Проблема с установкой Oracle Database 19c
Добрый день. Ставлю базы данных для обучения в институте, при установке Database выходит вот такая ошибка: [ 2020-09-21 14:48:49.176 MSK ] [WARNING] [DBT-09251] The listener configuration is not selected for the database. EM DB Express URL will not be accessible. [ 2020-09-21 14:49:05.678 MSK ] [WARNING] [DBT-06208] The 'SYS' password entered does not conform to the Oracle recommended standards. [ 2020-09-21 14:49:05.678 MSK ] [WARNING] [DBT-06208] The 'SYSTEM' password entered does not conform to the Oracle recommended standards. [ 2020-09-21 14:49:05.678 MSK ] [WARNING] [DBT-06208] The 'PDBADMIN' password entered does not conform to the Oracle recommended standards. [ 2020-09-21 14:49:06.065 MSK ] Prepare for db operation DBCA_PROGRESS : 8% [ 2020-09-21 14:49:06.385 MSK ] Copying database files [ 2020-09-21 14:49:07.442 MSK ] Error in Process: E:\WINDOWS.X64_193000_db_home\bin\oradim.exe Enter password for Oracle service user: Instance created. DIM-00019: create service error O/S-Error: (OS 1053) Служба не ответила на запрос своевременно. DBCA_PROGRESS : 31% DBCA_PROGRESS : 100% [ 2020-09-21 14:49:07.672 MSK ] [FATAL] java.io.IOException: There is an error in creating the following process: E:\WINDOWS.X64_193000_db_home\bin\sqlplus.exe -S -N /NOLOG The error is: Error 57 initializing SQL*Plus Error loading message shared library DBCA_PROGRESS : 8% DBCA_PROGRESS : 0% Что с этим делать? Спасибо. ... |
| 21.09.2020, 15:41:45 |
Версия Windows? Из-под какого пользователя производится установка? Еще могу рекомендовать: 1. https://apex.oracle.com/ 2. https://livesql.oracle.com/ 3. https://www.virtualbox.org 4. Always Free cloud services https://www.sql.ru/forum/1317117-1/oracle-cloud-free-tier-new-always-free-services https://www.sql.ru/forum/1324610/oracle-cloud-always-free-services ... |
| 21.09.2020, 15:55:35 |
dmdmdm, Windows version 10.0.18363.1082. У меня один пользователь, с правами администратора. ... |
| 21.09.2020, 16:02:46 |
У меня поддержки нет, поэтому увидел только описание такой проблемы для серверной редакции . Могу потыкать пальцем в небо. На этапе " Oracle Home User " выбрать "Windows Built-in Account". Отключить сторонний антивирус и встроенный защитник Windows. (в безопасном режиме) Код: powershell 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. ... |
| 21.09.2020, 16:30:35 |
dmdmdm, я нашел еще вот такую штуку , но посмотреть тоже не могу( Попробовал то что вы сказали - без изменений... спасибо за попытку( ... |
| 22.09.2020, 01:08:58 |
Erebuz DIM-00019: create service error O/S-Error: (OS 1053) Служба не ответила на запрос своевременно. ... [ 2020-09-21 14:49:07.672 MSK ] [FATAL] java.io.IOException: There is an error in creating the following process: E:\WINDOWS.X64_193000_db_home\bin\sqlplus.exe -S -N /NOLOG The error is: Error 57 initializing SQL*Plus Error loading message shared lib Проверьте виндовый эвент лог на предмет сопутствующих записей. Уточните у админа AD домена наличие доменных политик, ограничивающих запуск "несанкционированных" сервисов и исполняемых файлов. ... |
| 22.09.2020, 04:40:35 |
Кстати, да, учетка администратора, надеюсь, локальная. Если на другой машине с той же виндой, но которая не в домене, установка этого дистрибутива проходит успешно, можно, при желании, разбираться с доменной политикой. Но для новичка это перебор. Если админ не будет заниматься, для обучения используйте другие пути. ... |
| 22.09.2020, 10:20:37 |
dmdmdm, да, конечно, локальная. Речь вообще об одном домашнем компьютере. Раз с этим ничего не выходит, подскажите - можно ли использовать виртуальную машину для базы, нет там каких-то подводных камней? ... |
| 22.09.2020, 21:07:46 |
Камней нет. ... |
| 23.09.2020, 04:41:28 |
В общем, поставил в итоге все на виртуалке (уж не знаю почему, но установка прошла нормально). Но возникла новая проблема - ошибка 12514. Я повозился с ней, и выяснил, что по какой-то причине не происходит регистрации служб базы данных. Я, к сожалению, пока что не понял, ни почему, ни как это исправить... авторC:\Windows\system32>lsnrctl status LSNRCTL for 64-bit Windows: Version 19.0.0.0.0 - Production on 27-SEP-2020 05:27:11 Copyright (c) 1991, 2019, Oracle. All rights reserved. Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=localhost)(PORT=1521))) STATUS of the LISTENER ------------------------ Alias LISTENER Version TNSLSNR for 64-bit Windows: Version 19.0.0.0.0 - Production Start Date 27-SEP-2020 05:04:36 Uptime 0 days 0 hr. 22 min. 37 sec Trace Level off Security ON: Local OS Authentication SNMP OFF Listener Parameter File C:\WINDOWS.X64_193000_db_home\network\admin\listener.ora Listener Log File C:\Oracle\diag\tnslsnr\DESKTOP-GMEHORA\listener\alert\log.xml Listening Endpoints Summary... (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=127.0.0.1)(PORT=1521))) (DESCRIPTION=(ADDRESS=(PROTOCOL=ipc)(PIPENAME=\\.\pipe\EXTPROC1521ipc))) Services Summary... Service "CLRExtProc" has 1 instance(s). Instance "CLRExtProc", status UNKNOWN, has 1 handler(s) for this service... The command completed successfully по статусу листенера зарегистрирована только один сервис, и тот UNKNOWN (что, как я понял, говорит о статической регистрации). Остальных не видно. Все мои, достаточно жалкие, если честно, попытки это исправить ни к чему не привели. В частности, пытался сделать статическую регистрацию другим, но то ли я дурак, то ли лыжи не едут, но в общем ничего не вышло. К сожалению, в институте требуют именно оракл, и сейчас, с учетом дистанционного обучения, мне кровь из носу нужно его поставить на домашний комп хоть каким-нибудь образом( Можете подсказать, что тут можно сделать? ... |
| 27.09.2020, 05:35:53 |
Erebuz не знаю почему, но установка прошла нормально Бывают всякие экзотические проблемы, путь к каталогу , свободное место на диске . По 12514 ищите на форуме, куча тем. Для начала приведите из каталога ORA_HOME/NETWORK/ADMIN файлы sqlnet.ora, tnsnames.ora и listener.ora. ... |
| 27.09.2020, 07:40:57 |
И строку подключения. Код: plsql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. ... |
| 27.09.2020, 07:58:04 |
dmdmdm, Спасибо за помощь. Я все таки сделал это) Не знаю, в чем точно была причина, но я сделал следующее: скачал свеженький установщик с сайта oracle, убрав из его имени все что только можно лишнего, отключил полностью брандмауэр и встроенный антивирус, и установил. Все заработало. Видимо, проблема была либо в имени каталога, либо, в неверном пути в каком-нибудь файле. Не очень удобно, что в итоге все это счастье на виртуальной машине, но хотя бы так работает. Еще раз спасибо за помощь. ... |
| 28.09.2020, 00:54:37 |
start [/forum/topic.php?desktop=1&fid=52&tid=1880858]: |
139ms |
31ms |
| others: | 218ms |
| total: | 428ms |
