проблема с PollingDuplexHttpBinding
вот мой app.config <?xml version="1.0" encoding="utf-8" ?> <configuration> <system.web> <compilation debug="true" /> </system.web> <!-- Во время развертывания проекта библиотеки служб содержимое файла конфигурации необходимо добавить к файлу app.config на узле. Файлы конфигурации для библиотек не поддерживаются System.Configuration. --> <system.serviceModel> <extensions> <bindingExtensions> <add name="pollingDuplexHttpBinding" type="System.ServiceModel.Configuration.PollingDuplexHttpBindingCollectionElement, System.ServiceModel.PollingDuplex, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/> </bindingExtensions> </extensions> <bindings> <pollingDuplexHttpBinding> <binding name="PollingDuplexHttpBinding" sendTimeout="00:00:05"> <security mode="Transport"/> </binding> </pollingDuplexHttpBinding> </bindings> <services> <service behaviorConfiguration="SIHouseServiceBehavior" name="SIHService.Service1"> <endpoint address=" http://localhost:8732/Design_Time_Addresses/SIHService/Service1/WPF/" binding="wsDualHttpBinding" contract="SIHService.IService1"> <identity> <dns value="localhost:8732" /> </identity> </endpoint> <endpoint address=" http://localhost:8732/Design_Time_Addresses/SIHService/Service1/SL/" binding="PollingDuplexHttpBinding" contract="SIHService.IService1"> <identity> <dns value="localhost:8732" /> </identity> </endpoint> <endpoint address="mex" binding="mexHttpBinding" contract="IMetadataExchange" /> </service> <service name="SIHService.CrossDomainService" behaviorConfiguration="DefaultServiceBehavior"> <endpoint address="" binding="webHttpBinding" contract="SIHService.ICrossDomainService" behaviorConfiguration="webHttpBehavior"> <identity> <dns value="localhost:8732" /> </identity> </endpoint> <host> <baseAddresses> <add baseAddress=" http://localhost:8732/" /> </baseAddresses> </host> </service> </services> <behaviors> <endpointBehaviors> <behavior name="webHttpBehavior"> <webHttp /> </behavior> </endpointBehaviors> <serviceBehaviors> <behavior name="SIHouseServiceBehavior"> <serviceMetadata httpGetEnabled="true" /> <serviceDebug includeExceptionDetailInFaults="true" /> </behavior> <behavior name="DefaultServiceBehavior"> <serviceMetadata httpGetEnabled="true" /> <serviceDebug includeExceptionDetailInFaults="false" /> </behavior> </serviceBehaviors> </behaviors> </system.serviceModel> </configuration> выходят ошибки : не удалось разрешить указанную ссылкой сборку "System.ServiceModel.PollingDuplex", поскольку она зависит от "System.ServiceModel.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35", отсутствующей в текущей целевой платформе ".NETFramework,Version=v4.0,Profile=Client". Удалите ссылки на сборки не в целевой платформе или рассмотрите возможность переориентации проекта. не удалось разрешить указанную ссылкой сборку "System.ServiceModel.PollingDuplex", поскольку она зависит от "System.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a", отсутствующей в текущей целевой платформе ".NETFramework,Version=v4.0,Profile=Client". Удалите ссылки на сборки не в целевой платформе или рассмотрите возможность переориентации проекта. Элемент "bindings" имеет недопустимый дочерний элемент "pollingDuplexHttpBinding". Список ожидаемых элементов: "basicHttpBinding, customBinding, msmqIntegrationBinding, netPeerTcpBinding, netMsmqBinding, netNamedPipeBinding, netTcpBinding, wsFederationHttpBinding, ws2007FederationHttpBinding, wsHttpBinding, ws2007HttpBinding, wsDualHttpBinding, netTcpContextBinding, wsHttpContextBinding, basicHttpContextBinding, mexHttpBinding, mexHttpsBinding, mexNamedPipeBinding, mexTcpBinding, webHttpBinding". C:\Users\Asus\Favorites\Downloads\проект\ZWaveManager\ZWaveManager\SIHService\App.config 16 8 у подключаемой System.ServiceModel.PollingDuplex.dll Version и PublicKeyToken написаны правильно. Проверяла с помощью sn.exe. Что тут не так? ... |
| 21.04.2011, 13:07:08 |
aihulya, Попробуйте в свойствах проекта установить Target Framework ".NET Framework 4" Хорошо бы конфиг обернуть в тег SRC. ... |
| 21.04.2011, 14:27:22 |
Поменяла. Ничего не помогло((( ... |
| 22.04.2011, 10:53:18 |
start [/forum/topic.php?desktop=1&fid=21&tid=1442344]: |
90ms |
40ms |
| others: | 237ms |
| total: | 419ms |
