <getOCMDetails> INFO: Waiting for completion of background operations INFO: Completed background operations INFO: Initializing view <OCMDetailsUI> at state <getOCMDetails> INFO: Completed initializing view <OCMDetailsUI> at state <getOCMDetails> INFO: Displaying view <OCMDetailsUI> at state <getOCMDetails> INFO: Completed displaying view <OCMDetailsUI> at state <getOCMDetails> INFO: Loading view <OCMDetailsUI> at state <getOCMDetails> INFO: Completed loading view <OCMDetailsUI> at state <getOCMDetails> INFO: Localizing view <OCMDetailsUI> at state <getOCMDetails> INFO: Completed localizing view <OCMDetailsUI> at state <getOCMDetails> INFO: Waiting for completion of background operations INFO: Completed background operations INFO: Executing action at state getOCMDetails INFO: Completed executing action at state <getOCMDetails> INFO: Waiting for completion of background operations INFO: Completed background operations INFO: Waiting for completion of background operations INFO: Completed background operations INFO: Moved to state <getOCMDetails> INFO: Pause Oracle Database 12c Release 2 Installer INFO: Resume Oracle Database 12c Release 2 Installer INFO: Adding ExitStatus USER_CANCELLED_INSTALL to the exit status set INFO: Finding the most appropriate exit status for the current application INFO: Exit Status is 4 INFO: Shutdown Oracle Database 12c Release 2 Installer INFO: Unloading Setup Driver ... |
| 07.11.2019, 20:25:56 |
насколько я помню при установки субд инсталятор приводит тест системы и оповещает , что в системе ему не нравится. и какой у вас комп (техн характеристики) ... |
| 13.11.2019, 02:04:24 |
RAISEROS, авторWARNING: Unable to create xml tag for the key:CommonProgramFiles(x86)12 не для 32-битных ОС ... |
| 13.11.2019, 08:33:53 |
Siemargl авторCommonProgramFiles(x86) ... |
| 13.11.2019, 13:33:29 |
RAISEROS INFO: Pause Oracle Database 12c Release 2 Installer INFO: Resume Oracle Database 12c Release 2 Installer INFO: Adding ExitStatus USER_CANCELLED_INSTALL to the exit status set ... |
| 13.11.2019, 13:38:10 |
Siemargl RAISEROS, авторWARNING: Unable to create xml tag for the key:CommonProgramFiles(x86) https://docs.oracle.com/database/121/NTCLI/pre_install.htm#NTCLI1245 ... |
| 14.11.2019, 01:31:57 |
start [/forum/topic.php?desktop=1&fid=52&tid=1881865]: |
23ms |
44ms |
| others: | 192ms |
| total: | 292ms |
