Гетероген oracle to mssql
Знаю что тема много раз поднималась, весь форум уже перерыл и инет в том числе. Имеем unixODBC freetds oracle 11 solaris 10 mssql 2008 -bash-3.2# cat /etc/odbcinst.ini [FreeTDS] Driver=/usr/local/lib/libtdsodbc.so client charset=utf-8 UsageCount=23 -bash-3.2# cat /etc/odbc.ini [MyMSSQL] Driver=FreeTDS Servername=MyMSSQL TDS_Version=8.0 Database=BPMonline UID=IBSOUser PWD=IBSOUser CHARSET=utf8 -bash-3.2# cat /usr/local/etc/freetds.conf [MyMSSQL] host = srv-mssql port = 1433 tds version = 8.0 client charset = UTF-8 dump file = /tmp/freetds.log dump file append = yes -bash-3.2# isql -v MyMSSQL IBSOUser IBSOUser +---------------------------------------+ | Connected! | | | | sql-statement | | help [tablename] | | quit | | | +---------------------------------------+ SQL> select count(*) from contact; +------------+ | | +------------+ | 43 | +------------+ SQLRowCount returns 1 1 rows fetched SQL> до этого все как бы хорошо а вот oracle подключаться никак не хочет: -bash-3.2# cat /u/app/oracle/product/11.2.0/db_1/hs/admin/initMyMSSQL.ora HS_FDS_CONNECT_INFO=MyMSSQL HS_FDS_SHAREABLE_NAME = /usr/local/lib/libtdsodbc.so HS_FDS_TRACE_LEVEL=255 set ODBCINI = /etc/odbc.ini set ODBCINSTINI = /etc/odbcinst.ini #HS_LANGUAGE=AMERICAN_AMERICA.UTF8 HS_LANGUAGE=RUSSIAN_RUSIA.UTF8 #HS_FDS_SQLLEN_INTERPRETATION=32 -bash-3.2# cat /u/app/oracle/product/11.2.0/db_1/network/admin/listener.ora HS = (ADDRESS_LIST = (ADDRESS= (PROTOCOL= TCP)(Host= 192.168.2.47 )(Port= 1522)) (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROCHS)) ) SID_LIST_HS = (SID_LIST = (SID_DESC = (PROGRAM=dg4odbc) (SID_NAME = MyMSSQL) (ORACLE_HOME = /u/app/oracle/product/11.2.0/db_1/) (ENVS="LD_LIBRARY_PATH=/u/app/oracle/product/11.2.0/db_1/lib:/usr/lib:/usr/local/lib/sparcv9/:/usr/local/lib:/usr/openwin/lib:/usr/dt/lib") ) ) CONNECT_TIMEOUT_HS = 10 INBOUND_CONNECT_TIMEOUT_HS = 0 STARTUP_WAIT_TIME_HS = 0 sun04.oracle> tnsping MyMSSQL TNS Ping Utility for Solaris: Version 11.2.0.3.0 - Production on 19-JUL-2014 12:19:27 Copyright (c) 1997, 2011, Oracle. All rights reserved. Used parameter files: /u/app/oracle/product/11.2.0/db_1/network/admin/sqlnet.ora Used TNSNAMES adapter to resolve the alias Attempting to contact (DESCRIPTION = (ADDRESS = (PROTOCOL = TCP)(HOST = 192.168.2.47)(PORT = 1522)) (CONNECT_DATA = (SID = MyMSSQL) (SERVICE_NAME = MyMSSQL)) (HS = OK)) OK (10 msec) При попытке сделать заброс из дблинка получаем: SQL> select count(*) from "Contact"@dl_terrasoft; select count(*) from "Contact"@dl_terrasoft * ERROR at line 1: ORA-28500: connection from ORACLE to a non-Oracle system returned this message: ORA-02063: preceding line from DL_TERRASOFT Кусок трассировки: Exiting hgolofns at 2014/07/19-10:51:22 Failed to load ODBC library symbol: /usr/local/lib/libtdsodbc.so(SQLDescribeParam) Exiting hgolofn, rc=28500 at 2014/07/19-10:51:22 Exiting hgoinit, rc=28500 with error ptr FILE:hgoinit.c LINE:420 ID:Loading ODBC aray of function ptrs hostmstr: 61480960: HOA After hoainit RPC Calling nscontrol(0), rc=0 hostmstr: 61497344: RPC Before Exit Agent hostmstr: 61513728: HOA Before hoaexit Entered hgoexit HS Gateway: NULL connection context at exit Exiting hgoexit, rc=0 with error ptr FILE:hgoexit.c LINE:110 ID:Connection context hostmstr: 61530112: HOA After hoaexit hostmstr: 61546496: RPC After Exit Agent тут вроде все красиво: sun04.oracle> file "/usr/local/lib/libtdsodbc.so" /usr/local/lib/libtdsodbc.so: ELF 64-bit MSB dynamic lib SPARCV9 Version 1, dynamically linked, not stripped, no debugging information available sun04.oracle> ldd "/usr/local/lib/libtdsodbc.so" libodbcinst.so.2 => /usr/local/lib/libodbcinst.so.2 libthread.so.1 => /lib/64/libthread.so.1 libnsl.so.1 => /lib/64/libnsl.so.1 libsocket.so.1 => /lib/64/libsocket.so.1 libc.so.1 => /lib/64/libc.so.1 libgcc_s.so.1 => /usr/local/lib/sparcv9//libgcc_s.so.1 libmp.so.2 => /lib/64/libmp.so.2 libmd.so.1 => /lib/64/libmd.so.1 libscf.so.1 => /lib/64/libscf.so.1 libdoor.so.1 => /lib/64/libdoor.so.1 libuutil.so.1 => /lib/64/libuutil.so.1 libgen.so.1 => /lib/64/libgen.so.1 libm.so.2 => /lib/64/libm.so.2 /lib/sparcv9/../libm/sparcv9/libm_hwcap1.so.2 /platform/sun4v/lib/sparcv9/libc_psr.so.1 /platform/sun4v/lib/sparcv9/libmd_psr.so.1 sun04.oracle> sun04.oracle> file /u/app/oracle/product/11.2.0/db_1/bin/dg4odbc /u/app/oracle/product/11.2.0/db_1/bin/dg4odbc: ELF 64-bit MSB executable SPARCV9 Version 1, dynamically linked, not stripped перепробовал несколько версий freetds и unixODBC эффекта нет Раньше уже встречал подобную проблему на linux там решалось установкой других вариантов ODBC. На солярке для подключения к mssql не знаю что можно еще использовать кроме freetds. ... |
| 19.07.2014, 12:31:36 |
SuperMultikHS_FDS_SHAREABLE_NAME = /usr/local/lib/libtdsodbc.so Здесь лучше указывать не непосредственно драйвер, а ODBC Manager, который способен согласовать версии интерфейса драйвера и приложения. Пиши тут libodbc.so. Posted via ActualForum NNTP Server 1.5 ... |
| 19.07.2014, 12:45:25 |
При таком варианте не силльно лучше получается SQL> select count(*) from "Contact"@dl_terrasoft; select count(*) from "Contact"@dl_terrasoft * ERROR at line 1: ORA-28500: connection from ORACLE to a non-Oracle system returned this message: [unixODBC][Driver Manager]Data source name not found, and no default driver specified {IM002} ORA-02063: preceding 2 lines from DL_TERRASOFT SQL> Exiting hgogenconstr, rc=0 at 2014/07/19-13:09:17 Entered hgopoer at 2014/07/19-13:09:17 hgopoer, line 231: got native error 0 and sqlstate IM002; message follows... [unixODBC][Driver Manager]Data source name not found, and no default driver specified {IM002} Exiting hgopoer, rc=0 at 2014/07/19-13:09:17 hgocont, line 2754: calling SqlDriverConnect got sqlstate IM002 Exiting hgocont, rc=28500 at 2014/07/19-13:09:17 with error ptr FILE:hgocont.c LINE:2774 ID:Something other than invalid authorization Exiting hgolgon, rc=28500 at 2014/07/19-13:09:17 with error ptr FILE:hgolgon.c LINE:801 ID:Calling hgocont ... |
| 19.07.2014, 13:10:34 |
sun04.oracle> cat /u/app/oracle/product/11.2.0/db_1/hs/admin/initMyMSSQL.ora HS_FDS_CONNECT_INFO=MyMSSQL #HS_FDS_SHAREABLE_NAME = /usr/local/lib/libtdsodbc.so HS_FDS_SHAREABLE_NAME = /usr/local/lib/libodbc.so HS_FDS_TRACE_LEVEL=255 set ODBCINI = /etc/odbc.ini set ODBCINSTINI = /etc/odbcinst.ini #HS_LANGUAGE=AMERICAN_AMERICA.UTF8 HS_LANGUAGE=RUSSIAN_RUSIA.UTF8 #HS_FDS_SQLLEN_INTERPRETATION=32 ... |
| 19.07.2014, 13:11:50 |
SuperMultikData source name not found Ну, не находит он DSN с каким-то именем. Врубай трассировку ODBC если таковая есть и смотри какое имя от него Оракул хочет. Posted via ActualForum NNTP Server 1.5 ... |
| 19.07.2014, 13:51:13 |
SuperMultikПри таком варианте не сильно лучше получается Я использую unix ODBC oт EasySoft, но сути это не меняет. В listener ENVS кроме ODBC библиотек надо еще прописывать environment variables для ODBC. В моем случае: ENVS="LD_LIBRARY_PATH=/himhqa02/oracle/product/11.1.0/lib:/himhqa02/apps/easysoft/lib:/himhqa02/apps/easysoft/unixODBC/lib:/himhqa02/apps/easysoft/sqlserver,ODBCSYSINI=/himhqa02/apps/odbc,EASYSOFT_ROOT=/himhqa02/apps/easysoft" SY. ... |
| 19.07.2014, 17:12:07 |
ну да не находит DSN он именно с libodbc.so трассировка ODBC вроде как включена только файл создается исключительно при пользовании isql, при запросах через dg4odbc в лог ничего не пишется. поставил ODBCSYSINI, изменений никаких. ... |
| 19.07.2014, 21:26:19 |
SuperMultik, ODBSSYSINI и EASYSOFT_ROOT это у EasySoft ODBC for Unix а какие у unixODBC freetds это ты и должен выяснить. SY. ... |
| 19.07.2014, 21:31:25 |
SuperMultikпри запросах через dg4odbc в лог ничего не пишется. Значит он работает от такой учётки или с такими переменными окружения, что не может найти твой odbc.ini. Posted via ActualForum NNTP Server 1.5 ... |
| 19.07.2014, 21:52:27 |
https://community.oracle.com/thread/2221685?tstart=0 Posted via ActualForum NNTP Server 1.5 ... |
| 19.07.2014, 21:59:55 |
не понятно почему не находит в initMyMSSQL.ora четко же прописано set ODBCINI=/etc/odbc.ini set ODBCINSTINI=/etc/odbcinst.ini и если ставить библиотеку libtdsodbc.so то вроде как находит ну и еще до кучи в .profile прописано export ODBCSYSINI=/etc export ODBCINI=/etc/odbc.ini тут тоже добавил sun04.oracle> cat /u/app/oracle/product/11.2.0/db_1/network/admin/listener.ora HS = (ADDRESS_LIST = (ADDRESS= (PROTOCOL= TCP)(Host= 192.168.2.47 )(Port= 1522)) (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROCHS)) ) SID_LIST_HS = (SID_LIST = (SID_DESC = (PROGRAM=dg4odbc) (SID_NAME = MyMSSQL) (ORACLE_HOME = /u/app/oracle/product/11.2.0/db_1/) (ENVS="LD_LIBRARY_PATH=/u/app/oracle/product/11.2.0/db_1/lib:/usr/lib:/usr/local/lib/sparcv9/:/usr/local/lib:/usr/openwin/lib:/usr/dt/lib,ODBCSYSINI=/etc,ODBCINI=/etc/odbc.ini,ODBCINSTINI=/etc/odbcinst.ini") ) ) CONNECT_TIMEOUT_HS = 10 INBOUND_CONNECT_TIMEOUT_HS = 0 STARTUP_WAIT_TIME_HS = 0 эффекта никакого нет SQL> select count(*) from "Contact"@dl_terrasoft; select count(*) from "Contact"@dl_terrasoft * ERROR at line 1: ORA-28500: connection from ORACLE to a non-Oracle system returned this message: [unixODBC][Driver Manager]Data source name not found, and no default driver specified {IM002} ORA-02063: preceding 2 lines from DL_TERRASOFT ... |
| 20.07.2014, 08:50:30 |
с библиотекой тоде все нормально вроде sun04.oracle> file /usr/local/lib/libodbc.so /usr/local/lib/libodbc.so: ELF 64-bit MSB dynamic lib SPARCV9 Version 1, dynamically linked, not stripped, no debugging information available sun04.oracle> ldd /usr/local/lib/libodbc.so libthread.so.1 => /lib/64/libthread.so.1 libc.so.1 => /lib/64/libc.so.1 libgcc_s.so.1 => /usr/local/lib/sparcv9//libgcc_s.so.1 libm.so.2 => /lib/64/libm.so.2 /lib/sparcv9/../libm/sparcv9/libm_hwcap1.so.2 /platform/sun4v/lib/sparcv9/libc_psr.so.1 что то с strace ничего не выходит, файл лога не создается -bash-3.2# ps -Af |grep hs oracle 1845 1 0 Jul 19 ? 0:01 /u/app/oracle/product/11.2.0/db_1/bin/tnslsnr hs -inherit -bash-3.2# strace -fae -o /tmp/dg4odbc.log -p 1845 что не так делаю? ... |
| 20.07.2014, 09:12:47 |
1) Какой разрядности у тебя Oracle? 2) ls -l /etc/odbc.ini Posted via ActualForum NNTP Server 1.5 ... |
| 20.07.2014, 11:50:15 |
sun04.oracle> uname -a SunOS sun04 5.10 Generic_147440-19 sun4v sparc sun4v Oracle Database 11g Enterprise Edition Release 11.2.0.3.0 - 64bit Production -bash-3.2# ls -l /etc/odbc.ini -rw-rw-r-- 1 root root 119 Jul 19 09:29 /etc/odbc.ini ... |
| 20.07.2014, 13:02:35 |
в общем проблему решил в солярке аналог strace truss -fae -o /tmp/dg4odbc.log -p 1845 проблема была вот в чем: 19532/1: open("/etc//etc/odbcinst.ini", O_RDONLY) Err#2 ENOENT 19532/1: open("/etc//etc/odbcinst.ini", O_RDWR|O_CREAT|O_TRUNC, 0666) Err#2 ENOENT 19532/1: time() = 1406111184 19532/1: open("/etc//etc/odbcinst.ini", O_RDONLY) Err#2 ENOENT 19532/1: open("/etc//etc/odbcinst.ini", O_RDWR|O_CREAT|O_TRUNC, 0666) Err#2 ENOENT ... |
| 23.07.2014, 14:38:19 |
Наткнулся еще на одну проблему: SQL> select "Name" from "Contact"@dl_terrasoft limit 10; select "Name" from "Contact"@dl_terrasoft limit 10 * ERROR at line 1: ORA-00933: SQL command not properly ended SQL> select "Name" from "Contact"@dl_terrasoft; ERROR: ORA-28511: lost RPC connection to heterogeneous remote agent using SID=ORA-28511: lost RPC connection to heterogeneous remote agent using SID=(DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=192.168.2.47)(PORT=1522))(CONNECT_ DATA=(SID=MyMSSQL)(SERVICE_NAME=MyMSSQL))) ORA-02063: preceding line from DL_TERRASOFT Process ID: 1469 Session ID: 449 Serial number: 51117 no rows selected при этом SQL> select count(*) from "Contact"@dl_terrasoft; COUNT(*) ---------- 45 никаких фаерволов между серверами нет sun04.oracle> cat /u/app/oracle/product/11.2.0/db_1/network/admin/listener.ora CONNECT_TIMEOUT_LISTENER = 10 INBOUND_CONNECT_TIMEOUT_LISTENER = 0 STARTUP_WAIT_TIME_LISTENER = 0 HS = (ADDRESS_LIST = (ADDRESS= (PROTOCOL= TCP)(Host= 192.168.2.47 )(Port= 1522)) (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROCHS)) ) SID_LIST_HS = (SID_LIST = (SID_DESC = (PROGRAM=dg4odbc) (SID_NAME = MyMSSQL) (ORACLE_HOME = /u/app/oracle/product/11.2.0/db_1/) (ENVS="LD_LIBRARY_PATH=/u/app/oracle/product/11.2.0/db_1/lib:/usr/lib:/usr/local/lib/sparcv9/:/usr/local/lib:/usr/openwin/lib:/usr/dt/lib,ODBCSYSINI=/etc,ODBCINI=/etc/odbc.ini,ODBCINSTINI=/etc/odbcinst.ini") ) ) SAVE_CONFIG_ON_STOP_LISTENER = TRUE TRACE_LEVEL_LISTENER = OFF DIRECT_HANDOFF_TTC_LISTENER=OFF USE_CKPFILE_LISTENER = OFF может кто сталкивался с похожей проблемой? трейс прикрепил в файле ... |
| 25.07.2014, 21:28:53 |
извиняюсь конечно же: CONNECT_TIMEOUT_HS = 10 INBOUND_CONNECT_TIMEOUT_HS = 0 STARTUP_WAIT_TIME_HS = 0 HS = (ADDRESS_LIST = (ADDRESS= (PROTOCOL= TCP)(Host= 192.168.2.47 )(Port= 1522)) (ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROCHS)) ) SID_LIST_HS = (SID_LIST = (SID_DESC = (PROGRAM=dg4odbc) (SID_NAME = MyMSSQL) (ORACLE_HOME = /u/app/oracle/product/11.2.0/db_1/) (ENVS="LD_LIBRARY_PATH=/u/app/oracle/product/11.2.0/db_1/lib:/usr/lib:/usr/local/lib/sparcv9/:/usr/local/lib:/usr/openwin/lib:/usr/dt/lib,ODBCSYSINI=/etc,ODBCI NI=/etc/odbc.ini,ODBCINSTINI=/etc/odbcinst.ini") ) ) SAVE_CONFIG_ON_STOP_HS = TRUE TRACE_LEVEL_HS = OFF DIRECT_HANDOFF_TTC_HS=OFF USE_CKPFILE_HS = OFF но это к сожалению никак не повлияло на результат ... |
| 25.07.2014, 21:41:32 |
мне помогло HS_FDS_SUPPORT_STATISTICS = FALSE ... |
| 25.07.2014, 21:50:06 |
предыдущий параметр был ни при чем решилось все так: HS_FDS_FETCH_ROWS=1 ... |
| 25.07.2014, 22:00:28 |
Здравствуйте, помогите решить ту же проблему. Понял, что самому уже не разобраться. Есть Oracle под Linux 11.2.0.4 нужен DBLINK с MSSQL2012 Всё по инструкции Драйвера и freetds и Microsoft ODBC Driver for SQL Server cat /etc/odbc.ini [MSSQLDSN] Description = MSSQL SERVER Driver = FreeTDS ;Driver = MSSQL17 Trace = No Servername = MEDSQL Database = MYDB Port = 1433 ;TDS version = 1 [MSSQLDSN2] Description = MSSQL SERVER Driver = MSSQL17 Trace = No Server = tcp:mssql.dom ,1433 Database = MYDB Оба варианта работают. #isql -v MSSQLDSN #isql -v MSSQLDSN2 Дохожу до создания DBLINK cat $ORACLE_HOME/HS/admin/initMSSQL.ora HS_FDS_CONNECT_INFO = MSSQLDSN HS_FDS_TRACE_LEVEL = 0 #HS_FDS_TRACE_FILE_NAME = /tmp/dg4odbc.trc HS_FDS_SHAREABLE_NAME = /usr/lib64/libodbc.so set ODBCINI = /etc/odbc.ini set ODBCINSTINI = /etc/odbcinst.ini listneter.ora SID_LIST_LISTENER = (SID_LIST = (SID_DESC = (SID_NAME = PLSExtProc) (ORACLE_HOME = /oracle/base/product) (PROGRAM = extproc) ) (SID_DESC = (SID_NAME = MSSQL) (ORACLE_HOME = /oracle/base/product) (PROGRAM = dg4odbc) (ENVS=LD_LIBRARY_PATH = /oracle/base/product/lib:/lib64:/usr/lib64:/lib:/usr/lib:/etc/freetds/lib) ) ) tnsnames.ora TEST = (DESCRIPTION = (ADDRESS_LIST = (ADDRESS = (PROTOCOL = TCP)(HOST = localhost)(PORT = 1521)) ) (CONNECT_DATA = (SID = MSSQL)) (HS = OK) ) SQL> create database link HSLINK connect to "user" identified by "password" using 'TEST'; При тесте получаю вышеупомянутую в этой теме ошибку ORA-28500: соединение ORACLE с посторонней системой выдало сообщение: [unixODBC][Driver Manager]Data source name {I} ORA-02063: предшествующий 2 lines из HSLINK Я так понимаю, что под oracle он не может обнаружить ODBC драйвера? При этом под пользователем oracle работает #isql -v MSSQLDSN #isql -v MSSQLDSN2 [oracle@host ~]$ odbcinst -j unixODBC 2.3.1 DRIVERS............: /etc/odbcinst.ini SYSTEM DATA SOURCES: /etc/odbc.ini FILE DATA SOURCES..: /etc/ODBCDataSources USER DATA SOURCES..: /home/oracle/.odbc.ini SQLULEN Size.......: 8 SQLLEN Size........: 8 SQLSETPOSIROW Size.: 8 Я уже честно говоря за неделю запутался совсем, нужен взгляд со стороны. Спасибо. ... |
| 26.03.2020, 09:53:10 |
Давно уже не настраивал, могу ошибаться, но Код: powershell 1. это должно быть имя ODBC-соединения. [MSSQLDSN] ... |
| 26.03.2020, 10:09:02 |
dmdmdm, Первоначально так и было listener (SID_NAME = MSSQLDSN) tnsnames (CONNECT_DATA = (SID = MSSQLDSN)) Результат тот же. файл в hs/admin и initMSSQLDSN.ora и initMSSQL.ora уже столько вариантов перепробовал, поэтому показал финальный ... |
| 26.03.2020, 10:22:35 |
Я забил на общесистемные настройки FreeTDS и прописал локальные в $ORACLE_HOME/hs/admin/ initmssql1c.ora Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. odbc.ini Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. ... |
| 26.03.2020, 10:40:06 |
не совсем понятно в чём же была проблема выше и как решилась SuperMultik, в общем проблему решил в солярке аналог strace truss -fae -o /tmp/dg4odbc.log -p 1845 проблема была вот в чем: 19532/1: open("/etc//etc/odbcinst.ini", O_RDONLY) Err#2 ENOENT 19532/1: open("/etc//etc/odbcinst.ini", O_RDWR|O_CREAT|O_TRUNC, 0666) Err#2 ENOENT 19532/1: time() = 1406111184 19532/1: open("/etc//etc/odbcinst.ini", O_RDONLY) Err#2 ENOENT 19532/1: open("/etc//etc/odbcinst.ini", O_RDWR|O_CREAT|O_TRUNC, 0666) Err#2 ENOENT ... |
| 26.03.2020, 10:43:36 |
SuperMultik, -bash-3.2# cat /etc/odbc.ini [MyMSSQL] Driver=FreeTDS Servername=MyMSSQL <- заменить на TDSMSSQL TDS_Version=8.0 Database=BPMonline UID=IBSOUser PWD=IBSOUser CHARSET=utf8 -bash-3.2# cat /usr/local/etc/freetds.conf [MyMSSQL] <- попробовать заменить на TDSMSSQL host = srv-mssql port = 1433 tds version = 8.0 ... |
| 26.03.2020, 10:48:47 |
start [/forum/topic.php?desktop=1&fid=52&tid=1881415]: |
29ms |
38ms |
| others: | 188ms |
| total: | 285ms |
