Помогите разобрать SOAP в котором элемент содержит еще один SOAP
<SOAP-ENV:Envelope xmlns:SOAP-ENV=" http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd=" http://www.w3.org/2001/XMLSchema" xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xmlns:SOAP-ENC=" http://schemas.xmlsoap.org/soap/encoding/"> <SOAP-ENV:Body SOAP-ENV:encodingStyle=" http://schemas.xmlsoap.org/soap/encoding/"> <NS1:GetBlockResponse xmlns:NS1="SysEtranInt"> <return xsi:type="xsd:boolean">true</return> <Text xsi:type="xsd:string"><![CDATA[<?xml version="1.0" encoding="windows-1251"?> <GetInformReply> <Inform_ID>12</Inform_ID> <ASOUPReply><![CDATA[<?xml version="1.0" encoding="UTF-8"?><S:Envelope xmlns:S=" http://schemas.xmlsoap.org/soap/envelope/"><S:Body><ns2:getReference12ASUResponse xmlns:ns2=" http://service.siw.pktbcki.rzd/"><return><reference12ASU><row><DATE_OP>2019-10-03T11:45:00.000</DATE_OP><NOM_VAG>42054940</NOM_VAG><GRUZOTPR>6752</GRUZOTPR><NAIM_KOP_VMD>OAII</NAIM_KOP_VMD><KOD_GRZ_TGNL>351043</KOD_GRZ_TGNL><NAIM_KOD_GRZ></NAIM_KOD_GRZ><VES_GRZ>20759</VES_GRZ><GRUZPOL>7768</GRUZPOL><STAN_OP>830200</STAN_OP><NAIM_STAN_OP>AOIAIA?</NAIM_STAN_OP><GRUZOTPR_OKPO>1098886</GRUZOTPR_OKPO><NAIM_GRUZOTPR>OINI IIN ? 22 CAI-NEA AE?AEOEE II ?AIIIOO IOOE O</NAIM_GRUZOTPR><KOP_VMD>81</KOP_VMD><GRUZPOL_OKPO>58786880</GRUZPOL_OKPO><NAIM_GRUZPOL>IIN ? 216 CAI-NEA AE?AEOEE II ?AIIIOO IOOE OA?I IA</NAIM_GRUZPOL><PRIN_PP_OKPO>0</PRIN_PP_OKPO><NAIM_PRIN_PP_OKPO></NAIM_PRIN_PP_OKPO></row></reference12ASU><amount>1</amount><codeTypeObject>1</codeTypeObject><returnCode>0</returnCode><errorCode>0</errorCode><errorMessage xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/><title>Ni?aaea i iiaa?a/oai?ea aaaiiia ia iiauacaiuo iooyo eeeaioia</title><dateIzm xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/></return></ns2:getReference12ASUResponse></S:Body></S:Envelope>]]> </ASOUPReply> </GetInformReply>]]></Text> </NS1:GetBlockResponse> </SOAP-ENV:Body> </SOAP-ENV:Envelope> при попытке разбора вываливается сообщение что тэг конца элемента ASOUPReply не соот-ет тэгу начала элемента Text как можно вытащить хотя бы как текст или clob содержимое элемента Text ? Спасибо за помощь ... |
| 17.10.2019, 17:49:14 |
т.е. проблема вся в содержимом тэга ASOUPReply если туда вместо еще одного SOAP чтото написать разбор проходит нормально ... |
| 17.10.2019, 17:56:32 |
Там CDATA вложена в CDATA, на том парсер и ломается - вложенную в CDATA "<![CDATA[" игнорит и вываливается из внешней CDATA на вложенной "]]", т.е. посреди документа. Можно вручную выдирать или sax-парсером, если отработать вложенность CDATA. ... |
| 17.10.2019, 18:02:47 |
еще фишка в том что весь разбор и прочая обработка должна хранится в бд в пакете ... |
| 17.10.2019, 18:10:07 |
boss1999хранится в бд в пакете Серверная java? ... |
| 17.10.2019, 18:16:53 |
нет бд оракловая ... |
| 17.10.2019, 18:35:37 |
boss1999нет бд оракловая https://docs.oracle.com/database/121/CNCPT/srvrside.htm#GUID-DDFED855-D1F3-4AB2-8FD3-B2A1B3C922D7 ... |
| 17.10.2019, 18:38:10 |
Проще говоря пакеты все пишутся в pl/sql и разбор формирование стандартными функциями оракла производятся ... |
| 17.10.2019, 18:46:26 |
Получается sax парсер не подходит. Придётся колхозить выдирать текст из cdata ... |
| 17.10.2019, 19:02:48 |
select * from xmltable(xmlnamespaces ( 'http://schemas.xmlsoap.org/soap/envelope/' as "SOAP-ENV" , 'http://www.w3.org/2001/XMLSchema' as "xsd" , 'http://www.w3.org/2001/XMLSchema-instance' as "xsi" , 'SysEtranInt' as "NS1" , 'http://schemas.xmlsoap.org/soap/encoding/' as "SOAP-ENC" ) , '/SOAP-ENV:Envelope/SOAP-ENV:Body/NS1:GetBlockResponse' passing xmltype( (select regexp_replace(response, '''', '"') from etran_db.etr_invoice_req where id_message=85) ) columns data clob path 'Text/(.)' ) temp, XMLTABLE (XMLNAMESPACES( 'http://schemas.xmlsoap.org/soap/envelope/' as "S", 'http://service.siw.pktbcki.rzd/' as "ns2" ) ,'/S:Envelope/S:Body/ns2:getReference12ASUResponse/return/reference12ASU' passing xmltype(temp.data) columns clob xml_data path './text()' ) t блин где-то неверный тип данных ... |
| 18.10.2019, 13:42:00 |
boss1999, Открой для себя тэги оформления, например, SRC Код: plsql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. ... |
| 18.10.2019, 16:16:09 |
boss1999, это не валидный xml, надо эскейпить ]]> во вложенной CDATA ... |
| 21.10.2019, 12:05:27 |
env, спасибо большое ... |
| 21.10.2019, 13:00:10 |
vadim19, <SOAP-ENV:Envelope xmlns:SOAP-ENV=" http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd=" http://www.w3.org/2001/XMLSchema" xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xmlns:SOAP-ENC=" http://schemas.xmlsoap.org/soap/encoding/"> <SOAP-ENV:Body SOAP-ENV:encodingStyle=" http://schemas.xmlsoap.org/soap/encoding/"> <NS1:GetBlockResponse xmlns:NS1="SysEtranInt"> <return xsi:type="xsd:boolean">true</return> <Text xsi:type="xsd:string"><![CDATA[<?xml version="1.0" encoding="windows-1251"?> <GetInformReply><Inform_ID>12</Inform_ID><ASOUPReply><![CDATA[<?xml version="1.0" encoding="UTF-8"?><S:Envelope xmlns:S=" http://schemas.xmlsoap.org/soap/envelope/"><S:Body><ns2:getReference12ASUResponse xmlns:ns2=" http://service.siw.pktbcki.rzd/"><return><reference12ASU><row><DATE_OP>2019-10-03T11:45:00.000</DATE_OP><NOM_VAG>42055806</NOM_VAG><GRUZOTPR>6752</GRUZOTPR><NAIM_KOP_VMD>УВПП</NAIM_KOP_VMD><KOD_GRZ_TGNL>351043</KOD_GRZ_TGNL><NAIM_KOD_GRZ></NAIM_KOD_GRZ><VES_GRZ>20759</VES_GRZ><GRUZPOL>7768</GRUZPOL><STAN_OP>830200</STAN_OP><NAIM_STAN_OP>ВХОДНАЯ</NAIM_STAN_OP><GRUZOTPR_OKPO>1098886</GRUZOTPR_OKPO><NAIM_GRUZOTPR>ТОСП ПМС № 22 ЗАП-СИБ ДИРЕКЦИИ ПО РЕМОНТУ ПУТИ Ц</NAIM_GRUZOTPR><KOP_VMD>81</KOP_VMD><GRUZPOL_OKPO>58786880</GRUZPOL_OKPO><NAIM_GRUZPOL>ПМС № 216 ЗАП-СИБ ДИРЕКЦИИ ПО РЕМОНТУ ПУТИ ЦДРП ОА</NAIM_GRUZPOL><PRIN_PP_OKPO>0</PRIN_PP_OKPO><NAIM_PRIN_PP_OKPO></NAIM_PRIN_PP_OKPO></row><row><DATE_OP>2019-10-03T11:45:00.000</DATE_OP><NOM_VAG>42046490</NOM_VAG><GRUZOTPR>6752</GRUZOTPR><NAIM_KOP_VMD>УВПП</NAIM_KOP_VMD><KOD_GRZ_TGNL>351043</KOD_GRZ_TGNL><NAIM_KOD_GRZ></NAIM_KOD_GRZ><VES_GRZ>20759</VES_GRZ><GRUZPOL>7768</GRUZPOL><STAN_OP>830200</STAN_OP><NAIM_STAN_OP>ВХОДНАЯ</NAIM_STAN_OP><GRUZOTPR_OKPO>1098886</GRUZOTPR_OKPO><NAIM_GRUZOTPR>ТОСП ПМС № 22 ЗАП-СИБ ДИРЕКЦИИ ПО РЕМОНТУ ПУТИ Ц</NAIM_GRUZOTPR><KOP_VMD>81</KOP_VMD><GRUZPOL_OKPO>58786880</GRUZPOL_OKPO><NAIM_GRUZPOL>ПМС № 216 ЗАП-СИБ ДИРЕКЦИИ ПО РЕМОНТУ ПУТИ ЦДРП ОА</NAIM_GRUZPOL><PRIN_PP_OKPO>0</PRIN_PP_OKPO><NAIM_PRIN_PP_OKPO></NAIM_PRIN_PP_OKPO></row><row><DATE_OP>2019-10-03T11:45:00.000</DATE_OP><NOM_VAG>42054940</NOM_VAG><GRUZOTPR>6752</GRUZOTPR><NAIM_KOP_VMD>УВПП</NAIM_KOP_VMD><KOD_GRZ_TGNL>351043</KOD_GRZ_TGNL><NAIM_KOD_GRZ></NAIM_KOD_GRZ><VES_GRZ>20759</VES_GRZ><GRUZPOL>7768</GRUZPOL><STAN_OP>830200</STAN_OP><NAIM_STAN_OP>ВХОДНАЯ</NAIM_STAN_OP><GRUZOTPR_OKPO>1098886</GRUZOTPR_OKPO><NAIM_GRUZOTPR>ТОСП ПМС № 22 ЗАП-СИБ ДИРЕКЦИИ ПО РЕМОНТУ ПУТИ Ц</NAIM_GRUZOTPR><KOP_VMD>81</KOP_VMD><GRUZPOL_OKPO>58786880</GRUZPOL_OKPO><NAIM_GRUZPOL>ПМС № 216 ЗАП-СИБ ДИРЕКЦИИ ПО РЕМОНТУ ПУТИ ЦДРП ОА</NAIM_GRUZPOL><PRIN_PP_OKPO>0</PRIN_PP_OKPO><NAIM_PRIN_PP_OKPO></NAIM_PRIN_PP_OKPO></row><row><DATE_OP>2019-10-03T11:45:00.000</DATE_OP><NOM_VAG>42045716</NOM_VAG><GRUZOTPR>6752</GRUZOTPR><NAIM_KOP_VMD>УВПП</NAIM_KOP_VMD><KOD_GRZ_TGNL>351043</KOD_GRZ_TGNL><NAIM_KOD_GRZ></NAIM_KOD_GRZ><VES_GRZ>19506</VES_GRZ><GRUZPOL>7768</GRUZPOL><STAN_OP>830200</STAN_OP><NAIM_STAN_OP>ВХОДНАЯ</NAIM_STAN_OP><GRUZOTPR_OKPO>1098886</GRUZOTPR_OKPO><NAIM_GRUZOTPR>ТОСП ПМС № 22 ЗАП-СИБ ДИРЕКЦИИ ПО РЕМОНТУ ПУТИ Ц</NAIM_GRUZOTPR><KOP_VMD>81</KOP_VMD><GRUZPOL_OKPO>58786880</GRUZPOL_OKPO><NAIM_GRUZPOL>ПМС № 216 ЗАП-СИБ ДИРЕКЦИИ ПО РЕМОНТУ ПУТИ ЦДРП ОА</NAIM_GRUZPOL><PRIN_PP_OKPO>0</PRIN_PP_OKPO><NAIM_PRIN_PP_OKPO></NAIM_PRIN_PP_OKPO></row><row><DATE_OP>2019-10-03T11:45:00.000</DATE_OP><NOM_VAG>42051680</NOM_VAG><GRUZOTPR>6752</GRUZOTPR><NAIM_KOP_VMD>УВПП</NAIM_KOP_VMD><KOD_GRZ_TGNL>351043</KOD_GRZ_TGNL><NAIM_KOD_GRZ></NAIM_KOD_GRZ><VES_GRZ>17927</VES_GRZ><GRUZPOL>7768</GRUZPOL><STAN_OP>830200</STAN_OP><NAIM_STAN_OP>ВХОДНАЯ</NAIM_STAN_OP><GRUZOTPR_OKPO>1098886</GRUZOTPR_OKPO><NAIM_GRUZOTPR>ТОСП ПМС № 22 ЗАП-СИБ ДИРЕКЦИИ ПО РЕМОНТУ ПУТИ Ц</NAIM_GRUZOTPR><KOP_VMD>81</KOP_VMD><GRUZPOL_OKPO>58786880</GRUZPOL_OKPO><NAIM_GRUZPOL>ПМС № 216 ЗАП-СИБ ДИРЕКЦИИ ПО РЕМОНТУ ПУТИ ЦДРП ОА</NAIM_GRUZPOL><PRIN_PP_OKPO>0</PRIN_PP_OKPO><NAIM_PRIN_PP_OKPO></NAIM_PRIN_PP_OKPO></row><row><DATE_OP>2019-10-03T11:45:00.000</DATE_OP><NOM_VAG>42885988</NOM_VAG><GRUZOTPR>6752</GRUZOTPR><NAIM_KOP_VMD>УВПП</NAIM_KOP_VMD><KOD_GRZ_TGNL>351043</KOD_GRZ_TGNL><NAIM_KOD_GRZ></NAIM_KOD_GRZ><VES_GRZ>17927</VES_GRZ><GRUZPOL>7768</GRUZPOL><STAN_OP>830200</STAN_OP><NAIM_STAN_OP>ВХОДНАЯ</NAIM_STAN_OP><GRUZOTPR_OKPO>1098886</GRUZOTPR_OKPO><NAIM_GRUZOTPR>ТОСП ПМС № 22 ЗАП-СИБ ДИРЕКЦИИ ПО РЕМОНТУ ПУТИ Ц</NAIM_GRUZOTPR><KOP_VMD>81</KOP_VMD><GRUZPOL_OKPO>58786880</GRUZPOL_OKPO><NAIM_GRUZPOL>ПМС № 216 ЗАП-СИБ ДИРЕКЦИИ ПО РЕМОНТУ ПУТИ ЦДРП ОА</NAIM_GRUZPOL><PRIN_PP_OKPO>0</PRIN_PP_OKPO><NAIM_PRIN_PP_OKPO></NAIM_PRIN_PP_OKPO></row><row><DATE_OP>2019-10-03T11:45:00.000</DATE_OP><NOM_VAG>44323665</NOM_VAG><GRUZOTPR>6752</GRUZOTPR><NAIM_KOP_VMD>УВПП</NAIM_KOP_VMD><KOD_GRZ_TGNL>351043</KOD_GRZ_TGNL><NAIM_KOD_GRZ></NAIM_KOD_GRZ><VES_GRZ>17927</VES_GRZ><GRUZPOL>7768</GRUZPOL><STAN_OP>830200</STAN_OP><NAIM_STAN_OP>ВХОДНАЯ</NAIM_STAN_OP><GRUZOTPR_OKPO>1098886</GRUZOTPR_OKPO><NAIM_GRUZOTPR>ТОСП ПМС № 22 ЗАП-СИБ ДИРЕКЦИИ ПО РЕМОНТУ ПУТИ Ц</NAIM_GRUZOTPR><KOP_VMD>81</KOP_VMD><GRUZPOL_OKPO>58786880</GRUZPOL_OKPO><NAIM_GRUZPOL>ПМС № 216 ЗАП-СИБ ДИРЕКЦИИ ПО РЕМОНТУ ПУТИ ЦДРП ОА</NAIM_GRUZPOL><PRIN_PP_OKPO>0</PRIN_PP_OKPO><NAIM_PRIN_PP_OKPO></NAIM_PRIN_PP_OKPO></row></reference12ASU><amount>7</amount><codeTypeObject>1</codeTypeObject><returnCode>0</returnCode><errorCode>0</errorCode><errorMessage xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/><title>Справка о подаче/уборке вагонов на подъездных путях клиентов</title><dateIzm xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true"/></return></ns2:getReference12ASUResponse></S:Body></S:Envelope>]]></ASOUPReply></GetInformReply>]]></Text> </NS1:GetBlockResponse> </SOAP-ENV:Body> </SOAP-ENV:Envelope> ... |
| 21.10.2019, 13:46:21 |
вот полный кусок xml помогите с ним разобраться пожалуйста ... |
| 21.10.2019, 13:59:04 |
авboss1999ор вот полный кусок xml помогите с ним разобраться Босс, куда скинуть полный номер карты сбера? ... |
| 21.10.2019, 15:45:16 |
Lary Denisавboss1999ор вот полный кусок xml помогите с ним разобраться Босс, куда скинуть полный номер карты сбера? было бы смешно, если бы не было так грустно ну реально помощь нужна ... |
| 21.10.2019, 15:47:31 |
boss1999Lary Denisпропущено... Босс, куда скинуть полный номер карты сбера? было бы смешно, если бы не было так грустно ну реально помощь нужна Студентам, желающим помощи HOWTO :: Как правильно задавать вопросы 1) Полная постановка задачи (без сокращений) 2) Подготовьте тестовые данные, лучше в виде with например (не ваш случай): Код: plsql 1. 2. 3. 4. 5. 2) Покажите что сделали, что не получается, точный текст ошибки (не screenshot) 3) используйте Тэги, читать код без них неудобно ... |
| 21.10.2019, 16:07:15 |
boss1999вот полный кусок xml помогите с ним разобраться пожалуйста Ну не валидный он, не валидный, Вам же уже сказали... Код: plsql 1. 2. 3. 4. 5. 6. 7. ... |
| 21.10.2019, 18:42:37 |
проблему решил. можно закрывать ветку. ... |
| 21.10.2019, 18:58:34 |
start [/forum/topic.php?desktop=1&fid=52&tid=1880675]: |
70ms |
67ms |
| others: | 236ms |
| total: | 432ms |
