Математические ф-ции в М.
Всем привет.Какие мат.ф-ции есть в М(и его реализациях GT.M, Cache), кроме +,-,**,*,/,\,#? Интересуют напрмер sin, cos, tg, exp, ln и т.д.Если их нет - то какими средствами пользуетесь?Как средствами M округлить число до n знаков? ... |
| 03.08.2013, 09:30:44 |
user_tivКак средствами M округлить число до n знаков? http://docs.intersystems.com/cache20131/csp/docbook/DocBook.UI.Page.cls?KEY=RCOS_fjustify ... |
| 03.08.2013, 10:45:31 |
user_tivИнтересуют напрмер sin, cos, tg, exp, ln и т.д. http://docs.intersystems.com/cache20131/csp/docbook/DocBook.UI.Page.cls?KEY=RCOS_MATHFUNCTIONS ... |
| 03.08.2013, 10:46:54 |
Еще вот это : MATH ;========================================================================= ;Mathmatical Functions ;========================================================================= ;This set of functions was obtained from the ;"M[MUMPs] Draft Standard Version 18 (Millenium) ;which Ed de Moel, as MDC Proposer and Sponsor kindly supplied to me. ;Ed J.P.M. de Moel ;c/o Jacquard Systems Research ;800 Nelson Street ;Rockville Maryland 20850-2051 ;Phone and fax: +1-301-762-8999 ;dem...@jacquardsystems.com ;Please note that I include Ed's name here as a matter of identification and gratitude ;only. He is not providing support for this library. ; ;Since the proposed standard's code already contains many functions, which are not ;yet part of the standard, I adapted this code to GT.M for LINUX and put in code that conforms ;to the current syntax . This required changes, so that THIS CODE DOES NOT CONFROM WITH ;THE PROPOSED STANDARD AND DOES NOT BELONG TO ANY CURRENT STANDARD. ; ;NOT EVERY ROUTINE HAS BEEN TESTED AFTER IT WAS ADAPTED. THE USER MUST ;VERIFY THE ACCURACY OF THE CODE HIMSELF. IN CASE YOU FIND ANY ERRORS OR HAVE SUGGESTIONS ;PLEASE MAKE THEM IN THE SAME DISCUSSION THREAD IN WHICH YOU FOUND THIS MESSAGE. ;All and any liability whatsoever is excluded. Any use is at your own risk. ; ;All suggestions, or the posting of further functions to be included into this ;library is welcome. This library may be copied, distributed and reproduced, provided that ;mentioning is made of the MDC and the sponsor as stated above and that the sharing of ;suggestions and further functions is encouraged. All new suggestions and functions should ;also be made available on google's discussion group comp.lang.mumps, if possible under the ;same discussion thread as this set or routines. ;To find comp.lang.mumps, go to www.google.com and select the groups bottom, then search form MUMPS. ; ;I would also like to thank Sanchez for making their GT.M available for LINUX on Sourceforge.com ;It is an excellent program, simple to handle and well documented: www.sanchez.com ; ;============ CONTENTS =================================================================== ; ;Routine: Key Word ;======== ======== ;--- Mathmatical Functions --- ;ABS Absolute Value ;ARCCOSS Trigonometric arccosine in radians, optimized for speed ;ARCOS Trigonometric arccosine in radians, optimized for precision ;ARCCOSH Hyperbolic Arccosine in radians ;ARCCOT Trigonomic arccotangent in radians ;ARCCOTH Hyperbolic arccotangent in radians ;ARCCSC Trigonometric arccosecant in radians ;ARCSEC Trigonometric arcsecant in radians ;ARCSINS Trigonometric arcsine in radians optimized for speed ;ARCSIN Trigonometric arcsine in radians optimized for precision ;ARCSINH Hyperbolic arcsine in radians ;ARCTAN Trigonometric arctangent in radians ;ARCTANH Hyperbolic artangent in radians ;CABS Absolute value of a complex number ;CADD Sum of two complex numbers ;CCOS Trigonometric consine in radians ;CDIV Division of complex numbers ;CEXP Raise e to the power of a complex number ;CLOG Return the logarithm of a complex number ;CMUL Multiply two complex numbers ;COMPLEX Returns the complex representation of the number specified ;CONJUG Conjugate of a complex number ;COSS Trigonometric cosine in radians, optimized for speed ;COS Trigonometric cosine in radians, optimized for precision ;COSH Hyperbolic cosine in radians ;COT Trigonometric cotangent in radians ;COTH Hyperbolic cotangent in radians ;CPOWER Raise one complex number to the power of another complex number ;CSC Trigonometric cosecant of a complex number in radians ;CSCH Hyperbolic cosecant of a complex number in radians ;CSIN Trigonometric sine of a complex number in radians ;CSUB Subtract one complex number from the other ;DECDMS Convert an angle specified in degrees into the degree:minutes:seconds notation ;DEGRAD Convert an angle specified in degrees into raidans. ;DEMSDEC Convert an angle specified in degree:minutes:seconds into degrees ;E Retrun the value of e ;EXP Raise the value of e to the power of a specified number ;LOG Naperian logarithm ("natural" logarithm) ;LOG10 Briggsian logarithm (logarithm with the base 10) ;MTXADD Add one matrix to the other ;MTXCOF Cofactor ;MTXCOPY Copy a matrix ;MTXDET Determinant of a matrix ;MTXEQU Matrix equation ;MTXINV Invert a matrix ;MTXMUL Multiply one matrix with the other ;MYXSCA Multiply a scalar value with a matrix ;MTXSUB Subtract one matrix from the other ;MTXTRP Transposes one matric into the other ;MTXUNIT Create matrix as a unit matrix ;PI Returns the value of pi ;RADDEG Converts an angle specified in radians into degrees ;SEC Trigonometric secant ;SECH Hyperbolic secant ;SIGN Returns -1 if argument smaller than 0, 0 if argument 0 and +1 if argument greater than 0 ;SINS Trigonometric sine, optimized for speed ;SIN Trigonometric sine, optimized for precision ;SINH Hyperbolic sine ;SQRT Root ;TAN Trigonometric tangent ;TANH Hyperbolic tangent ; ;============ Mathmatical Functions ========================================== ABS(X) Quit $Translate(+X,"-") ARCCOSS(X) ; ; This version of the function is ; optimized for speed, not for precision. ; The 'precision' parameter is not supported, ; and the precision is at best 2 in 10**-8. ; New A,N,R,SIGN,XX If X<-1 Set $Ecode=",M28," If X>1 Set $Ecode=",M28," Set SIGN=1 Set:X<0 X=-X,SIGN=-1 Set A(0)=1.5707963050,A(1)=-0.2145988016,A(2)=0.0889789874 Set A(3)=-0.0501743046,A(4)=0.0308918810,A(5)=-0.0170881256 Set A(6)=0.0066700901,A(7)=-0.0012624911 Set R=A(0),XX=1 For N=1:1:7 Set XX=XX*X,R=A(N)*XX+R Set R=$$SQRT^MATH(1-X,11)*R Quit R*SIGN ARCCOS(X,PREC) ; ; This version of the function is ; optimized for precision. ; New L,LIM,K,SIG,SIGS,VALUE ; If X<-1 Set $Ecode=",M28," If X>1 Set $Ecode=",M28," Set PREC=$Get(PREC,11) If $Translate(X,"-")=1 Quit 0 ; Set SIG=$Select(X<0:-1,1:1),VALUE=1-(X*X) Set X=$$SQRT^MATH(VALUE,PREC) If $Translate(X,"-")=1 Do Quit VALUE . Set VALUE=$$PI^MATH()/2*X . Quit ; If X>0.9 Do Quit VALUE . Set SIGS=$Select(X<0:-1,1:1) . Set VALUE=1/(1/X/X-1) . Set X=$$SQRT^MATH(VALUE,PREC) . Set VALUE=$$ARCTAN^MATH(X,PREC)*SIGS . Quit Set (VALUE,L)=X Set LIM=$Select((PREC+3)'>11:PREC+3,1:11),@("LIM=1E-"_LIM) For K=3:2 Do Quit:($Translate(L,"-")<LIM) . Set L=L*X*X*(K-2)/(K-1)*(K-2)/K,VALUE=VALUE+L . Quit Quit $Select(SIG<0:$$PI^MATH()-VALUE,1:VALUE) ARCCOSH(X,PREC) ; If X<1 Set $Ecode=",M28," New SQ Set PREC=$Get(PREC,11) Set SQ=$$SQRT^MATH(X*X-1,PREC) Quit $$LOG^MATH(X+SQ,PREC) ARCCOT(X,PREC) ; Set PREC=$Get(PREC,11) Set X=1/X Quit $$ARCTAN^MATH(X,PREC) ARCCOTH(X,PREC) ; New L1,L2 Set PREC=$Get(PREC,11) Set L1=$$LOG^MATH(X+1,PREC) Set L2=$$LOG^MATH(X-1,PREC) Quit L1-L2/2 ARCCSC(X,PREC) ; Set PREC=$Get(PREC,11) Set X=1/X Quit $$ARCSIN^MATH(X,PREC) ARCSEC(X,PREC) ; Set PREC=$Get(PREC,11) Set X=1/X Quit $$ARCCOS^MATH(X,PREC) ARCSINS(X) ; ; This version of the function is ; optimized for speed, not for precision. ; The 'precision' parameter is not supported, ; and the precision is at best 2 in 10**-8. ; New A,N,R,SIGN,XX If X<-1 Set $Ecode=",M28," If X>1 Set $Ecode=",M28," Set SIGN=1 Set:X<0 X=-X,SIGN=-1 Set A(0)=1.5707963050,A(1)=-0.2145988016,A(2)=0.0889789874 Set A(3)=-0.0501743046,A(4)=0.0308918810,A(5)=-0.0170881256 Set A(6)=0.0066700901,A(7)=-0.0012624911 Set R=A(0),XX=1 For N=1:1:7 Set XX=XX*X,R=A(N)*XX+R Set R=$$SQRT^MATH(1-X,11)*R Set R=$$PI^MATH()/2-R Quit R*SIGN ARCSIN(X,PREC) ; ;Option 2, optimized for precision, not speed. New L,LIM,K,SIGS,VALUE Set PREC=$Get(PREC,11) If $Translate(X,"-")=1 Do Quit VALUE . Set VALUE=$$PI^MATH()/2*X . Quit If X>0.99999 Do Quit VALUE . Set SIGS=$Select(X<0:-1,1:1) . Set VALUE=1/(1/X/X-1) . Set X=$$SQRT^MATH(VALUE,PREC) . Set VALUE=$$ARCTAN^MATH(X,PREC)*SIGS . Quit Set (VALUE,L)=X Set LIM=$Select((PREC+3)'>11:PREC+3,1:11),@("LIM=1E-"_LIM) For K=3:2 Do Quit:($Translate(L,"-")<LIM) . Set L=L*X*X*(K-2)/(K-1)*(K-2)/K,VALUE=VALUE+L . Quit Quit VALUE ARCSINH(X,PREC) ; If X<1 Set $Ecode=",M28," New SQ Set PREC=$Get(PREC,11) Set SQ=$$SQRT^MATH(X*X+1,PREC) Quit $$LOG^MATH(X+SQ,PREC) ARCTAN(X,PREC) ; New FOLD,HI,L,LIM,LO,K,SIGN,SIGS,SIGT,VALUE Set PREC=$Get(PREC,11) Set LO=0.0000000001,HI=9999999999 Set SIGT=$Select(X<0:-1,1:1),X=$Translate(X,"-") Set X=$Select(X<LO:LO,X>HI:HI,1:X) Set FOLD=$Select(X'<1:0,1:1) Set X=$Select(FOLD:1/X,1:X) Set L=X,VALUE=$$PI^MATH()/2-(1/X),SIGN=1 If X<1.3 Do Quit VALUE . Set X=$Select(FOLD:1/X,1:X),VALUE=1/((1/X/X)+1) . Set X=$$SQRT^MATH(VALUE,PREC) . If $Translate(X,"-")=1 Do Quit . . Set VALUE=$$PI^MATH()/2*X . . Quit . If X>0.9 Do Quit . . Set SIGS=$Select(X<0:-1,1:1) . . Set VALUE=1/(1/X/X-1) . . Set X=$$SQRT^MATH(VALUE) . . Set VALUE=$$ARCTAN(X,10) . . Set VALUE=VALUE*SIGS . . Quit . Set (VALUE,L)=X . Set LIM=$Select((PREC+3)'>11:PREC+3,1:11),@("LIM=1E-"_LIM) . For K=3:2 Do Quit:($Translate(L,"-")<LIM) . . Set L=L*X*X*(K-2)/(K-1)*(K-2)/K,VALUE=VALUE+L . . Quit . Set VALUE=$Select(SIGT<1:-VALUE,1:VALUE) . Quit Set LIM=$Select((PREC+3)'>11:PREC+3,1:11),@("LIM=1E-"_LIM) For K=3:2 Do Quit:($Translate(1/L,"-")<LIM) . Set L=L*X*X,VALUE=VALUE+(1/(K*L)*SIGN) . Set SIGN=SIGN*-1 . Quit Set VALUE=$Select(FOLD:$$PI^MATH()/2-VALUE,1:VALUE) Set VALUE=$Select(SIGT<1:-VALUE,1:VALUE) Quit VALUE ARCTANH(X,PREC) ; If X<-1 Set $Ecode=",M28," If X>1 Set $Ecode=",M28," Set PREC=$Get(PREC,11) Quit $$LOG^MATH(1+X/(1-X),PREC)/2 CABS(Z) ; New ZRE,ZIM Set ZRE=+Z,ZIM=+$Piece(Z,"%",2) Quit $$SQRT^MATH(ZRE*ZRE+(ZIM*ZIM)) CADD(X,Y) ; New XRE,XIM,YRE,YIM Set XRE=+X,XIM=+$Piece(X,"%",2) Set YRE=+Y,YIM=+$Piece(Y,"%",2) Quit XRE+YRE_"%"_(XIM+YIM) CCOS(Z,PREC) ; New E1,E2,IA Set PREC=$Get(PREC,11) Set IA=$$CMUL^MATH(Z,"0%1") Set E1=$$CEXP^MATH(IA,PREC) Set IA=-IA_"%"_(-$Piece(IA,"%",2)) Set E2=$$CEXP^MATH(IA,PREC) Set IA=$$CADD^MATH(E1,E2) Quit $$CMUL^MATH(IA,"0.5%0") CDIV(X,Y) ; New D,IM,RE,XIM,XRE,YIM,YRE Set XRE=+X,XIM=+$Piece(X,"%",2) Set YRE=+Y,YIM=+$Piece(Y,"%",2) Set D=YRE*YRE+(YIM*YIM) Set RE=XRE*YRE+(XIM*YIM)/D Set IM=XIM*YRE-(XRE*YIM)/D Quit RE_"%"_IM CEXP(Z,PREC) ; New R,ZIM,ZRE Set PREC=$Get(PREC,11) Set ZRE=+Z,ZIM=+$Piece(Z,"%",2) Set R=$$EXP^MATH(ZRE,PREC) Quit R*$$COS^MATH(ZIM,PREC)_"%"_(R*$$SIN^MATH(ZIM,PREC)) CLOG(Z,PREC) ; New ABS,ARG,ZIM,ZRE Set PREC=$Get(PREC,11) Set ABS=$$CABS^MATH(Z) Set ZRE=+Z,ZIM=+$Piece(Z,"%",2) Set ARG=$$ARCTAN^MATH(ZIM/ZRE,PREC) Quit $$LOG^MATH(ABS,PREC)_"%"_ARG CMUL(X,Y) ; New XIM,XRE,YIM,YRE Set XRE=+X,XIM=+$Piece(X,"%",2) Set YRE=+Y,YIM=+$Piece(Y,"%",2) Quit XRE*YRE-(XIM*YIM)_"%"_(XRE*YIM+(XIM*YRE)) COMPLEX(X) Quit +X_"%0" CONJUG(Z) ; New ZIM,ZRE Set ZRE=+Z,ZIM=+$Piece(Z,"%",2) Quit ZRE_"%"_(-ZIM) COSS(X) ; ; This version of the function is ; optimized for speed, not for precision. ; The 'precision' parameter is not supported, ; and the precision is at best 1 in 10**-9. ; Note that this function does not accept its ; parameter in degrees, minutes and seconds. ; New A,N,PI,R,SIGN,XX ; ; This approximation only works for 0 <= x <= pi/2 ; so reduce angle to correct quadrant. ; Set PI=$$PI^MATH(),X=X#(PI*2),SIGN=1 Set:X>PI X=2*PI-X Set:X*2>PI X=PI-X,SIGN=-1 ; Set XX=X*X,A(1)=-0.4999999963,A(2)=0.0416666418 Set A(3)=-0.0013888397,A(4)=0.0000247609,A(5)=-0.0000002605 Set (X,R)=1 For N=1:1:5 Set X=X*XX,R=A(N)*X+R Quit R*SIGN COS(X,PREC) ; New L,LIM,K,SIGN,VALUE ; Option 2, optimized for precision, not speed. ; The official description does not mention that ; the function may also be called with the first ; parameter in degrees, minutes and seconds. Set:X[":" X=$$DMSDEC^MATH(X) ; Set PREC=$Get(PREC,11) Set X=X#(2*$$PI^MATH()) Set (VALUE,L)=1,SIGN=-1 Set LIM=$Select((PREC+3)'>11:PREC+3,1:11),@("LIM=1E-"_LIM) For K=2:2 Do Quit:($Translate(L,"-")<LIM) Set SIGN=SIGN*-1 . Set L=L*X*X/(K-1*K),VALUE=VALUE+(SIGN*L) . Quit Quit VALUE COSH(X,PREC) ; New E,F,I,P,R,T,XX Set PREC=$Get(PREC,11)+1 Set @("E=1E-"_PREC) Set XX=X*X,F=1,(P,R,T)=1,I=1 For Set T=T*XX,F=I+1*I*F,R=T/F+R,P=P-R/R,I=I+2 If -E<P,P<E Quit Quit R COT(X,PREC) ; New C,L,LIM,K,SIGN,VALUE ; The official description does not mention that ; the function may also be called with the first ; parameter in degrees, minutes and seconds. Set:X[":" X=$$DMSDEC^MATH(X) ; Set PREC=$Get(PREC,11) Set (VALUE,L)=1,SIGN=-1 Set LIM=$Select((PREC+3)'>11:PREC+3,1:11),@("LIM=1E-"_LIM) For K=2:2 Do Quit:($Translate(L,"-")<LIM) Set SIGN=SIGN*-1 . Set L=L*X*X/(K-1*K),VALUE=VALUE+(SIGN*L) . Quit Set C=VALUE Set X=X#(2*$$PI^MATH()) Set (VALUE,L)=X,SIGN=-1 Set LIM=$Select((PREC+3)'>11:PREC+3,1:11),@("LIM=1E-"_LIM) For K=3:2 Do Quit:($Translate(L,"-")<LIM) Set SIGN=SIGN*-1 . Set L=L/(K-1)*X/K*X,VALUE=VALUE+(SIGN*L) . Quit If 'VALUE Quit "INFINITE" Quit VALUE=C/VALUE COTH(X,PREC) ; New SINH If 'X Quit "INFINITE" ; Set PREC=$Get(PREC,11) Set SINH=$$SINH^MATH(X,PREC) If 'SINH Quit "INFINITE" Quit $$COSH^MATH(X,PREC)/SINH CPOWER(Z,N,PREC) ; New AR,NIM,NRE,PHI,PI,R,RHO,TH,ZIM,ZRE ; Set PREC=$Get(PREC,11) Set ZRE=+Z,ZIM=+$Piece(Z,"%",2) Set NRE=+N,NIM=+$Piece(N,"%",2) If 'ZRE,'ZIM,'NRE,'NIM Set $Ecode=",M28," ; If 'ZRE,'ZIM Quit "0%0" ; Set PI=$$PI^MATH() Set R=$$SQRT^MATH(ZRE*ZRE+(ZIM*ZIM),PREC) ; If ZRE Set TH=$$ARCTAN^MATH(ZIM/ZRE,PREC) Else Set TH=$SELECT(ZIM>0:PI/2,1:-PI/2) ; Set RHO=$$LOG^MATH(R,PREC) Set AR=$$EXP^MATH(RHO*NRE-(TH*NIM),PREC) Set PHI=RHO*NIM+(NRE*TH) Quit AR*$$COS^MATH(PHI,PREC)_"%"_(AR*$$SIN^MATH(PHI,PREC)) CSC(X,PREC) ; New L,LIM,K,SIGN,VALUE ; ; The official description does not mention that ; the function may also be called with the first ; parameter in degrees, minutes and seconds. Set:X[":" X=$$DMSDEC^MATH(X) ; Set PREC=$Get(PREC,11) ; Set X=X#(2*$$PI^MATH()) Set (VALUE,L)=X,SIGN=-1 Set LIM=$Select((PREC+3)'>11:PREC+3,1:11),@("LIM=1E-"_LIM) For K=3:2 Do Quit:($Translate(L,"-")<LIM) Set SIGN=SIGN*-1 . Set L=L/(K-1)*X/K*X,VALUE=VALUE+(SIGN*L) . Quit If 'VALUE Quit "INFINITE" Quit 1/VALUE CSCH(X,PREC) Quit 1/$$SINH^MATH(X,$Get(PREC,11)) CSIN(Z,PREC) ; New IA,E1,E2 ; Set PREC=$Get(PREC,11) ; Set IA=$$CMUL^MATH(Z,"0%1") Set E1=$$CEXP^MATH(IA,PREC) Set IA=-IA_"%"_(-$Piece(IA,"%",2)) Set E2=$$CEXP^MATH(IA,PREC) Set IA=$$CSUB^MATH(E1,E2) Set IA=$$CMUL^MATH(IA,"0.5%0") Quit $$CMUL^MATH("0%-1",IA) CSUB(X,Y) ; New XIM,XRE,YIM,YRE Set XRE=+X,XIM=+$Piece(X,"%",2) Set YRE=+Y,YIM=+$Piece(Y,"%",2) Quit XRE-YRE_"%"_(XIM-YIM) DECDMS(X,PREC) New T Set PREC=$Get(PREC,5) Set X=X#360*3600 Set T=PREC-$Length(X\1) Set X=+$Justify(X,0,$Select(T'<0:T,1:0)) Quit X\3600_":"_(X\60#60)_":"_(X#60) DEGRAD(X) Quit X*3.14159265358979/180 DMSDEC(X) ; Quit $Piece(X,":")+($Piece(X,":",2)/60)+($Piece(X,":",3)/3600) E() Quit 2.71828182845905 EXP(X,PREC) ; New L,LIM,K,VALUE Set PREC=$Get(PREC,11) Set L=X,VALUE=X+1 Set LIM=$Select((PREC+3)'>11:PREC+3,1:11),@("LIM=1E-"_LIM) For K=2:1 Set L=L*X/K,VALUE=VALUE+L Quit:($Translate(L,"-")<LIM) Quit VALUE LOG(X,PREC) ; New L,LIM,M,N,K,VALUE If X'>0 Set $Ecode=",M28," Set PREC=$Get(PREC,11) Set M=1 ; For N=0:1 Quit:(X/M)<10 Set M=M*10 ; If X<1 For N=0:-1 Quit:(X/M)>0.1 Set M=M*0.1 Set X=X/M Set X=(X-1)/(X+1),(VALUE,L)=X Set LIM=$Select((PREC+3)'>11:PREC+3,1:11),@("LIM=1E-"_LIM) For K=3:2 Set L=L*X*X,M=L/K,VALUE=M+VALUE Set:M<0 M=-M Quit:M<LIM Set VALUE=VALUE*2+(N*2.30258509298749) Quit VALUE LOG10(X,PREC) ; New L,LIM,M,N,K,VALUE If X'>0 Set $Ecode=",M28," Set PREC=$Get(PREC,11) Set M=1 For N=0:1 Quit:(X/M)<10 Set M=M*10 If X<1 For N=0:-1 Quit:(X/M)>0.1 Set M=M*0.1 Set X=X/M Set X=(X-1)/(X+1),(VALUE,L)=X Set LIM=$Select((PREC+3)'>11:PREC+3,1:11),@("LIM=1E-"_LIM) For K=3:2 Set L=L*X*X,M=L/K,VALUE=M+VALUE Set:M<0 M=-M Quit:M<LIM Set VALUE=VALUE*2+(N*2.30258509298749) Quit VALUE/2.30258509298749 MTXADD(A,B,R,ROWS,COLS) ; ; Add A[ROWS,COLS] to B[ROWS,COLS], ; result goes to R[ROWS,COLS] If $Data(A)<10 Quit 0 If $Data(B)<10 Quit 0 If $Get(ROWS)<1 Quit 0 If $Get(COLS)<1 Quit 0 ; New ROW,COL,ANY For ROW=1:1:ROWS For COL=1:1:COLS Do . Kill R(ROW,COL) Set ANY=0 . Set:$Data(A(ROW,COL))#2 ANY=1 . Set:$Data(B(ROW,COL))#2 ANY=1 . Set:ANY R(ROW,COL)=$Get(A(ROW,COL))+$Get(B(ROW,COL)) . Quit Quit 1 MTXCOF(A,I,K,N) ; ; Compute cofactor for element [i,k] ; in matrix A[N,N] New T,R,C,RR,CC Set CC=0 For C=1:1:N Do:C'=K . Set CC=CC+1,RR=0 . For R=1:1:N Set:R'=I RR=RR+1,T(RR,CC)=$Get(A(R,C)) . Quit Quit $$MTXDET^MATH(.T,N-1) MTXCOPY(A,R,ROWS,COLS) ; ; Copy A[ROWS,COLS] to R[ROWS,COLS] If $Data(A)<10 Quit 0 If $Get(ROWS)<1 Quit 0 If $Get(COLS)<1 Quit 0 ; New ROW,COL For ROW=1:1:ROWS For COL=1:1:COLS Do . Kill R(ROW,COL) . Set:$Data(A(ROW,COL))#2 R(ROW,COL)=A(ROW,COL) . Quit Quit 1 MTXDET(A,N) ; ; Compute determinant of matrix A[N,N] If $Data(A)<10 Quit "" If $Get(N)<1 Quit "" ; ; First the simple cases ; If N=1 Quit $Get(A(1,1)) If N=2 Quit $Get(A(1,1))*$Get(A(2,2))-($Get(A(1,2))*$Get(A(2,1))) ; New DET,I,SIGN ; ; Det A = sum (k=1:n) element (i,k) * cofactor [i,k] ; Set DET=0,SIGN=1 For I=1:1:N Do . Set DET=$Get(A(1,I))*$$MTXCOF^MATH(.A,1,I,N)*SIGN+DET . Set SIGN=-SIGN . Quit Quit DET MTXEQU(A,B,R,N,M) ; ; Solve matrix equation A [M,M] * R [M,N] = B [M,N] If $Get(M)<1 Quit "" If $Get(N)<1 Quit "" If '$$MTXDET^MATH(.A,M) Quit 0 ; New I,I1,J,J1,J2,K,L,T,T1,T2,TEMP,X ; Set X=$$MTXCOPY^MATH(.A,.T,N,N) Set X=$$MTXCOPY^MATH(.B,.R,N,M) ; ; Reduction of matrix A ; Steps of reduction are counted by index K ; For K=1:1:N-1 Do . ; . ; Search for largest coefficient of T . ; (denoted by TEMP) . ; in first column of reduced system . ; . Set TEMP=0,J2=K . For J1=K:1:N Do . . Quit:$TRanslate($Get(T(J1,K)),"-")>$TRanslate(TEMP,"-") . . Set TEMP=T(J1,K),J2=J1 . . Quit . ; . ; Exchange row number K with row number J2, . ; if necessary . ; . Do:J2'=K . . ; . . For J=K:1:N Do . . . Set T1=$Get(T(K,J)),T2=$Get(T(J2,J)) . . . Kill T(K,J),T(J2,J) . . . If T1'="" Set T(J2,J)=T1 . . . If T2'="" Set T(K,J)=T2 . . . Quit . . For J=1:1:M Do . . . Set T1=$Get(R(K,J)),T2=$Get(R(J2,J)) . . . Kill R(K,J),R(J2,J) . . . If T1'="" Set R(J2,J)=T1 . . . If T2'="" Set R(K,J)=T2 . . . Quit . . Quit . ; . ; Actual reduction . ; . For I=K+1:1:N Do . . For J=K+1:1:N Do . . . Quit:'$Get(T(K,K)) . . . Set T(I,J)=-$Get(T(K,J))*$Get(T(I,K))/T(K,K)+$Get(T(I,J)) . . . Quit . . For J=1:1:M Do . . . Quit:'$Get(T(K,K)) . . . Set R(I,J)=-$Get(R(K,J))*$Get(T(I,K))/T(K,K)+$Get(R(I,J)) . . . Quit . . Quit . Quit ; ; Backsubstitution ; For J=1:1:M Do . If $Get(T(N,N)) Set R(N,J)=$Get(R(N,J))/T(N,N) . If N-1>0 For I1=1:1:N-1 Do . . Set I=N-I1 . . For L=I+1:1:N Do . . . Set R(I,J)=-$Get(T(I,L))*$Get(R(L,J))+$Get(R(I,J)) . . . Quit . . If $Get(T(I,I)) Set R(I,J)=$Get(R(I,J))/$Get(T(I,I)) . . Quit . Quit Quit $Select(M=N:$$MTXDET^MATH(.R,M),1:1) MTXINV(A,R,N) ; ; Invert A[N,N], result goes to R[N,N] If $Data(A)<10 Quit 0 If $Get(N)<1 Quit 0 ; New T,X Set X=$$MTXUNIT^MATH(.T,N) Quit $$MTXEQU^MATH(.A,.T,.R,N,N) MTXMUL(A,B,R,M,L,N) ; ; Multiply A[M,L] by B[L,N], result goes to R[M,N] If $Data(A)<10 Quit 0 If $Data(B)<10 Quit 0 If $Get(L)<1 Quit 0 If $Get(M)<1 Quit 0 If $Get(N)<1 Quit 0 ; New I,J,K,SUM,ANY For I=1:1:M For J=1:1:N Do . Set (SUM,ANY)=0 . Kill R(I,J) . For K=1:1:L Do . . Set:$Data(A(I,K))#2 ANY=1 . . Set:$Data(B(K,J))#2 ANY=1 . . Set SUM=$Get(A(I,K))*$Get(B(K,J))+SUM . . Quit . Set:ANY R(I,J)=SUM . Quit Quit 1 MTXSCA(A,R,ROWS,COLS,S) ; ; Multiply A[ROWS,COLS] with the scalar S, ; result goes to R[ROWS,COLS] If $Data(A)<10 Quit 0 If $Get(ROWS)<1 Quit 0 If $Get(COLS)<1 Quit 0 If '($Data(S)#2) Quit 0 ; New ROW,COL For ROW=1:1:ROWS For COL=1:1:COLS Do . Kill R(ROW,COL) . Set:$Data(A(ROW,COL))#2 R(ROW,COL)=A(ROW,COL)*S . Quit Quit 1 MTXSUB(A,B,R,ROWS,COLS) ; ; Subtract B[ROWS,COLS] from A[ROWS,COLS], ; result goes to R[ROWS,COLS] If $Data(A)<10 Quit 0 If $Data(B)<10 Quit 0 If $Get(ROWS)<1 Quit 0 If $Get(COLS)<1 Quit 0 ; New ROW,COL,ANY For ROW=1:1:ROWS For COL=1:1:COLS Do . Kill R(ROW,COL) Set ANY=0 . Set:$Data(A(ROW,COL))#2 ANY=1 . Set:$Data(B(ROW,COL))#2 ANY=1 . Set:ANY R(ROW,COL)=$Get(A(ROW,COL))-$Get(B(ROW,COL)) . Quit Quit 1 MTXTRP(A,R,M,N) ; ; Transpose A[M,N], result goes to R[N,M] If $Data(A)<10 Quit 0 If $Get(M)<1 Quit 0 If $Get(N)<1 Quit 0 ; New I,J,K,D1,V1,D2,V2 For I=1:1:M+N-1 For J=1:1:I+1\2 Do . Set K=I-J+1 . If K=J Do Quit . . Set V1=$Get(A(J,J)),D1=$Data(A(J,J))#2 . . If J'>N,J'>M Kill R(J,J) Set:D1 R(J,J)=V1 . . Quit . ; . Set V1=$Get(A(K,J)),D1=$Data(A(K,J))#2 . Set V2=$Get(A(J,K)),D2=$Data(A(J,K))#2 . If K'>M,J'>N Kill R(K,J) Set:D2 R(K,J)=V2 . If J'>M,K'>N Kill R(J,K) Set:D1 R(J,K)=V1 . Quit Quit 1 MTXUNIT(R,N,SPARSE) ; ; Create a unit matrix R[N,N] If $Get(N)<1 Quit 0 ; New ROW,COL For ROW=1:1:N For COL=1:1:N Do . Kill R(ROW,COL) . If $Get(SPARSE) Quit:ROW'=COL . Set R(ROW,COL)=$Select(ROW=COL:1,1:0) . Quit Quit 1 PI() Quit 3.14159265358979 RADDEG(X) Quit X*180/3.14159265358979 SEC(X,PREC) ; New L,LIM,K,SIGN,VALUE ; ; The official description does not mention that ; the function may also be called with the first ; parameter in degrees, minutes and seconds. Set:X[":" X=$$DMSDEC^MATH(X) ; Set PREC=$Get(PREC,11) Set X=X#(2*$$PI^MATH()) Set (VALUE,L)=1,SIGN=-1 Set LIM=$Select((PREC+3)'>11:PREC+3,1:11),@("LIM=1E-"_LIM) For K=2:2 Do Quit:($Translate(L,"-")<LIM) Set SIGN=SIGN*-1 . Set L=L*X*X/(K-1*K),VALUE=VALUE+(SIGN*L) . Quit If 'VALUE Quit "INFINITE" Quit 1/VALUE SECH(X,PREC) Quit 1/$$COSH^MATH(X,$Get(PREC,11)) SIGN(X) Quit $Select(X<0:-1,X>0:1,1:0) SINS(X) ; ; ; This version of the function is ; optimized for speed, not for precision. ; The 'precision' parameter is not supported, ; and the precision is at best 1 in 10**-9. ; Note that this function does not accept its ; parameter in degrees, minutes and seconds. ; New A,N,PI,R,SIGN,XX ; ; This approximation only works for 0 <= x <= pi/2 ; so reduce angle to correct quadrant. ; Set PI=$$PI^MATH(),X=X#(PI*2),SIGN=1 Set:X>PI X=2*PI-X,SIGN=-1 Set:X*2<PI X=PI-X Set XX=X*X,A(1)=-0.4999999963,A(2)=0.0416666418 Set A(3)=-0.0013888397,A(4)=0.0000247609,A(5)=-0.0000002605 Set (X,R)=1 For N=1:1:5 Set X=X*XX,R=A(N)*X+R Quit R*SIGN SIN(X,PREC) ; New L,LIM,K,SIGN,VALUE ; ; Option 2, optimized for precision, not speed ; The official description does not mention that ; the function may also be called with the first ; parameter in degrees, minutes and seconds. Set:X[":" X=$$DMSDEC^MATH(X) ; Set PREC=$Get(PREC,11) Set X=X#(2*$$PI^MATH()) Set (VALUE,L)=X,SIGN=-1 Set LIM=$Select((PREC+3)'>11:PREC+3,1:11),@("LIM=1E-"_LIM) For K=3:2 Do Quit:($Translate(L,"-")<LIM) Set SIGN=SIGN*-1 . Set L=L/(K-1)*X/K*X,VALUE=VALUE+(SIGN*L) . Quit Quit VALUE SINH(X,PREC) ; New E,F,I,P,R,T,XX ; Set PREC=$Get(PREC,11)+1 Set @("E=1E-"_PREC) Set XX=X*X,F=1,I=2,(P,R,T)=X For Set T=T*XX,F=I+1*I*F,R=T/F+R,P=P-R/R,I=I+2 If -E<P,P<E Quit Quit R SQRT(X,PREC) ; If X<0 Set $Ecode=",M28," If X=0 Quit 0 ; Set PREC=$Get(PREC,11) If X<1 Quit 1/$$SQRT^MATH(1/X,PREC) ; New P,R,E Set PREC=$Get(PREC,11)+1 Set @("E=1E-"_PREC) ; Set R=X For Set P=R,R=X/R+R/2,P=P-R/R If -E<P,P<E Quit Quit R TAN(X,PREC) ; New L,LIM,K,S,SIGN,VALUE ; ; The official description does not mention that ; the function may also be called with the first ; parameter in degrees, minutes and seconds. Set:X[":" X=$$DMSDEC^MATH(X) ; Set PREC=$Get(PREC,11) Set X=X#(2*$$PI^MATH()) Set (VALUE,L)=X,SIGN=-1 Set LIM=$Select((PREC+3)'>11:PREC+3,1:11),@("LIM=1E-"_LIM) For K=3:2 Do Quit:($Translate(L,"-")<LIM) Set SIGN=SIGN*-1 . Set L=L/(K-1)*X/K*X,VALUE=VALUE+(SIGN*L) . Quit Set S=VALUE Set X=X#(2*$$PI^MATH()) Set (VALUE,L)=1,SIGN=-1 Set LIM=$Select((PREC+3)'>11:PREC+3,1:11),@("LIM=1E-"_LIM) For K=2:2 Do Quit:($Translate(L,"-")<LIM) Set SIGN=SIGN*-1 . Set L=L*X*X/(K-1*K),VALUE=VALUE+(SIGN*L) . Quit If 'VALUE Quit "INFINITE" Quit S/VALUE TANH(X,PREC) ; Set PREC=$Get(PREC,11) ; Quit $$SINH^MATH(X,PREC)/$$COSH^MATH(X,PREC) ... |
| 03.08.2013, 11:09:40 |
start [/forum/topic.php?desktop=1&fid=39&tid=1557087]: |
30ms |
67ms |
82ms |
| others: | 397ms |
| total: | 633ms |
