Периодически падает база с ошибками ORA-00445, ORA-07445, ORA-00600
Добрый день. AIX 6.1, Oracle Database 11g Enterprise Edition Release 11.2.0.4.0 - 64bit Production Периодически падает база с ошибками ORA-00445, ORA-07445, ORA-00600. Кейс в поддержке открыт уже месяц, но общение происходит «в одни ворота». Все патчи которые предлагали уже установлены, вся поддержка свелась к тому что по запросу отправляем им различные логи. Может у кого-нибудь есть идеи? Вырезки из alert.log: авторORA-00445: background process "J002" did not start after 120 seconds … ORA-07445: exception encountered: core dump [kghalf()+276] [SIGSEGV] [ADDR:0x10D09E78] [PC:0x1000C3794] [Address not mapped to object] [] ORA-07445: exception encountered: core dump [kghsrch()+144] [SIGSEGV] [ADDR:0x10D09E78] [PC:0x1000BE650] [Address not mapped to object] [] ORA-07445: exception encountered: core dump [kpucCleanup()+180] [SIGSEGV] [ADDR:0xF7E5F0F2E5E60179] [PC:0x100E276F4] [Address not mapped to object] [] … ORA-00600: internal error code, arguments: [kksParentHandleFreeCbk:inv litctx type], [0x700011AD168BD38], [], [], [], [], [], [], [], [], [], [] … ORA-00600: internal error code, arguments: [16366], [0x700011FCAEF66D8], [0x70001169CA4D500], [0x700011E2B125E68], [0x700011E2B125F10], [0x000000000], [0x000000000], [], [], [], [], [] … Errors in file /u01/app/oracle/diag/rdbms/fin/B/trace/B_s002_7274622.trc (incident=1364331): ORA-00600: internal error code, arguments: [17147], [0x7000116A82BDCF0], [], [], [], [], [], [], [], [], [], [] ORA-00600: internal error code, arguments: [17147], [0x7000116A82BDCF0], [], [], [], [], [], [], [], [], [], [] Incident details in: /u01/app/oracle/diag/rdbms/fin/B/incident/incdir_1364331/B_s002_7274622_i1364331.trc Use ADRCI or Support Workbench to package the incident. … Errors in file /u01/app/oracle/diag/rdbms/fin/B/trace/B_pmon_4587540.trc: ORA-00600: internal error code, arguments: [17147], [0x7000116A82BDCF0], [], [], [], [], [], [], [], [], [], [] PMON (ospid: 4587540): terminating the instance due to error 472 Instance terminated by PMON, pid = 4587540 ... |
| 17.02.2021, 09:34:22 |
Apecc, баги в 11.2.0.4 на ORA-600 [17147] все прочитали? кстати, учитывая error 472, у вас случаем MMON перед PMON'ом не умирал? хотя, полагаю, это первое, от чего саппорт должен был предложить патч... ... |
| 17.02.2021, 23:03:11 |
проходил мимо..., Баги думаю раз на 10 прочитали, если пропустил чего-нибудь буду рад узнать что. mmon не умирал. С mmon есть такой кусок в алерт довольно старый. автор... Fri Dec 25 06:21:01 2020 Errors in file /u01/app/oracle/diag/rdbms/fin/B/trace/B_mmon_8912910.trc (incident=1171515): ORA-00445: background process "m001" did not start after 120 seconds Incident details in: /u01/app/oracle/diag/rdbms/fin/B/incident/incdir_1171515/B_mmon_8912910_i1171515.trc Fri Dec 25 06:21:07 2020 Sweep [inc][1171627]: completed Sweep [inc][1171515]: completed Sweep [inc2][1171515]: completed Fri Dec 25 06:21:07 2020 Dumping diagnostic data in directory=[cdmp_20201225062107], requested by (instance=1, osid=8912910 (MMON)), summary=[incident=1171515]. Fri Dec 25 06:23:11 2020 Dumping diagnostic data in directory=[cdmp_20201225062311], requested by (instance=1, osid=8585602 (S001)), summary=[incident=1171627]. Fri Dec 25 06:23:13 2020 Sweep [inc2][1171627]: completed ... В первую очередь саппорт предположил Bug 22243719, на него патч стоит. ... |
| 18.02.2021, 07:39:17 |
Видел такое когда LPAR ресурсов не хватало, процессора было назначено 0.0001% ядра или около того ... |
| 19.02.2021, 14:58:42 |
start [/forum/topic.php?desktop=1&fid=52&tid=1880421]: |
35ms |
43ms |
| others: | 217ms |
| total: | 333ms |
