Не обновляется на свежем репозитарии
Добрый день! Помогите, пожалуйста, разобраться! Есть сервер: s-mf39-nixupd (10.1.2.215) cat /etc/release Oracle Solaris 11.3 X86 Copyright (c) 1983, 2015, Oracle and/or its affiliates. All rights reserved. Assembled 06 October 2015 На нём установлен репозиторий c последней версией SRU (11.3.35): pkg publisher PUBLISHER TYPE STATUS P LOCATION solaris origin online F file:///repositories/ И запущен pkg/server: svcs -a | grep application/pkg/server online Oct_31 svc:/application/pkg/server:default Прослушивается 80 порт:: netstat -a -P tcp | grep "*.80" Local Address Remote Address Swind Send-Q Rwind Recv-Q State -------------------- -------------------- ------- ------ ------- ------ ----------- *.80 *.* 0 0 128000 0 LISTEN pkg info entire Name: entire Summary: Incorporation to lock all system packages to the same build Description: This package constrains system package versions to the same build. WARNING: Proper system update and correct package selection depend on the presence of this incorporation. Removing this package will result in an unsupported system. Category: Meta Packages/Incorporations State: Installed Publisher: solaris Version: 0.5.11 (Oracle Solaris 11.3.1.5.0) Build Release: 5.11 Branch: 0.175.3.1.0.5.0 Packaging Date: October 6, 2015 02:00:51 PM Size: 5.46 kB FMRI: pkg://solaris/entire@0.5.11,5.11-0.175.3.1.0.5.0:20151006T140051Z Вроде всё настроено и я на этом сервере установил программу mc (pkg install mc) Хотя, меня эта запись смущает: Summary: Incorporation to lock all system packages to the same build ============================================================================================================== Иду на другой хост: s-ma98-ladmin (10.1.2.197) cat /etc/release Oracle Solaris 11.3 X86 Copyright (c) 1983, 2017, Oracle and/or its affiliates. All rights reserved. Assembled 05 October 2017 Настроил на сервер с репозиторием: pkg publisher PUBLISHER TYPE STATUS P LOCATION solaris origin online F http://10.1.2.215:80/ Смотрю версию: pkg info entire Name: entire Summary: entire incorporation including Support Repository Update (Oracle Solaris 11.3.29.5.0). Description: This package constrains system package versions to the same build. WARNING: Proper system update and correct package selection depend on the presence of this incorporation. Removing this package will result in an unsupported system. For more information see: https://support.oracle.com/rs?type=doc&id=2045311.1 Category: Meta Packages/Incorporations State: Installed Publisher: solaris Version: 0.5.11 (Oracle Solaris 11.3.29.5.0) Build Release: 5.11 Branch: 0.175.3.29.0.5.0 Packaging Date: February 14, 2018 01:36:11 AM Last Install Time: December 11, 2017 02:35:25 PM Last Update Time: March 15, 2018 11:56:10 AM Size: 5.46 kB FMRI: pkg://solaris/entire@0.5.11,5.11-0.175.3.29.0.5.0:20180214T013611Z Видно, что версия устарела. Пробую обновить: pkg update No updates available for this image. Не обновляется, почему? Заранее благодарен. Борис. ... |
| 12.11.2018, 14:01:47 |
На s-mf39-nixupd репозиторий паблишера solaris находится в /repositories, проверьте, что он актуальный. Тот факт, что запущен pkg server, ещё не говорит о том, что он тоже смотрит на этот репозиторий :) Тот факт, что s-ma98-ladmin настроен на pkg server, запущенный на s-mf39-nixupd, ещё не говорит о том, что обновлялся он с него :) Я бы проверил, что вообще есть в репозиториях, так: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. Сообщение "Summary: Incorporation to lock all system packages to the same build" просто описывает саму суть такой штуки, как incorporation - общесистемного ограничителя версий пакетов. Да, кстати - в 11.4 (если вдруг туда собираетесь) mc слегка подвыпилен. Нужно или самому собирать или ставить со стороны или делать так: Код: plaintext ... |
| 12.11.2018, 20:52:18 |
Scott Tiger, Вроде так: root@s-mf39-nixupd:~# pkg list -af entire NAME (PUBLISHER) VERSION IFO entire 0.5.11-0.175.3.1.0.5.0 i-- root@s-mf39-nixupd:~# ... |
| 13.11.2018, 11:12:56 |
start [/forum/topic.php?desktop=1&fid=25&tid=1481235]: |
50ms |
71ms |
| others: | 330ms |
| total: | 531ms |
