Collate for Blob/text field
Sorry for English, don't have Russian layout right now. Currently it is not possible to specify the collate for blob text fields, only the charset on domain creation. The only way for now is to use script execution tool and to create domains manually :) ... |
| 29.11.2018, 17:25:38 |
С какой версии ФБ можно коллейты для блоб-полей указывать? ... |
| 01.12.2018, 04:29:41 |
IBExpert, At least i tested with FB 3.0 and the following statement works: CREATE DOMAIN DT_TEXT_UCAI AS BLOB SUB_TYPE 1 SEGMENT SIZE 80 CHARACTER SET UTF8 COLLATE UNICODE_CI_AI; Later I did some case insensitive searches and everything went fine. ... |
| 02.12.2018, 00:11:24 |
start [/forum/topic.php?desktop=1&fid=42&tid=1598787]: |
45ms |
37ms |
| others: | 195ms |
| total: | 322ms |
