Отправка сообщений в Телеграм чат-бот из PL/SQL
Всем привет ! Пытаюсь реализовать отправку уведомлений в Telegram средствами PL SQL Шаги следующие 1) Экспортируем серт с api.telegram.org 2) Копируем cерт в /home/oracle/api-telegram.cer 3) Создаем бумажник (пароль welcome_tg) mkdir /home/oracle/wallet orapki wallet create -wallet /home/oracle/wallet -auto_login -pwd welcome_tg 4) Добавляем серт orapki wallet add -wallet /home/oracle/wallet -trusted_cert -cert /home/oracle/api-telegram.cer -pwd welcome_tg 5) Просмотрим бумажник orapki wallet display -complete -wallet /home/oracle/wallet Requested Certificates: User Certificates: Trusted Certificates: Subject: CN=Go Daddy Secure Certificate Authority - G2,OU=http://certs.godaddy.com/repository/,O=GoDaddy.com\, Inc.,L=Scottsdale,ST=Arizona,C=US Issuer: CN=Go Daddy Root Certificate Authority - G2,O=GoDaddy.com\, Inc.,L=Scottsdale,ST=Arizona,C=US Serial Number: 07 Key Length 2048 MD5 digest: 96:C2:50:31:BC:0D:C3:5C:FB:A7:23:73:1E:1B:41:40 SHA digest: 27:AC:93:69:FA:F2:52:07:BB:26:27:CE:FA:CC:BE:4E:F9:C3:19:B8 Subject: CN=Go Daddy Root Certificate Authority - G2,O=GoDaddy.com\, Inc.,L=Scottsdale,ST=Arizona,C=US Issuer: CN=Go Daddy Root Certificate Authority - G2,O=GoDaddy.com\, Inc.,L=Scottsdale,ST=Arizona,C=US Serial Number: 00 Key Length 2048 MD5 digest: 80:3A:BC:22:C1:E6:FB:8D:9B:3B:27:4A:32:1B:9A:01 SHA digest: 47:BE:AB:C9:22:EA:E8:0E:78:78:34:62:A7:9F:45:C2:54:FD:E6:8B Subject: CN=api.telegram.org,OU=Domain Control Validated Issuer: CN=Go Daddy Secure Certificate Authority - G2,OU=http://certs.godaddy.com/repository/,O=GoDaddy.com\, Inc.,L=Scottsdale,ST=Arizona,C=US Serial Number: 0D:03:23:A0:90:B6:80:42 Key Length 2048 MD5 digest: F1:66:BE:C6:ED:1D:63:D3:2B:17:63:7E:D5:C5:C7:6B SHA digest: F2:AD:29:9C:34:48:DD:8D:F4:CF:52:32:F6:57:33:68:2E:81:C1:90 6) Пробуем select UTL_HTTP.request('https://api.telegram.org/bot2137664:AAFccDDwYyEFqZMwTF1LyFipYbSdBlopcfIIs/getUpdates',null,'file:/home/oracle/wallet', 'welcome_tg') from dual; Получаю ошибку ERROR at line 1: ORA-29273: HTTP request failed ORA-06512: at "SYS.UTL_HTTP", line 1501 ORA-29024: Certificate validation failure ORA-06512: at "SYS.UTL_HTTP", line 380 ORA-06512: at "SYS.UTL_HTTP", line 1441 ORA-06512: at line 1 Судя по ошибке , проблема в сертификате . Пробовал разные манипуляции с сертификатом - ошибка одна и таже ORA-29024 ... |
| 27.11.2021, 08:58:15 |
MaximKozhetyev, Мне помогло EXEC UTL_HTTP.set_wallet('file:/path', NULL); ... |
| 27.11.2021, 09:25:44 |
SQL> exec UTL_HTTP.set_wallet('file:/home/oracle/wallet', 'welcome_tg'); PL/SQL procedure successfully completed. SQL> select UTL_HTTP.request('https://api.telegram.org/bot2137664:AAFccDDwYyEFqZMwTF1LyFipYbSdBlopcfIIs/getUpdates') from dual; select UTL_HTTP.request('https://api.telegram.org/bot2137664:AAFccDDwYyEFqZMwTF1LyFipYbSdBlopcfIIs/getUpdates') from dual * ERROR at line 1: ORA-29273: HTTP request failed ORA-06512: at "SYS.UTL_HTTP", line 1501 ORA-29024: Certificate validation failure ORA-06512: at "SYS.UTL_HTTP", line 380 ORA-06512: at "SYS.UTL_HTTP", line 1441 ORA-06512: at line 1 ... |
| 27.11.2021, 09:42:19 |
MaximKozhetyev SQL> exec UTL_HTTP.set_wallet('file:/home/oracle/wallet', 'welcome_tg'); PL/SQL procedure successfully completed. SQL> select UTL_HTTP.request('https://api.telegram.org/bot2137664:AAFccDDwYyEFqZMwTF1LyFipYbSdBlopcfIIs/getUpdates') from dual; select UTL_HTTP.request('https://api.telegram.org/bot2137664:AAFccDDwYyEFqZMwTF1LyFipYbSdBlopcfIIs/getUpdates') from dual * ERROR at line 1: ORA-29273: HTTP request failed ORA-06512: at "SYS.UTL_HTTP", line 1501 ORA-29024: Certificate validation failure ORA-06512: at "SYS.UTL_HTTP", line 380 ORA-06512: at "SYS.UTL_HTTP", line 1441 ORA-06512: at line 1 Именно NULL пиши ... |
| 27.11.2021, 09:44:36 |
т е не указывать пароль к бумажнику? так ? SQL> exec UTL_HTTP.set_wallet('file:/home/oracle/wallet',null); PL/SQL procedure successfully completed. SQL> select UTL_HTTP.request('https://api.telegram.org/bot2137664:AAFccDDwYyEFqZMwTF1LyFipYbSdBlopcfIIs/getUpdates') from dual; select UTL_HTTP.request('https://api.telegram.org/bot2137664:AAFccDDwYyEFqZMwTF1LyFipYbSdBlopcfIIs/getUpdates') from dual * ERROR at line 1: ORA-29273: HTTP request failed ORA-06512: at "SYS.UTL_HTTP", line 1501 ORA-29024: Certificate validation failure ORA-06512: at "SYS.UTL_HTTP", line 380 ORA-06512: at "SYS.UTL_HTTP", line 1441 ORA-06512: at line 1 SQL> ... |
| 27.11.2021, 09:51:02 |
MaximKozhetyev т е не указывать пароль к бумажнику? так ? SQL> exec UTL_HTTP.set_wallet('file:/home/oracle/wallet',null); PL/SQL procedure successfully completed. SQL> select UTL_HTTP.request('https://api.telegram.org/bot2137664:AAFccDDwYyEFqZMwTF1LyFipYbSdBlopcfIIs/getUpdates') from dual; select UTL_HTTP.request('https://api.telegram.org/bot2137664:AAFccDDwYyEFqZMwTF1LyFipYbSdBlopcfIIs/getUpdates') from dual * ERROR at line 1: ORA-29273: HTTP request failed ORA-06512: at "SYS.UTL_HTTP", line 1501 ORA-29024: Certificate validation failure ORA-06512: at "SYS.UTL_HTTP", line 380 ORA-06512: at "SYS.UTL_HTTP", line 1441 ORA-06512: at line 1 SQL> Код: plsql 1. 2. 3. 4. Код: xml 1. ... |
| 27.11.2021, 09:52:16 |
MaximKozhetyev, ... |
| 27.11.2021, 09:54:34 |
Я так и экспортировал как у тебя на скрине . Можешь прикрепить файл сертификата ? или хотя бы показать вывод команды orapki wallet display -complete -wallet /home/u01/app/oracle/product/19.3.0/dbhome_1/wallet ... |
| 27.11.2021, 10:10:14 |
Aleks Niches спасибо огромное. получилось ... |
| 27.11.2021, 10:37:50 |
start [/forum/topic.php?desktop=1&fid=52&tid=1879721]: |
29ms |
56ms |
23ms |
89ms |
| others: | 361ms |
| total: | 598ms |
