Oracle 19 и внешние библиотеки
Доброго дня всем. Пытаюсь запустить внешнюю библиотеку на Oracle 19.3 (которая успешно работала на 11.2) и что то ничего не получается: ORA-06520: PL/SQL: Error loading external library Включил trace в extproc.ora но ничего вразумительного в логах HS не получил Oracle Corporation --- 2021-06-09 00:37:45.236353000 Version 19.0.0.0.0 HOA 06/09 00:37:45.236581000: (horcrase_AllocStackElt) Entered! HOA 06/09 00:37:45.236597000: (horcrase_AllocStackElt) Exiting... HOA 06/09 00:37:45.236606000: (horcrpuoe_PushOciEnv) Entered! HOA 06/09 00:37:45.236615000: (horcrpuoe_PushOciEnv) Exiting... HOA 06/09 00:37:45.236624000: (horcries_InitExtprocSession) Exiting... HOA 06/09 00:37:45.236639000: (hotkisc_InitSessionContext) Exiting... HOA 06/09 00:37:45.236649000: (hotkec_EstablishConnection) Entered! 2021/06/09-00:37:45.236777000: Entered shorcsju_spawn_jssu_unix HS: Parent extproc argv[1] = (DESCRIPTION=(LOCAL=YES)(ADDRESS=(PROTOCOL=BEQ))) HS: Parent extproc called nsgetaddr, addr = (ADDRESS=(PROTOCOL=ipc)(KEY=#3824.1.1455049792)) HS: Parent extproc received the IN param, flags_horrx = 0x1000 0: 31303030 [1000] HS: Parent extproc is falling back to the old behavior with connect string = (ADDRESS=(PROTOCOL=BEQ)(PROGRAM=/u01/app/oracle/product/oracle19/bin/extproc)(ARGV0=/u01/app/oracle/product/oracle19/bin/extproc)(ARGS='(DESCRIPTION=(LOCAL=YES)(ADDRESS=(PROTOCOL=BEQ)))')) HS: Parent extproc called nsbequeath! status = 0 2021/06/09-00:37:45.248961000: Exiting shorcsju_spawn_jssu_unix, rc=0 HS: Parent extproc is calling exit(0)!!! HOA 06/09 00:48:44.427108000: (horcciX_ExecCalloutCallbackIn) Entered! HOA 06/09 00:48:44.427117000: (horcctf_TransferFDO) Entered! HOA 06/09 00:48:44.427140000: (horcciX_ExecCalloutCallbackIn) Exiting..., status = 0 HOA 06/09 00:48:44.427149000: (horcrX_ReceiveExecCallout) ncrorin: status = 0 HOA 06/09 00:48:44.427170000: (horcrwc_WithContext) Entered! HOA 06/09 00:48:44.427178000: (horcrwc_WithContext) Exiting... HOA 06/09 00:48:44.427187000: (horcrsdi_SetDurationIds) Entered! HOA 06/09 00:48:44.427204000: (horcrsdi_SetDurationIds) Exiting... HOA 06/09 00:48:44.427218000: (hospvld_DllPath) Entered! HOA 06/09 00:48:44.427231000: (hospvld_DllPath) HS: EXTPROC_DLLS = ANY HOA 06/09 00:48:44.427240000: (hospvld_DllPath) Exiting... HOA 06/09 00:48:44.427248000: (horcrX_ReceiveExecCallout) loading PL/SQL library : KD.LIBFS_SO HOA 06/09 00:48:44.427292000: (horcrX_ReceiveExecCallout) called pefload, status = 6520 HOA 06/09 00:48:44.427304000: (horccoX_ExecCalloutCallbackOut) Entered! HOA 06/09 00:48:44.427313000: (horccoX_ExecCalloutCallbackOut) Exiting..., status = 0 HOA 06/09 00:48:44.427322000: (horcrX_ReceiveExecCallout) ncrosou: status = 0 HOA 06/09 00:48:44.427330000: (horcrgoe_GetOciEnv) Entered! HOA 06/09 00:48:44.427338000: (horcrgoe_GetOciEnv) Exiting... HOA 06/09 00:48:44.427346000: (horcrec_EndCallout) Entered! HOA 06/09 00:48:44.427354000: (horcrec_EndCallout) Exiting... HOA 06/09 00:48:44.427362000: (horcrX_ReceiveExecCallout) Exiting..., status = 0 И нигде не могу найти в чем дело. Документация говорит, что должно сходу все завестись, но лыжи не едут. Пробовал прописать как в 11-м через listener/tnsnames - результат тот же. Есть какие-то приколы в конфигурировании внешних библиотек под 19-й оракл? Где еще можно посмотреть причины нестарта? ... |
| 08.06.2021, 23:02:49 |
Migelle ORA-06520: PL/SQL: Error loading external library ... |
| 09.06.2021, 01:24:21 |
И заодно проверяешь, что под владельцем листенера для extproc видны все зависимости для библиотеке (правильно устанавливается PATH / LD_LIBRARY_PATH, например) ldd libname ... |
| 09.06.2021, 01:48:18 |
start [/forum/topic.php?desktop=1&fid=52&tid=1880122]: |
290ms |
| others: | 186ms |
| total: | 524ms |
