ошибка при restore
Есть база на линуксе, FB 1.5. Бэкап проходит без ошибок. Однако ресторе не проходит :( Вот кусок лога при попытке восстановления gbak: gbak: 1090000 records restored gbak: 1100000 records restored gbak: 1110000 records restored gbak: 1120000 records restored gbak: 1130000 records restored gbak: 1132948 records restored gbak: do not recognize table attribute 0 -- continuing gbak: restoring data for table TREATMENT_AMB gbak: 10000 records restored gbak: 20000 records restored gbak: 30000 records restored gbak: 40000 records restored gbak: 50000 records restored gbak: 60000 records restored gbak: 70000 records restored gbak: 80000 records restored gbak: 81151 records restored gbak: ERROR: cannot find table PROFILE_AMB gbak: Exiting before completion due to errors Вот кусок лога при попытке восстановления сервисом из IBexpert: skip... [11:02:16] gbak: 1100000 records restored [11:02:16] gbak: 1110000 records restored [11:02:17] gbak: 1120000 records restored [11:02:17] gbak: 1130000 records restored [11:02:17] gbak: committing data for table TREATMENT_AMB [11:02:17] gbak: 1132948 records restored [11:02:17] gbak: do not recognize table attribute 0 -- continuing [11:02:17] gbak: restoring data for table TREATMENT_AMB [11:02:17] gbak: 10000 records restored [11:02:17] gbak: 20000 records restored [11:02:18] gbak: 30000 records restored [11:02:18] gbak: 40000 records restored [11:02:18] gbak: 50000 records restored [11:02:18] gbak: 60000 records restored [11:02:18] gbak: 70000 records restored [11:02:18] gbak: 80000 records restored [11:02:18] gbak: committing data for table TREATMENT_AMB [11:02:18] gbak: 81151 records restored [11:02:18] gbak: restoring data for table PROFILE_AMB [11:02:18] gbak: committing data for table PROFILE_AMB [11:02:19] gbak: 93 records restored [11:02:19] gbak: restoring index OPERATION_AMB_IDX1 [11:02:19] gbak: restoring index OPERATION_AMB_IDX2 [11:02:19] gbak: restoring index OPERATION_AMB_IDX3 [11:02:19] gbak: restoring index MES [11:02:19] gbak: restoring index MES_DPL_IDX1 [11:02:19] gbak: restoring index MES_DPL_IDX2 [11:02:19] gbak: restoring data for table MES_DPL [11:02:19] gbak: 10000 records restored [11:02:19] gbak: 20000 records restored [11:02:19] gbak: 30000 records restored [11:02:19] gbak: 40000 records restored [11:02:19] gbak: 50000 records restored [11:02:19] gbak: 60000 records restored skip... [11:02:55] gbak: restoring privilege for user SYSDBA [11:02:55] gbak: restoring privilege for user SYSDBA [11:02:55] gbak: restoring privilege for user SYSDBA [11:02:55] gbak: restoring privilege for user SYSDBA IBE: Unsuccessful execution caused by system error that does not preclude successful execution of subsequent statements. connection lost to database. IBE: Restore completed. Current time: 11:02:55. Elapsed time: 00:01:47 как вылечить сие безобразие? ... |
| 18.05.2017, 07:35 |
ошибка при restore
Tactical Nuclear Penguin, точно ли версия gbak совпадает с версией ФБ 1.5? командные строки бэкапа и рестора? бэкап делается куда? другой носитель можно выбрать? вдруг диск с бэкапом глючит... ... |
| 18.05.2017, 11:13 |
ошибка при restore
Похоже, что или бэкап или рестор идёт совсем не на Firebird. Posted via ActualForum NNTP Server 1.5 ... |
| 18.05.2017, 11:13 |
ошибка при restore
kdvTactical Nuclear Penguin, точно ли версия gbak совпадает с версией ФБ 1.5? командные строки бэкапа и рестора? бэкап делается куда? другой носитель можно выбрать? вдруг диск с бэкапом глючит... версии совпадают 100% командные строки самые простые - gbak -b и gbak -c диск может так глючить? попробую на другой... ... |
| 18.05.2017, 11:17 |
ошибка при restore
Dimitry SibiryakovПохоже, что или бэкап или рестор идёт совсем не на Firebird. гм. это как? если имеется в виду Interbase или еще что-то - никогда не ставил... ... |
| 18.05.2017, 11:18 |
ошибка при restore
Tactical Nuclear Penguinесли имеется в виду Interbase или еще что-то - никогда не ставил... Ну, если ты в этом так уверен, то проблема, скорее всего, в дохлом железе. Проверяй ОЗУ, винт, шлейфы. И если восстановление происходило на другом компьютере, то побиться бэкап мог и по дороге. Сравнивай хэши оригинала и копии. Posted via ActualForum NNTP Server 1.5 ... |
| 18.05.2017, 12:45 |
ошибка при restore
Tactical Nuclear PenguinDimitry SibiryakovПохоже, что или бэкап или рестор идёт совсем не на Firebird. гм. это как? если имеется в виду Interbase или еще что-то - никогда не ставил... Я похожую ошибку поймал,когда бэкапил gbak 'ом от форка,имеющего лишние системные таблицы. ... |
| 18.05.2017, 13:09 |
start [/forum/topic.php?desktop=1&fid=40&tid=1561582]: |
211ms |
31ms |
| others: | 228ms |
| total: | 507ms |
