Помогите найти Ошибку, Или укажите её!!!
| 10.02.2011, 20:15:03 |
Das_alou, <ResourceDictionary xmlns=" http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x=" http://schemas.microsoft.com/winfx/2006/xaml"> <Style TargetType="{x:Type Button}" x:Key="Button"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="{x:Type Button}" x:Name="But"> <Border x:Name="Buton" > <Ellipse Fill="{StaticResource HorizontalNormalBrush}" Height="100" Width="100" Stroke="Black"/> </Border> <ControlTemplate.Triggers> <Trigger Property="IsPressed" Value="True"> <Setter TargetName="Buton" Property="Background" Value="{StaticResource LightBrush}"/> </Trigger> </ControlTemplate.Triggers> </ControlTemplate> </Setter.Value> </Setter> </Style> <LinearGradientBrush x:Key="LightBrush" StartPoint="0,0" EndPoint="0,1"> <GradientBrush.GradientStops> <GradientStopCollection> <GradientStop Color="#FFF" Offset="0.0"/> <GradientStop Color="#EEE" Offset="1.0"/> </GradientStopCollection> </GradientBrush.GradientStops> </LinearGradientBrush> <LinearGradientBrush x:Key="HorizontalNormalBrush" StartPoint="0,0" EndPoint="1,0"> <GradientBrush.GradientStops> <GradientStopCollection> <GradientStop Color="Red" Offset="0.0"/> <GradientStop Color="Black" Offset="1.0"/> </GradientStopCollection> </GradientBrush.GradientStops> </LinearGradientBrush> </ResourceDictionary> ... |
| 11.02.2011, 00:22:56 |
HorizontalNormalBrush не виден для эллипса. Надо ресурс наверх просто поставить: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. ... |
| 11.02.2011, 09:36:44 |
start [/forum/topic.php?desktop=1&fid=21&tid=1442465]: |
72ms |
34ms |
| others: | 200ms |
| total: | 344ms |
