Не устанавливается SQL Server
Добрый день. Никак не получается становить SQL Server 2016 ExprEd на Win 2016 Standart. При установке ошибки: 1) TITLE: Microsoft SQL Server 2016 Setup ------------------------------ The following error has occurred: Value cannot be null. Parameter name: value For help, click: http://go.microsoft.com/fwlink?LinkID=20476&ProdName=Microsoft SQL Server&EvtSrc=setup.rll&EvtID=50000&ProdVer=13.0.5026.0&EvtType=0xBCD389FC%400x11428655 ------------------------------ BUTTONS: OK ------------------------------ 2) TITLE: Microsoft SQL Server 2016 Setup ------------------------------ The following error has occurred: The specified service does not exist as an installed service. Click 'Retry' to retry the failed action, or click 'Cancel' to cancel this action and continue setup. For help, click: http://go.microsoft.com/fwlink?LinkID=20476&ProdName=Microsoft SQL Server&EvtSrc=setup.rll&EvtID=50000&ProdVer=13.0.5026.0&EvtType=0x4E01BCF2%400xDC80C325 ------------------------------ BUTTONS: &Retry Cancel ------------------------------ 3) TITLE: SQL Server Setup failure. ------------------------------ SQL Server Setup has encountered the following error: Cannot find registry key 'SOFTWARE\Microsoft\Microsoft SQL Server\130\ConfigurationState'. Error code 0x84BB0001. For help, click: http://go.microsoft.com/fwlink?LinkID=20476&ProdName=Microsoft SQL Server&EvtSrc=setup.rll&EvtID=50000&EvtType=0xF96176E5%400xD3BEBD98%401211%401 ------------------------------ BUTTONS: OK ------------------------------ И все. Database Engine не устанавливается. Что делать? :(( ... |
| 16.12.2019, 18:58 |
ssms Что делать? :(( ... |
| 16.12.2019, 22:52 |
ssms, 1. Дисрибутив битый. 2. .Net не включен/установлен. ... |
| 17.12.2019, 01:12 |
alexeyvg ssms Что делать? :(( Спасибо. Сморю, там написано вот что: Detailed results: Feature: Database Engine Services Status: Failed: see logs for details Reason for failure: An error occurred during the setup process of the feature. Next Step: Use the following information to resolve the error, uninstall this feature, and then run the setup process again. Component name: SQL Server Database Engine Services Instance Features Component error code: 0x84BB0001 Error description: The specified service does not exist as an installed service. Error help link: http://go.microsoft.com/fwlink?LinkId=20476&ProdName=Microsoft SQL Server&EvtSrc=setup.rll&EvtID=50000&ProdVer=13.0.5026.0&EvtType=0x4E01BCF2@0xDC80C325&EvtType=0x4E01BCF2@0xDC80C325 По ссылке реклама игровых приставок. :( ... |
| 17.12.2019, 10:27 |
Владислав Колосов ssms, 1. Дисрибутив битый. 2. .Net не включен/установлен. Дистрибутив точно не битый. С него устанавливал раньше + скачал свежий - не ставится ни с какого. Тут .net в списке отсутствует: Control Panel\Programs\Programs and Features Его как-то отдельно надо ставить? Думал он с скл сервер сам ставится. ... |
| 17.12.2019, 10:29 |
Владислав Колосов ssms, 1. Дисрибутив битый. 2. .Net не включен/установлен. Википедия пишет что .net версии 4.6 по умолчанию присутствует в виндоус10. о_О ... |
| 17.12.2019, 10:41 |
ssms Владислав Колосов ssms, 1. Дисрибутив битый. 2. .Net не включен/установлен. Википедия пишет что .net версии 4.6 по умолчанию присутствует... Проверил, действительно присутствует. ... |
| 17.12.2019, 14:58 |
ssms Сморю, там написано вот что: Нужно посмотреть в последней папке вида 20191216_123456 Там есть Detail.txt и SQLServer_ERRORLOG_*.txt Их надо поизучать, там детальный лог установки. И ещё, какой дистрибутив запускали, имя фала? ssms По ссылке реклама игровых приставок. :( ... |
| 17.12.2019, 15:19 |
Коллеги, проблема актуальна. ... |
| 18.12.2019, 11:06 |
В логе установки вот что нашел: (01) 2019-12-18 10:50:06 SQLEngine: --FilestreamConfiguration: Setting RsFxVersion to 0411 (01) 2019-12-18 10:50:06 Slp: Sco: Attempting to set value RsFxVersion (01) 2019-12-18 10:50:06 Slp: SetValue: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL Server\MSSQL13.SQLEXPRESS\MSSQLServer\Filestream, Name = RsFxVersion (01) 2019-12-18 10:50:06 SQLEngine: : SetFSCTLInRegistry: Set FSCTL in value FSCTL_SQL_FILESTREAM_FETCH_OLD_CONTENT under System\CurrentControlSet\Services\LanmanServer\Parameters\FsctlAllowList (01) 2019-12-18 10:50:06 Slp: Sco: Attempting to create base registry key HKEY_LOCAL_MACHINE, machine (01) 2019-12-18 10:50:06 Slp: Sco: Attempting to open registry subkey System\CurrentControlSet\Services\LanmanServer\Parameters\FsctlAllowList (01) 2019-12-18 10:50:06 Slp: Prompting user if they want to retry this action due to the following failure: (01) 2019-12-18 10:50:06 Slp: ---------------------------------------- (01) 2019-12-18 10:50:06 Slp: The following is an exception stack listing the exceptions in outermost to innermost order (01) 2019-12-18 10:50:06 Slp: Inner exceptions are being indented (01) 2019-12-18 10:50:06 Slp: (01) 2019-12-18 10:50:06 Slp: Exception type: Microsoft.SqlServer.Configuration.Sco.ScoException (01) 2019-12-18 10:50:06 Slp: Message: (01) 2019-12-18 10:50:06 Slp: Attempted to perform an unauthorized operation. (01) 2019-12-18 10:50:06 Slp: HResult : 0x84bb0001 (01) 2019-12-18 10:50:06 Slp: FacilityCode : 1211 (4bb) (01) 2019-12-18 10:50:06 Slp: ErrorCode : 1 (0001) (01) 2019-12-18 10:50:06 Slp: Data: (01) 2019-12-18 10:50:06 Slp: WatsonData = HKEY_LOCAL_MACHINE@System\CurrentControlSet\Services\LanmanServer\Parameters\FsctlAllowList (01) 2019-12-18 10:50:06 Slp: DisableRetry = true (01) 2019-12-18 10:50:06 Slp: Inner exception type: System.UnauthorizedAccessException (01) 2019-12-18 10:50:06 Slp: Message: (01) 2019-12-18 10:50:06 Slp: Attempted to perform an unauthorized operation. (01) 2019-12-18 10:50:06 Slp: HResult : 0x80070005 (01) 2019-12-18 10:50:07 Slp: Stack: (01) 2019-12-18 10:50:07 Slp: at Microsoft.SqlServer.Configuration.Sco.InternalRegistryKey.OpenSubKey(String subkey, RegistryAccess requestedAccess) (01) 2019-12-18 10:50:07 Slp: ---------------------------------------- (01) 2019-12-18 10:53:37 Slp: User has chosen to retry this action (01) 2019-12-18 10:53:37 Slp: Prompting user if they want to retry this action due to the following failure: (01) 2019-12-18 10:53:37 Slp: ---------------------------------------- Это он реестр поменять не может? ... |
| 18.12.2019, 11:06 |
Я вообще считал что express должен ставится вообще просто, чтобы не отталкивать потенциальных клиентов от платного продукта. ... |
| 18.12.2019, 11:09 |
ssms Я вообще считал что express должен ставится вообще просто, чтобы не отталкивать потенциальных клиентов от платного продукта. если устанавливающий юзер какой-то бесправный, то дело в юзере, а не в "бесплатном продукте" ... |
| 18.12.2019, 11:15 |
Yasha123 ssms Я вообще считал что express должен ставится вообще просто, чтобы не отталкивать потенциальных клиентов от платного продукта. если устанавливающий юзер какой-то бесправный, то дело в юзере, а не в "бесплатном продукте" Юзер впролне себе правный, является локальным админом. Установка запущена по правой кнопке "run as administrator". ... |
| 18.12.2019, 11:17 |
ну лог тогда не тот что ли? пишет же, Inner exception type: System.UnauthorizedAccessException ... |
| 18.12.2019, 11:25 |
Yasha123 ну лог тогда не тот что ли? пишет же, Inner exception type: System.UnauthorizedAccessException Лог тот. ... |
| 18.12.2019, 11:29 |
Сервер виртуальный (если это важно) ... |
| 18.12.2019, 11:29 |
По симптомам похоже на это: https://support.microsoft.com/ru-ru/help/2799534/various-problems-may-occur-when-running-sql-server-2012-in-hyper-v-or Кто-нибудь встречал подобную проблему? ... |
| 18.12.2019, 11:49 |
Виндоус свежеустановленная. ... |
| 18.12.2019, 11:52 |
А где посмотреть требования к ОС для установки SQL Server 2016 ExprEd ? А то мож он на виндоус 2016 в принципе не ставится... ... |
| 18.12.2019, 17:39 |
ssms А где посмотреть требования к ОС для установки SQL Server 2016 ExprEd ? А то мож он на виндоус 2016 в принципе не ставится... Вроде должен работать: Поддерживаемая операционная система: Windows 10; Windows 8; Windows 8.1; Windows Server 2008 R2; Windows Server 2008 R2 SP1; Windows Server 2012; Windows Server 2012 R2; Windows Server 2016 ... |
| 18.12.2019, 17:58 |
ssms ssmsА то мож он на виндоус 2016 в принципе не ставится... Вроде должен работать:Да, должен. Вы скопируйте сюда имя установщика. И хоть какую то инфу про винды (язык, версия) ... |
| 18.12.2019, 21:08 |
alexeyvg ssms пропущено... Вроде должен работать: Вы скопируйте сюда имя установщика. И хоть какую то инфу про винды (язык, версия) ... |
| 18.12.2019, 21:11 |
ssms Установка запущена по правой кнопке "run as administrator". ... |
| 18.12.2019, 21:13 |
alexeyvg ssms Установка запущена по правой кнопке "run as administrator". Да, очень странно. У меня впечатление что это е****я виртуализация коряво настроена. ... |
| 19.12.2019, 10:57 |
ssms, это запросто. Поищите: https://www.yandex.ru/search/?text=best practices sql virtualisation&lr=35. ... |
| 19.12.2019, 12:11 |
start [/forum/topic.php?desktop=1&fid=46&tid=1686749]: |
26ms |
64ms |
| others: | 220ms |
| total: | 364ms |
