expdp\impdp не создается схема. oracle 12.1
при экспорте не создается schema definitions и соответственно импорт завершается с ошибкой ORA-01918 не могу понять причину отсутствия schema definitions . запуск экспорта: Код: plsql 1. лог Export: Release 12.1.0.2.0 - Production on Tue Jul 7 10:31:19 2020 Copyright (c) 1982, 2014, Oracle and/or its affiliates. All rights reserved. Connected to: Oracle Database 12c Enterprise Edition Release 12.1.0.2.0 - 64bit Production With the Partitioning, OLAP, Advanced Analytics and Real Application Testing options WARNING: Oracle Data Pump operations are not typically needed when connected to the root or seed of a container database. Starting "SYSTEM"."SYS_EXPORT_SCHEMA_09":.... Estimate in progress using BLOCKS method... Processing object type SCHEMA_EXPORT/TABLE/TABLE_DATA Total estimation using BLOCKS method: 10.93 MB Processing object type SCHEMA_EXPORT/SYSTEM_GRANT Processing object type SCHEMA_EXPORT/DEFAULT_ROLE Processing object type SCHEMA_EXPORT/PRE_SCHEMA/PROCACT_SCHEMA Processing object type SCHEMA_EXPORT/DB_LINK Processing object type SCHEMA_EXPORT/TYPE/TYPE_SPEC Processing object type SCHEMA_EXPORT/SEQUENCE/SEQUENCE Processing object type SCHEMA_EXPORT/TABLE/TABLE Processing object type SCHEMA_EXPORT/TABLE/COMMENT Processing object type SCHEMA_EXPORT/TABLE/IDENTITY_COLUMN Processing object type SCHEMA_EXPORT/FUNCTION/FUNCTION Processing object type SCHEMA_EXPORT/FUNCTION/ALTER_FUNCTION Processing object type SCHEMA_EXPORT/VIEW/VIEW Processing object type SCHEMA_EXPORT/TYPE/TYPE_BODY Processing object type SCHEMA_EXPORT/TABLE/INDEX/INDEX Processing object type SCHEMA_EXPORT/TABLE/CONSTRAINT/CONSTRAINT Processing object type SCHEMA_EXPORT/TABLE/INDEX/STATISTICS/INDEX_STATISTICS Processing object type SCHEMA_EXPORT/TABLE/CONSTRAINT/REF_CONSTRAINT Processing object type SCHEMA_EXPORT/TABLE/TRIGGER Processing object type SCHEMA_EXPORT/TABLE/STATISTICS/TABLE_STATISTICS Processing object type SCHEMA_EXPORT/STATISTICS/MARKER . . exported... соответственно в логе нет Processing object type SCHEMA_EXPORT/USER ... |
| 07.07.2020, 11:15:44 |
ORA-01918: user name does not exist Cause You tried to execute a command that specified a user name or role name that does not exist. Выполните команду с явными значениями Код: plsql 1. Потом разбирайтесь почему не подставились значения переменных ... |
| 07.07.2020, 14:56:57 |
elunin при экспорте не создается schema definitions и соответственно импорт завершается с ошибкой ORA-01918 Ну так создай пользователя предварительно ручками пустого. ... |
| 07.07.2020, 18:37:12 |
elunin при экспорте не создается schema definitions и соответственно импорт завершается с ошибкой ORA-01918 При экспорте схема и не должна создаваться, она должна создаваться при импорте. Как уже написали выполни экспорт с явными параметрами и смотри в логе что происходит. ... |
| 07.07.2020, 20:43:22 |
start [/forum/topic.php?desktop=1&fid=52&tid=1881088]: |
58ms |
53ms |
| others: | 194ms |
| total: | 361ms |
