Генерация java классов для доступа к 1с web сервисам
Всем доброго времени суток. Задеплоил Web сервис 1с (8.2) на Apache 2.2. В браузере выдается содержание сервиса по Wsdl. ( http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl) При попытке сгенерить джава классы для доступа к сервису с помощью wsimport [WARNING] src-resolve: Cannot resolve the name 'xs2:TestRes' to a(n) 'type definition' component. line 135 of http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl#types?schema3 [WARNING] cos-nonambig: WC[##any] and " http://www.scheduler-comon.org":Cnt (or elements from their substitution group) violate "Unique Particle Attribution". During validation against this schema , ambiguity would be created for those two particles. line 60 of http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl#types?schema2 [WARNING] cos-nonambig: WC[##any] and WC[##any] (or elements from their substitution group) violate "Unique Particle Attribution". During validation against this schema, ambiguity would be create d for those two particles. line 103 of http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl#types?schema2 [WARNING] cos-nonambig: WC[##any] and " http://www.scheduler-root.org":organ_s (or elements from their substitution group) violate "Unique Particle Attribution". During validation against this sch ema, ambiguity would be created for those two particles. line 30 of http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl#types?schema1 [ERROR] Property "Any" is already defined. Use <jaxb:property> to resolve this conflict. line 110 of http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl [ERROR] The following location is relevant to the above error line 84 of http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl [ERROR] Property "Any" is already defined. Use <jaxb:property> to resolve this conflict. line 69 of http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl [ERROR] The following location is relevant to the above error line 84 of http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl [ERROR] Property "Any" is already defined. Use <jaxb:property> to resolve this conflict. line 39 of http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl [ERROR] The following location is relevant to the above error line 84 of http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl [WARNING] src-resolve: Cannot resolve the name 'xs2:TestRes' to a(n) 'type definition' component. line 135 of http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl#types?schema3 [WARNING] cos-nonambig: WC[##any] and " http://www.scheduler-comon.org":Cnt (or elements from their substitution group) violate "Unique Particle Attribution". During validation against this schema , ambiguity would be created for those two particles. line 60 of http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl#types?schema2 [WARNING] cos-nonambig: WC[##any] and WC[##any] (or elements from their substitution group) violate "Unique Particle Attribution". During validation against this schema, ambiguity would be create d for those two particles. line 103 of http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl#types?schema2 [WARNING] cos-nonambig: WC[##any] and " http://www.scheduler-root.org":organ_s (or elements from their substitution group) violate "Unique Particle Attribution". During validation against this sch ema, ambiguity would be created for those two particles. line 30 of http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl#types?schema1 [ERROR] Property "Any" is already defined. Use <jaxb:property> to resolve this conflict. line 110 of http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl [ERROR] The following location is relevant to the above error line 84 of http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl [ERROR] Property "Any" is already defined. Use <jaxb:property> to resolve this conflict. line 69 of http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl [ERROR] The following location is relevant to the above error line 84 of http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl [ERROR] Property "Any" is already defined. Use <jaxb:property> to resolve this conflict. line 39 of http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl [ERROR] The following location is relevant to the above error line 84 of http://192.168.0.101:81/1cwebgate/ws/SchedulerSrv?wsdl Что я сделал не верно при создании сервисов в 1С? Спасибо ... |
| 28.08.2013, 21:34 |
start [/forum/topic.php?desktop=1&fid=28&tid=1519692]: |
87ms |
32ms |
| others: | 252ms |
| total: | 425ms |
