Тихая установка oracle 21xe, не запускается EM
Добрый день после тихой установки не запасается EM при обычной установке все нормально E:\oracle21\OracleXE213_Win64\setup.exe /s /v"RSP_FILE=E:\oracle21\OracleXE213_Win64\XEInstall.rsp" /v"/L*v E:\oracle21\OracleXE213_Win64\setup.log" /v"/qn" XEInstall.rsp #Do not leave any parameter with empty value #Install Directory location, username can be replaced with current user INSTALLDIR=C:\app\product\21c\ #Database password, All users are set with this password, Remove the value once installation is complete PASSWORD=QWERA123_!@# #If listener port is set to 0, available port will be allocated starting from 1521 automatically LISTENER_PORT=1521 #If EM express port is set to 0, available port will be used starting from 5550 automatically EMEXPRESS_PORT=5500 #Specify char set of the database CHAR_SET=CL8MSWIN1251 #Specify the database comain for the db unique name specification #DB_DOMAIN=SA lsnrctl status обычная установка C:\Users\il>lsnrctl status LSNRCTL for 64-bit Windows: Version 21.0.0.0.0 - Production on 09-OCT-2021 15:35:51 Copyright (c) 1991, 2021, Oracle. All rights reserved. Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=192.168.111.139)(PORT=1521))) STATUS of the LISTENER ------------------------ Alias LISTENER Version TNSLSNR for 64-bit Windows: Version 21.0.0.0.0 - Production Start Date 09-OCT-2021 12:08:57 Uptime 0 days 3 hr. 26 min. 56 sec Trace Level off Security ON: Local OS Authentication SNMP OFF Default Service XE Listener Parameter File C:\app\il\product\21c\homes\OraDB21Home1\network\admin\listener.ora Listener Log File C:\app\il\product\21c\diag\tnslsnr\DESKTOP-IPK3RRI\listener\alert\log.xml Listening Endpoints Summary... (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=192.168.111.139)(PORT=1521))) (DESCRIPTION=(ADDRESS=(PROTOCOL=ipc)(PIPENAME=\\.\pipe\EXTPROC1521ipc))) (DESCRIPTION=(ADDRESS=(PROTOCOL=tcps)(HOST=127.0.0.1)(PORT=5500))(Security=(my_wallet_directory=C:\APP\IL\PRODUCT\21C\admin\XE\xdb_wallet))(Presentation=HTTP)(Session=RAW)) Services Summary... Service "CLRExtProc" has 1 instance(s). Instance "CLRExtProc", status UNKNOWN, has 1 handler(s) for this service... Service "XE" has 1 instance(s). Instance "xe", status READY, has 2 handler(s) for this service... Service "XEXDB" has 1 instance(s). Instance "xe", status READY, has 1 handler(s) for this service... Service "fbe0f23bd49647b0840505386c37392a" has 1 instance(s). Instance "xe", status READY, has 2 handler(s) for this service... Service "xepdb1" has 1 instance(s). Instance "xe", status READY, has 2 handler(s) for this service... The command completed successfully тихая установка C:\Users\il>lsnrctl status LSNRCTL for 64-bit Windows: Version 21.0.0.0.0 - Production on 09-OCT-2021 15:39:07 Copyright (c) 1991, 2021, Oracle. All rights reserved. Connecting to (DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=DESKTOP-IPK3RRI.localdomain)(PORT=1521))) STATUS of the LISTENER ------------------------ Alias LISTENER Version TNSLSNR for 64-bit Windows: Version 21.0.0.0.0 - Production Start Date 09-OCT-2021 15:00:54 Uptime 0 days 0 hr. 38 min. 17 sec Trace Level off Security ON: Local OS Authentication SNMP OFF Default Service XE Listener Parameter File C:\app\product\21c\homes\OraDB21Home1\network\admin\listener.ora Listener Log File C:\app\product\21c\diag\tnslsnr\DESKTOP-IPK3RRI\listener\alert\log.xml Listening Endpoints Summary... (DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=DESKTOP-IPK3RRI)(PORT=1521))) (DESCRIPTION=(ADDRESS=(PROTOCOL=ipc)(PIPENAME=\\.\pipe\EXTPROC1521ipc))) Services Summary... Service "CLRExtProc" has 1 instance(s). Instance "CLRExtProc", status UNKNOWN, has 1 handler(s) for this service... The command completed successfully ... |
| 09.10.2021, 15:50:01 |
start [/forum/topic.php?desktop=1&fid=52&tid=1879837]: |
190ms |
| others: | 207ms |
| total: | 473ms |
