Форумы / WPF, Silverlight [игнор отключен] [закрыт для гостей] / Drag-and-Drop файлов MVVM
    #39495068
vb_sub
Всем привет, не получается дропнуть файл в контрол и получить его полное имя с путем.
Когда писал на VB.Net делал так и все работало
Код: vbnet
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
 Public NotInheritable Class DragAndDropBehaviour
        Private Sub New()
        End Sub
#Region "The dependecy Property"
        ''' <summary>
        ''' The Dependency property. To allow for Binding, a dependency
        ''' property must be used.
        ''' </summary>
        Private Shared ReadOnly PreviewDropCommandProperty As DependencyProperty = DependencyProperty.RegisterAttached("PreviewDropCommand", GetType(ICommand), GetType(DragAndDropBehaviour), New PropertyMetadata(AddressOf PreviewDropCommandPropertyChangedCallBack))
#End Region
#Region "The getter and setter"
        Public Shared Sub SetPreviewDropCommand(inUIElement As UIElement, inCommand As ICommand)
            inUIElement.SetValue(PreviewDropCommandProperty, inCommand)
        End Sub
        Private Shared Function GetPreviewDropCommand(inUIElement As UIElement) As ICommand
            Return DirectCast(inUIElement.GetValue(PreviewDropCommandProperty), ICommand)
        End Function
#End Region
#Region "The PropertyChangedCallBack method"
        Private Shared Sub PreviewDropCommandPropertyChangedCallBack(inDependencyObject As DependencyObject, inEventArgs As DependencyPropertyChangedEventArgs)
            Dim uiElement As UIElement = TryCast(inDependencyObject, UIElement)
            If uiElement Is Nothing Then
                Return
            End If
            AddHandler uiElement.Drop, AddressOf procecc_drag_and_drop
        End Sub
        Private Shared Sub procecc_drag_and_drop(sender As Object, e As DragEventArgs)
            Dim files As String() = DirectCast(e.Data.GetData(DataFormats.FileDrop), String())
            If files.Length = 1 Then
                Dim fl_path As String = files.First
                If UCase(Right(fl_path, 3)) = "PDF" Then
                    Dim d = e.Source.datacontext// получаем доступ к ViewModel
                    d.pdf_path = fl_path// присваиваем имя дропнутого файла полю из ViewModel
                End If
            Else
                MessageBox.Show("Выбрано несколько файлов")
            End If
            ' Assuming you have one file that you care about, pass it off to whatever
            ' handling code you have defined.
            'GetPreviewDropCommand(sender).Execute(e.Data)
            'e.Handled = True
        End Sub
#End Region
    End Class
в свойствах контрола устанавливаем
Код: xml
1.
       <Setter Property="behavior:DragAndDropBehaviour.PreviewDropCommand" Value="{Binding PreviewDropCommand}"/>
behavior- пространство имен, где живет класс DragAndDropBehaviour, PreviewDropCommand команда из ViewModel.
Сейчас пишу тоже самое на С#, только так уже не прокатывает.
Код: c#
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
public sealed class DragAndDropBehaviour
	private DragAndDropBehaviour()
	#region "The dependecy Property"
	/// <summary>
	/// The Dependency property. To allow for Binding, a dependency
	/// property must be used.
	/// </summary>
		#endregion
	private static readonly DependencyProperty PreviewDropCommandProperty = DependencyProperty.RegisterAttached("PreviewDropCommand", typeof(ICommand), typeof(DragAndDropBehaviour), new PropertyMetadata(PreviewDropCommandPropertyChangedCallBack));
	#region "The getter and setter"
	public static void SetPreviewDropCommand(UIElement inUIElement, ICommand inCommand)
		inUIElement.SetValue(PreviewDropCommandProperty, inCommand);
	private static ICommand GetPreviewDropCommand(UIElement inUIElement)
		return (ICommand)inUIElement.GetValue(PreviewDropCommandProperty);
	#endregion
	#region "The PropertyChangedCallBack method"
	private static void PreviewDropCommandPropertyChangedCallBack(DependencyObject inDependencyObject, DependencyPropertyChangedEventArgs inEventArgs)
		UIElement uiElement = inDependencyObject as UIElement;
		if (uiElement == null) {
			return;
		uiElement.Drop += procecc_drag_and_drop;
	private static void procecc_drag_and_drop(object sender, DragEventArgs e)
		string[] files = (string[])e.Data.GetData(DataFormats.FileDrop);
		if (files.Length == 1)
			string fl_path = files.First();
				dynamic d = e.Source.DataContext;//'object' не содержит определения для "DataContext" и не удалось найти метод расширения "DataContext",
				//принимающий тип 'object' в качестве первого аргумента (возможно, пропущена директива using или ссылка на сборку)
				d.pdf_path = fl_path;
		} else
			MessageBox.Show("Выбрано несколько файлов");
	#endregion
Подскажите плиз что поправить.
